I am trying to set the content-type for a cfhttp request like this (on coldfusion 9):
<cfhttp redirect="no" method="get" timeout="120" url="http://10.0.0.1/test2.cfm">
<cfhttpparam type="HEADER" name="Content-Type" value="application/json; charset=utf-8">
</cfhttp>
// coding on test2.cfm:
<cfset x = GetHttpRequestData()>
<cfdump var=#x#>
// Output on test2.cfm
content | [empty string] | ||||||||||||||||
headers |
method | GET | ||||||||||||||||
protocol | HTTP/1.1 |
As you can see no content-type is send through. I also tried the sniffer.exe:
GET http://10.0.0.1:80/test2.cfm HTTP/1.1
Host: 127.0.0.1
Proxy-Connection: close
Connection: TE
TE: trailers, deflate, gzip, compress
User-Agent: ColdFusion
Accept-Encoding: deflate, gzip, x-gzip, compress, x-compress
Here you can also see that no content-type was passed through. The sniffer should report back
Host: 127.0.0.1
Connection: TE
Content-Type: application/json; charset=utf-8
But is does not, what do i need todo to set the content-type in a cfhttp request.
Kind regards,
Nebu
When used as a REQUEST header (which you are doing) the Content-Type header indicated the content type of the Entity Body of the request. This means it is only a valid header for requests that have a body (POST and PUT). Change your CFHTTP type to POST and you will see the header show up.
jason
No idea why but i could not reply for some reason, anyway now i can again. First of all thanks for your response. I tried to change te request to a post which indeed does send the correct content-type. However the server which i am connecting to requires the following syntax:
GET {webpage} HTTP/1.1
Accept: text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.1.4322)
Host: {domain}
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Changing Get to Post returns an error, so i need to be able to set the Content-Type for a Get request. Is this possible with cfhttp?
I'm new to CF, but can't you add the Content-Type header using cfhttpparam:
http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=Tags_g-h_10.html
Jim
jimcpl,
If you read his first post, that is exactly what he is trying to do.
Jason
Hi Jason,
I re-read the thread, and sorry, I missed that ... Got it now ...
Jim
I do not have any contact with the website owner so i cannot contact them. I realise setting the content-type in this manor is useless but the website requires it for some reason.Would still love to know a way to get around this problem. Futhermore it is also strange that the cfhttp tag strips a header that i instruct it to use.
Just for fun, try this:
<cfhttpparam type="CGI" encoded="false" name="Content_Type" value="application/json; charset=utf-8">
@12Robots: Brilliant it works not sure why but it works. Thank you very much this solves a really anoying problem.
It works because CGI.CONTENT_TYPE is equivilent to the header Content-Type. I found something about it in the docs for the Java HTTTPServletRequest. So I thought it was worth a try.
jason
Damn replied to soon it still doesn't work i it does send Content_Type: application/json; charset=utf-8 but apparently the website requires Content-Type: application/json; charset=utf-8. So i am still stucked.
Then I'm afraid you're hosed.
You could try dropping down into Java and usign that, or using cURL from the command line or somehting. But I doubt there is anyway to force CF to make that invalid HTTP call.
I hope you are not doing something business critical with a service where you can't even get a hold of their admins to tell them something like this is wrong. Frankly. I would question the wisdom of depending on such a service.
GET requests do not have Content-Type headers. Period. There is no need for them, and the fact that they require it is stupid.
Can you say what service this is?
Jason
12Robots - are you sure about your statement that GET method requests cannot have Content-Type headers? I don't think that that is correct. I've always thought that it was valid (maybe unusual, but ...) and this W3C link weems to agree, especially in the context of its comment about what Content-Type means in a HEAD method request: http://www.w3.org/Protocols/rfc2616/rfc2616-sec14.html
The big problem with trying to get around the CFHTTP limitation by using the CGI scope is that the dash is illegal in a CF varname.
There is a custom tag called CFHTTP5 that getsaround a lot of the CFHTTP limitations, including cookie preservation across multiple requests. I haven't used it for a long time (CF5), but it is still actively developed. Costs $50 - http://www.cftagstore.com/tags/cfxhttp5.cfm
-reed
Yes, I am sure.
If you are referring to this line in the RFC:
The Content-Type entity-header field indicates the media type of the
entity-body sent to the recipient or, in the case of the HEAD method,
the media type that would have been sent had the request been a GET.
That is referring to the RESPONSE header "Content-Type" not the REQUEST header. So if a GET request was made for a GIF image, then the response would include a Content-Type: image/gif header. Which is describing the body.
Content-Type is for describing the body of a request or response. If a request/response doesn't have a body, it doesn't need a Content-Type header. The exception to that is for the response to a HEAD request where the response will include the Content-Type to indicated the type of the body that would have been returned. Since a HEAD request is a request only for the response headers, this makes perfect sense.
jason
So it looks like cURL will let you do it.
For example:
curl --header "Content-Type: text/html" http://www.google.com
http://screencast.com/t/UWV0LSXQs
Maybe you could do it that way in combination with <cfexecute>
Jason
@Nebu23, @12Robots
Am I seeing things, or did'nt Nebu23 mark this as the answer? It helps to mark answered questions as answered.
He unmarked it as the answer, since it turned out it didn't work. Which is reasonable.
Jason
Jason
Ah, thanks for clearing that up.
Then you may be hosed. Cause I doubt you are going to be able to do it.
I suggest contacting the administrators of that service and find out why they require a useless header.
Are you even passing along any JSON data? Why would you need to tell them that your bodyless post contains JSON data, when it doesn't?
Jason
These seem to work, though they stand for something else
<cfhttpparam type="HEADER" name="Content_Type" value="application/json;charset=utf-8">
<cfhttpparam type="HEADER" name="'Content-Type'" value="application/json;charset=utf-8">
Hope this inspires someone.
Correct i changed it to helpfull cause it could have worked but in my case it didn't. I am currenty writing a component based on java to bypass this issue in cfhttp. I will post this component here so anyone else encoutering this issue can also use it. I am aware of the cfx_http5 tag but i do not like to use anything that is not open source or part of coldfusion itself cause then i have to depent on others to solve issues.
Well posted my beta version on http://coldfusion9.blogspot.com/2012/03/custom-cfhttp-tag.html . This tag overcomes some of the problems with the cfhttp tag and response very similar to the standard cfhttp tag with some extra features.
Java is the way
I suppose that "under the hood" CFHTTP is cutting the "Content-Type" header for verbs other than PUT/POST.
This would be a wrong assumption (GET requests are not prohibited to have a "Content-Type" header even if they have -obviously- no body).
See this StackOverflow discussion on the subject.
Now the Java solution: the original code
</cfhttp>
becomes (in CFScript)
<cfscript>
req = Createobject("java", "org.apache.http.client.fluent.Request");
res = req.get("http://10.0.0.1/test2.cfm ")
.setHeader("Content-Type", "application/json; charset=utf-8")
.execute()
.returnContent();
</cfscript>
That's all, thank you Java !
