Viewer Builder 1.9.0 Problem
Mar 15, 2012 4:11 AM
we are producing our first single issue publication and have successfully produced and tested a developer viewer (ipa) using viewer builder 1.9.0.
We are now ready to produce the distribution viewer (zip) to send to Apple but we are having issues (we have tried this on a couple of macs).
The process taken is exactly the same as we did for the developer viewer in that we specify in the popup box our p12 dist certificate and its password then our dist mobile provision.
This all seems ok but when we click 'download and sign' nothing happens except for the distribution certificate field in the popup window now has a red border. There is no error message.
We have tried to remake the certificate but this did not work.
Does anyone have an answer?
    Mar 15, 2012 4:35 AM   in reply to djtbc
    Did you hover the red box with your mouse? Normally there is the error
    message appearing. That might give some clues to what is going wrong here.
    —Johannes
    Mar 15, 2012 5:34 AM   in reply to djtbc
    Yes, it sounds like this is not the right certificate. you should be able to rebuild that.
    if the error is on the distribution mobileprovision, you need to make sure that you made this provisioning file for the app you are exporting (in the provisioning portal at apple).
    —Johannes
    Mar 15, 2012 5:36 AM   in reply to djtbc
    Sounds like you are not on the machine where the certificate is created first. you don't have the private key on this machine.
    either you obtain the private key from the first machine or create a new certificate on this machine (then no other computer can sign apps).
    —Johannes
    Mar 15, 2012 5:53 AM   in reply to djtbc
    You are welcome. just make sure to keep ALL certificate files you create in
    the process. and name them correctly.
    —Johannes
    Mar 15, 2012 6:37 AM   in reply to djtbc
    yes, separate dev and dist (i use different folders). you can name them
    what you want, just keep the file ending.
    —Johannes
  • Bob Bringhurst
    May 29, 2007
    Mar 15, 2012 6:57 AM   in reply to djtbc
    I've experienced this problem as well. I was able to add the developer cert to the keychain when I double-clicked it, but the dist cert didn't register for some reason. I quit the Keychain Access utility and restarted my computer. Then it worked. Try that.
    It sounds like Apple changed some of their file naming conventions recently.
    Mar 15, 2012 7:02 AM   in reply to djtbc
    seen this last week with another customer .. keychain was acting up when exporting the certificate to p12.. as if we were not right-clicking on the right spot.
    ... eventually selected the certificate and then used the menu File>Export Items .. that worked.
Bookmarked By (1)
