I'm not sure why my results are giving me 0. I'm trying to do a simple date difference. Here's my code:
<cfset nowtime = now()>
<cfif DateDiff("s", getpost.dtstamp, nowtime) lt 60>
<cfset thedate = DateDiff("s", getpost.dtstamp, nowtime) & " seconds ago">
<cfelseif DateDiff("m", getpost.dtstamp, nowtime) lt 60>
<cfset thedate = DateDiff("m", getpost.dtstamp, nowtime) & " minutes ago">
<cfelseif DateDiff("h", getpost.dtstamp, nowtime) lte 23>
<cfset thedate = DateDiff("h", getpost.dtstamp, nowtime) & " hours ago">
<cfelseif DateDiff("d", v.dtstamp, nowtime) lte 7>
<cfset thedate = DateDiff("d", getpost.dtstamp, nowtime) & " days ago">
<cfelse>
<cfset thedate = dateformat(getpost.dtstamp, "mmmm dd")>
</cfif>
When I displayed the original variables it shows:
getpost.dtstamp = 2012-03-10 17:33:25.0 I don't know where this .0 is coming from because the database doesn't show that.
now = {ts '2012-03-12 16:16:02'}
I'm getting 0.
Okay, that explains it. You have got the wrong DateDiff unit. "m" stands for months, not minutes.
Zero what: seconds ago, minutes ago, ....? What is the data type of the dtstamp column?
Btw, are you intentionally using a different variable there?
Just a mistake as I pasted my code on the forum it should be the same as the variables above it. That's not the cause of the error
That was just an fyi in case it was not a copy/paste error 😉
What about the first two questions?
@-==cfSearching==- oh sorry. I missed that. So all results are stuck at saying "0 minutes ago"
and the column is a timestamp mysql
@dan same thing. it dumps the seconds correctly but just stops at the minutes and says 0 minutes. it goes no further, even though all differences between posts are way past 60 minutes.
I don't know if the error is being caused by that random .0. I don't even know where it's coming from. I checked the value of the timestamp column and there is no .0 in there but this is what's dumping out.
I don't if the error is being caused by that random .0. I don't even know where it's coming from.
That is just a user friendly representation of the timestamp value as a string. Internally, it is a big unreadable number xxxxxxxxx. But since you are not performing a string comparison, its not relevant.
Message was edited by: -==cfSearching==-
OMG! thanks. I always forget n for minutes lol
When in doubt, look at your data. What does this give you?
<cfdump var = "nowtime is #nowtime# dtstamp is #getpost.dtstamp# datediff seconds is #DateDiff("s", getpost.dtstamp, nowtime)#">
