how to get or set the rtmfp TURN proxy service?
Mar 15, 2012 8:30 PM
Tags: #rtmfp #proxy #p2p #ture
when my project,we use flash p2p ,but the connections would be failed sometimes ,the docs said can configure the TURN proxy,but how to get the TURN proxy?
write a server or do some setting or install some softwares?
any help?
thanks very much!
    Mar 19, 2012 11:20 AM   in reply to acme2007
    the Flash runtime only supports draft-ietf-behave-turn-8 (with no authentication) for RTMFP, not any later draft or the final RFC version:
       http://tools.ietf.org/html/draft-ietf-behave-turn-08
    i don't know where you could get something like that now, unfortunately. i wrote the one we use here.
    if you happened to have such a TURN proxy server, you configure Flash Player to use it by adding a line to your mms.cfg file (location depends on your operating system; on the Mac it's at /Library/Application Support/Macromedia/mms.cfg). you add a line that says:
       RTMFPTURNProxy=<host/ipaddr>
    for example
      RTMFPTURNProxy=10.11.12.13
