HiTopp
ColdFusion caching SQL Server credentials?
Mar 13, 2012 1:10 PM
Tags: #cache #coldfusion9 #stored_procedure #cfstoredproc #credentials #sql_server
I have been using ColdFusion's storedProc() service for a while with no issue.  However, I have run into a scenario where I have a local stored procedure executing a remote stored procedure.  When I attempt this via ColdFusion, I receive a very cryptic error:
The DBMS has returned the command code 224...
The following is the code I am using:
variables.storedProcService = new storedProc();
variables.storedProcService.clear();
variables.storedProcService.setAttributes(datasource="DATASOURCE", procedure="STOREDPROCNAME");
variables.storedProcService.addParam(cfsqltype="CF_SQL_INTEGER", type="in", value=0);
variables.storedProcService.execute();
However, executing the exact same procedures from SQL Server Management Studio results in no issues.
Then, when I use the following code:
variables.storedProcService.setAttributes(datasource="DATASOURCE", procedure="STOREDPROCNAME", username="USERNAME", password="PASSWORD");
The execution runs without issue.  My question is this, does ColdFusion cache SQL Server/Datasource credentials?  Why does it [seem to] not use the credentials I provided in Jrun?
    Mar 14, 2012 7:38 AM   in reply to HiTopp
    Quick idea - try disabling the "Maintain Connections" checkbox in the datasource tab, it could be maintaining a connection rather than creating a new one.
    Mar 14, 2012 8:25 AM   in reply to HiTopp
    In CFAdmin go to the DSN, click "Show Advanced Settings" and it's in there. Should then create a new connection for every request.
    Mar 14, 2012 8:35 AM   in reply to HiTopp
    Ah, quite possibly. Why aren't you using the native driver?
    Mar 14, 2012 8:38 AM   in reply to HiTopp
    In which case it might be worth creating a second DSN with the native driver, and use that; it may sort your issue.
    Mar 14, 2012 8:49 AM   in reply to HiTopp
    Honestly I have no idea. Just throwing ideas out there.
