I have trouble with indsign cs5.5 only chrash when i try export my document for ePub. But when i try from cs5 it exports fine, but not with offchourse the article panel that i will love to use and the object export options that are in cs 5.5. I upgraded my indesign just for this purpose, but it really doesn't work. I've got 7.5.2... anyone?
Jakobsen2:
I have trouble with indsign cs5.5 only chrash when i try export my document for ePub. But when i try from cs5 it exports fine, but not with offchourse the article panel that i will love to use and the object export options that are in cs 5.5. I upgraded my indesign just for this purpose, but it really doesn't work. I've got 7.5.2... anyone have a clue where to start looking for faults in my document, with in mind that it exports to ePub from cs5?
The CS5.5 EPUB export code is completely rewritten from CS5, and it is not surprising that it has different bugs.
I believe there are several known bugs that we can expect to see fixes for in CS6, when it releases, as EPUB is a rapidly evolving area with a lot of attention.
It is not your document's fault, though it is possible you might be able to work around it.
What operating system are you using? Can you make your file available?
HI, I'm using Mac and Lion 10.7.3.
I belived I had solved it with replacing all of my footnotes that seemed to cause the chrash, but InDesign still crash...
Here's my doc. I have not yet figured out my tables, some i have saved for jpg and inserted as picture but, the thin is maybe i can solve the tables in Dreamweaver, but since i can't move on fro InDesign ... Thanks for helping.
