RHCL in RH9 not working
Mar 8, 2012 1:50 AM
I changed from RH 8 to RH 9. I can open my "old" projects. Everything is fine.
Now I tried my old batch file which generates WebHelp and creates a zip of everything at the end. I checked and changed the paths in the batch file. When I start the batch file an error message appears: Invalid project for RHCL. Recreate the project with RoboHelp. (translated from German)
What does this message mean? All paths and names are ok.
I suggested that this only happens with "old" projects. Then I created a new project with RH 9 and I created a new batch file. At the end I have the same result.
Regards
Danny
    Mar 13, 2012 7:08 AM   in reply to DannyH.
    Hello DannyH,
    Welcome to Adobe Robohelp Forums.
    1) Can you generate output using RHCL for a test or a new project in Robohelp 9?
    2) You mentioned that you are using a batch file, did you tried only a single command : rhcl [project path] [-l] [layout name]
    Complete document : http://help.adobe.com/en_US/robohelp/robohtml/WS5b3ccc516d4fbf351e63e3 d11aff59c2a0-7fe3.html
    Also if possible upload some screenshots, also you can contact us on tcssup@adobe.com
    Vikram
    Mar 13, 2012 7:59 AM   in reply to DannyH.
    Hello,
    Is you Operating System is in German or Robohelp 9 is installed in German ?
    Any possibility for a Screen Sharing, If yes (Email me : tcssup@adobe.com)
    Vikram
  • RoboColum(n)
    Oct 8, 2004
    Mar 13, 2012 8:17 AM   in reply to DannyH.
    You may not be aware that Vikram is an Adobe employee. It would not be in his or Adobe's interests to compromise your IP.
    Apr 10, 2012 7:44 AM   in reply to DannyH.
    Use the Wish list/Bug Reporting form to bring this to Adobe's attention.
