Is there a way to name the pages in the Pages Panel? Since I am linking to dozens of pages, it's hard to identify which page contains which document.
What about naming Hyperlinks? Now that I've used Text Anchors to link pages, I have dozens of Hyperlink that aren't helpful to distinguish what they are since it's just "Hyperlink 1, Hyperlink 2, Hyperlink 3". Ideally I want to rename hyperlinks to something like "Table of Content, 1. Oranges, etc.".
I have something similar below setup in my document. Each number in the table of content links to the corresponding page. I would like to name the hyperlinks so it's easier to tell what's link to what.
Table of Content
1. Oranges
2. Grapes
3. Apples
1. Oranges
2. Grapes
3. Apples
Thanks for any help!
This is a two step process, first define your destination(text anchor), then define the hyperlink, here is an example:
Go to page 1(not TOC page), with text cursor highlight/select "1. Orange" Then from the Hyperlinks Panel > flyout > New Hyperlink Destination > Type: Text Anchor + Name: This will autoplace the selected text, which in this case is "1. Orange"
Repeat for Grapes + Apples
Go to TOC page, with text cursor highlight/select "1. Orange" Then from the Hyperlinks Panel > flyout > New Hyperlink > Link To: Text Anchor + Destination Text Anchor: the pull down will have all of your text anchors, for this select hyperlink, select "1. Orange"
I see what's happening here. I am putting Rectange Frames around each section (so "1. Oranges") and then linking the Rectange Frames to the Text Achor. That's why it's showing up as "Hyperlink 1, 2, 3, etc". I am doing this because the document is used on iPads so it's easier to clink on links if there's a frame around the word as opposed to just linking the words.
Is there a work around to this so I can see the hyperlink names and still use the Rectange Frames?
Again, thanks for your reply Jeff!
The method I described, you can select a visible rectangle appearance and some different highlights (when link is clicked in pdf).
You can create the hyperlinks with separate rectangles, but this may be harder to manage if you are adding or deleting various toc entries, and then you have to manually adjust the hyperlink rectangle.
