I have been working on a layered png file of a site for the past two days. Today I just went to "save as" for the last time with a new version. I got an error that said "Fireworks can not save the document. An error occured."
So then I tried saving to a different location. Again the same error. Hmm this is strange. Mind you the file has been opened and closed and saved every 10 minutes for the last two days. Finally I just saved and it seemed to work. I closed the document and went to make sure that it was still there and POOF it is gone.
Searched my entire drive. No luck!!
I have been a designer working in adobe product for 10 years and never, never have I been screwed like this. How can an application actually delete the file that was already saved in the file system?
I don't understand at all how this has happened.
By the way this is Fireworks 4 and all I can say is this has to be the buggiest version of Fireworks I have ever worked in. Usually I just ignore the bugs but this is pretty hard to ignore.
Anyone have any suggestions on how to recover this file? Pretty sure it is gone.
This used to happen to me a lot too with CS4.
I believe it is fixed/correct in either an update or with CS5.
Unfortunately, I believe your file is gone. Like any software, files are saved from memory, with memory issues, file gets corrupted or not saved, or similar.
So the best way you can deal with this, is to get backup in the future.
The bug made me change my workflow and it is something I suggest you do for the future:
It is not a nice situation you got into, I feel sorry for it happening. But look at the bright side, you might find some new approaches to your design.
And do backups!
Yes normally I have an external hard drive that does dropbox backups every 10 minutes. As another failsafe, I had it saved to dropbox. But for some reason, I forgot to plug in my time machine drive.
Dropbox did have a version but it was like an hour old so it wasn't a complete loss. I just don't understand how Fireworks could delete a file from the filesystem.
Thanks for the advice and yes, when working in Fireworks from now on I am going to take extra steps to make sure this doens't happen. Thanks for the advice.
Jesse
If that file was really important, you could try some data recovery software... I've successfully recovered files that I'd accidentally deleted this way.
When you trash files, they get removed from your system's file directory, so to speak, but they're still on your hard drive for a period of time... so I imagine your FW file might still be around. However, it sounds like you found a version to work from, so it's probably not worth the time it would take to explore this option.
Oh, I almost forgot to mention: You might want to take the time to run Disk Utility to give your hard drive a checkup (e.g., run the Verify Disk command).
