Flash crashes when I try to open any Movie Clip with a text field. This happens with both CS 5 and CS5.5. I am on a Mac Running 10.6.8.
The files in question began as a CS4 about a year ago and have been converted to CS5 and CS55 since.
This problem happens sometime but not always, but it has definitely gotten worse with the latest Flash Pro update. (Flash Pro CS5.5 v. 11.5.1.349)
This appears to be related to Mac only. I have reprouced on two other Macs, but have not been able to on a PC. (all running CS 5 or CS 5.5)
We have a Javascript that goes through the FLA and embeds the fonts in all text fields. (Because font embedding in CS5 or CS5.5 infamously does not work at all). Sometimes if you run this script before you try to open the MC it will apparently fix the problem and let you in, sometimes it will not. (Right now it will not).
Any insite anyone has would be greatly appreciated.
Thanks. Restarting does sometime alleviate the probem for a few minutes.
It sometimes seems to be related to broken links to fonts. I work on this project on two different computers. For some reason it thinks that the fonts used on the two systems are different -- even though they are the same one. So I get font remapping notices whenever I start up the FLAs (i.e., It will say that "Fred Bold" is not available, but it will let me remap to "Fred Bold").
So yesterday I painstakingly went through one of the FLAs and reassiged all text fields to Library font objects which I made (like "myboldFont", etc). I could then point the library font to the correct font if the system said it could find it -- thus getting around remapping. This actually seemed to work for a while.
However, since then I've had more crashes concerning movie clips using these new Library fonts. Overall it is perfoming better, but still lots of crashes around dealing with Layers or MCs with text fields.
It's very weird problem. It seems to crop up and then go away for a while.
Hi Ziplinski,
We would like to try to reproduce this issue in house so that we can address it.
Could you please send me a sample fla file that reproduces this issue for you currently? Also please include all fonts that are used in the sample file so that we can use the same fonts as the one(s) that you have installed on the machine where the bug is currently reproducing for you.
You can zip all files then attach them to an email and send it to FlashAuthBetaBugs@adobe.com. Note that our filter system doesn't accept .zip files so after you've zipped the files, before you attach them to the email, please first change the ".zip" file extension from ".zip" to ".zzz"
Thanks so much.
Marisa
Adobe Flash Authoring, QE
I was able to solve the problem to a great extent by unistalling and reinstalling CS5.5 (and running the Flash update again.). The problem does still occur, but probably about 15-20% as often as it did before. Usually it will happen if I have two or more Flash projects open.
But at this point, I'm able to move forward -- so I'll just hope that a future update or upgrade to Flash will fix it completely.
Final Note:
Reinstalling Flash did help for a while but the problem came back over the course of a few days. Unistalling and reinstalling again did seem to help a bit, but less so (go figure).
At this point I have finished a grueling 4-week process of porting this buggy file to work on various devices -- so hopefully I will not have to come back to it again.
I did get word back from Adobe support which said the file was corrupt but could offer no other assistance. They also said they were able to reproduce the problem on both Mac and Windows. The problem does certainly occur more in this file than others(but not exclusively in this file) so I accept that there is something different about this file. I can live with the frequency of crashes and hangs it happens in other files. Moving forward, all new projects will originate in CS5.5 so I expect I will not see it again.
So to sum up, this is what I know for certain about this problem:
1) It only affects Movie Clips or Layers Containing text fields
2) It only affects FLA that began as CS4 and were brought forward into CS5 or CS5.5
Beyond that it occurrs somewhat randomly and has been extremely difficult to pin down.
This is becoming insane!
Flash CS5.5 crashes every 15 minutes or so...
I cant work like this, I only have 20 something days left in my trial and then Adobe expects me to pay for this?
Process: Adobe Flash CS5.5 [174]
Path: /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
Identifier: com.adobe.flash
Version: 11.5.1.349 (11.5.0)
Code Type: X86 (Native)
Parent Process: launchd [89]
Date/Time: 2012-01-11 16:06:53.832 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 2607 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 1259 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 675A4C25-6D0D-4E90-865A-17066CBFB07F
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffffffff
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0000000022f50262
Java VM: Java HotSpot(TM) Client VM (20.4-b02-402 mixed mode macosx-x86)
Current thread (000000004f801400): JavaThread "main" [_thread_in_native, id=-1597422272, stack(00000000bf800000,00000000c0000000)]
Stack: [00000000bf800000,00000000c0000000]
Java Threads: ( => current thread )
000000004f83f400 JavaThread "Thread-4" [_thread_blocked, id=-1309147136, stack(00000000b1e80000,00000000b1f80000)]
0000000060045400 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1312858112, stack(00000000b1af6000,00000000b1bf6000)]
0000000060044800 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1313914880, stack(00000000b19f4000,00000000b1af4000)]
000000005012ec00 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1314971648, stack(00000000b18f2000,00000000b19f2000)]
000000005012d400 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1316028416, stack(00000000b17f0000,00000000b18f0000)]
000000005012c800 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1317085184, stack(00000000b16ee000,00000000b17ee000)]
