CQ5
CRXDE 1.0.1 issues with CQ5.5
Mar 14, 2012 7:29 AM
Tags: #cq5
When I try to use CRXDE 1.0.1 to access CQ5.5, I am getting the below error. Does any one know how to resolve this issue?
    Mar 14, 2012 8:53 AM   in reply to Murali Vusthipalli
    Hi Murali,
    Try deleting your .~/.crxde directory before starting it up.
    I simply started CRX101 with CQ55 without incurring in major issues.
    HTH
    Davide
  • Justin Edelson
    Nov 24, 2010
    Mar 15, 2012 7:51 PM   in reply to Murali Vusthipalli
    Murali-
    If you take a look of the console output of that java command, does it say "Will fork a JVM to get enough memory"? If so, the forked Java process will not get your debug parameters.
    Debugging in Eclipse, RAD, NetBeans, etc. is just a matter of starting a remote debugger pointing to port 30303.
    HTH,
    Justin
  • Justin Edelson
    Nov 24, 2010
    Mar 15, 2012 8:05 PM   in reply to Murali Vusthipalli
    Murali-
    Something's fishy here. You're passing -Xmx1024m, but the JVM is reporting a heap size of 910 MB and, as a result, forking. I don't know why that would be. You could either give the JVM more memory or pass -nofork to suppress the forking behavior.
    Also, I see you are running on Java 7. That is not supported. See http://dev.day.com/docs/en/cq/current/deploying/technical_requirements .html
    Maybe this is why it isn't supported
    Justin
  • Justin Edelson
    Nov 24, 2010
    Mar 15, 2012 8:19 PM   in reply to Murali Vusthipalli
    If you scroll further down, you'll see where Oracle JRE 1.7 isn't supported.
    Justin
