dthbtdsvs
After Effects CS5 layer alignment
Mar 13, 2012 8:57 AM
Tags: #cs5 #after #effects #after_effects #layer #ae #align #alignment #protect #protected
Hey guys,
is there a way in After Effects to protect a layer from the layer alignment? Like in Illustrator with Alt+Click on the vector.
Thanks for every answer!
    Mar 13, 2012 9:18 AM   in reply to dthbtdsvs
    Lock it?
    Mar 13, 2012 9:38 AM   in reply to dthbtdsvs
    Not exactly sure what you mean by "protect from layer alignment", but there's a million ways to enforce a layer to stay stationary from adding a dummy hold keyframe to a simpel expression with fixed values...
    Mylenium
    Mar 14, 2012 6:43 AM   in reply to dthbtdsvs
    If you don't want a layer to be part of the alignment, don't select it?
    Otherwise what Mylenium said should work.
    Jun 9, 2012 2:07 PM   in reply to dthbtdsvs
    For those of you who couldn't figure out a clear solution, combining what has already been said, I figured out a little system that might help someone who likes to line up their objects WITHOUT have to move-one-of-the-objects-that-you-so-carefully-already-placed...
    Simply copy the position of the importantly-placed object (let's call it object A) that you don't want to move, and then select that and the other object you want to align and hit the center align (or whatever align you want).  If you are already lost and don't see the Align tab, you can find it the "Windows" menu.
    Obviously object A & B are now aligned but are out of place. Now parent object B (that you didn't copy the keyframe from) to the important object A. Next, paste the original position back into the important object A, and both will return to the original spot.
    It's not as nice an abobe built-in solution, but hey at least it works.
    Jun 9, 2012 2:13 PM   in reply to fallingscalesmedia
    and by the way, you can use this for more than two and it works for text as well...
