Use a script
Mar 16, 2012 10:22 AM
    Mar 16, 2012 10:22 AM   in reply to Community Help
    WHERE is the scripts folder?!
    Mar 16, 2012 10:27 AM   in reply to raymassie
    Hi bubbagrump
    It´s inside the own Illustrator installation folder. For example...if you are in Windows 7 64 bits...by default it´s HD > Program Files(x86) > Adobe > Adobe Illustrator CS5 > Scripts.
    Which OS are you?
    Best Regards
    Gustavo.
    Mar 16, 2012 10:35 AM   in reply to Gustavo Del Vechio
    If you are referring to the folder scripts should be installed in, this is inside the presets folder in the Illustrator program folder.
    Mar 16, 2012 10:42 AM   in reply to Monika Gause
    i found it in the Presets folder; thanks, to you both.
    i just think the article from Adobe needs to be less oblique; basic information shouldn't require input from the user community.
    Apr 18, 2012 1:52 PM   in reply to Community Help
    I discovered that the complete file path to the script folder on Windows 7 is:
    C:\Program Files (x86)\Adobe\Adobe Illustrator CS5\Presets\en_US\Scripts
    Unfortunately, in my office, that folder is protected for aministrative access only. Ugh.
    Apr 18, 2012 2:20 PM   in reply to NateshDaniel
    You can call a script from anywhere, suing File > Script > Other script