000000005f805000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1319198720, stack(00000000b14ea000,00000000b15ea000)]
000000005f804000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1320255488, stack(00000000b13e8000,00000000b14e8000)]
000000005f803000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1321312256, stack(00000000b12e6000,00000000b13e6000)]
000000005f802000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1322369024, stack(00000000b11e4000,00000000b12e4000)]
00000000500f6800 JavaThread "Finalizer" daemon [_thread_blocked, id=-1323425792, stack(00000000b10e2000,00000000b11e2000)]
000000004f816c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1324482560, stack(00000000b0fe0000,00000000b10e0000)]
=>000000004f801400 JavaThread "main" [_thread_in_native, id=-1597422272, stack(00000000bf800000,00000000c0000000)]
Other Threads:
00000000500f3c00 VMThread [stack: 00000000b0ede000,00000000b0fde000] [id=-1325539328]
000000005f806800 WatcherThread [stack: 00000000b15ec000,00000000b16ec000] [id=-1318141952]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14784K, used 583K [0000000052910000, 0000000053910000, 0000000053910000)
eden space 13184K, 1% used [0000000052910000, 0000000052950470, 00000000535f0000)
from space 1600K, 20% used [00000000535f0000, 00000000536417b0, 0000000053780000)
to space 1600K, 0% used [0000000053780000, 0000000053780000, 0000000053910000)
concurrent mark-sweep generation total 49152K, used 18687K [0000000053910000, 0000000056910000, 000000005a910000)
concurrent-mark-sweep perm gen total 18072K, used 10841K [000000005a910000, 000000005bab6000, 000000005e910000)
Code Cache [0000000050901000, 0000000050b02000, 0000000052901000)
total_blobs=1018 nmethods=884 adapters=77 free_code_cache=31474624 largest_free_block=384
Virtual Machine Arguments:
JVM Args: -Djava.awt.headless=true -Xmx128m
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 6144M, Free = 17592186044154M
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...ia.Flash Player.authplaylib 0x22f50262 0x22c86000 + 2925154
1 ...ia.Flash Player.authplaylib 0x22f54b1a 0x22c86000 + 2943770
2 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
3 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
4 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
5 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
6 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
7 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
8 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
9 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
10 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
11 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
12 ...ia.Flash Player.authplaylib 0x22f54a96 0x22c86000 + 2943638
13 ...ia.Flash Player.authplaylib 0x22efe805 0x22c86000 + 2590725
14 ...ia.Flash Player.authplaylib 0x230d6b32 0x22c86000 + 4524850
15 ...ia.Flash Player.authplaylib 0x230d6e8e 0x22c86000 + 4525710
16 ...ia.Flash Player.authplaylib 0x22fcb3bc 0x22c86000 + 3429308
17 ...ia.Flash Player.authplaylib 0x2300d28c 0x22c86000 + 3699340
18 ...ia.Flash Player.authplaylib 0x23133924 ExternalPlayer_Initialize + 222836
19 com.apple.CoreFoundation 0x90a61a3b __CFRunLoopRun + 8059
20 com.apple.CoreFoundation 0x90a5f3c4 CFRunLoopRunSpecific + 452
21 com.apple.CoreFoundation 0x90a5f1f1 CFRunLoopRunInMode + 97
22 com.apple.HIToolbox 0x970a7e04 RunCurrentEventLoopInMode + 392
23 com.apple.HIToolbox 0x970a7bb9 ReceiveNextEventCommon + 354
24 com.apple.HIToolbox 0x97230084 _AcquireNextEvent + 54
25 com.apple.HIToolbox 0x97225d40 RunApplicationEventLoop + 228
26 com.adobe.flash 0x010244aa non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
27 com.adobe.flash 0x00ffcead CTimerImpl::~CTimerImpl() + 279
28 com.adobe.flash 0x00ffcf59 CTimerImpl::~CTimerImpl() + 451
29 com.adobe.flash 0x00265182 devtech_private::Buffer<unsigned short>::Grow(unsigned long) + 1506
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x9a237382 kevent + 10
1 libSystem.B.dylib 0x9a237a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9a236f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9a236cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9a236781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9a2365c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x9a210b42 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x9a23e6f8 _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x9a28705f pthread_cond_wait + 48
3 com.adobe.amt.services 0x0bf9d274 C_AMTUISwitchSuppressUpdates + 16864
4 com.adobe.amt.services 0x0bf96074 C_EULA_SetState + 2166
5 com.adobe.amt.services 0x0bf9d2da C_AMTUISwitchSuppressUpdates + 16966
6 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
7 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 3:
3 ...ia.Flash Player.authplaylib 0x230d611f 0x22c86000 + 4522271
4 ...ia.Flash Player.authplaylib 0x22ca025f 0x22c86000 + 107103
5 ...ia.Flash Player.authplaylib 0x230d620c 0x22c86000 + 4522508
6 ...ia.Flash Player.authplaylib 0x230d6250 0x22c86000 + 4522576
7 ...ia.Flash Player.authplaylib 0x230d6376 0x22c86000 + 4522870
8 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
9 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 4:
Thread 5:
Thread 6:
Thread 7:
0 libSystem.B.dylib 0x9a23eaa2 __semwait_signal + 10
1 libSystem.B.dylib 0x9a23e75e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x9a2403f8 pthread_cond_wait$UNIX2003 + 73
3 ...ple.CoreServices.CarbonCore 0x914c821e TSWaitOnCondition + 126
4 ...ple.CoreServices.CarbonCore 0x914b3b68 TSWaitOnConditionTimedRelative + 202
5 ...ple.CoreServices.CarbonCore 0x914af533 MPWaitOnQueue + 250
6 com.adobe.ACE 0x060c5309 0x608a000 + 242441
7 com.adobe.ACE 0x060c4d01 0x608a000 + 240897
8 ...ple.CoreServices.CarbonCore 0x9149354a PrivateMPEntryPoint + 68
9 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
10 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 8:
Thread 9:
Thread 10:
0 libSystem.B.dylib 0x9a24e0d6 recvfrom$UNIX2003 + 10
1 libSystem.B.dylib 0x9a26deab recv$UNIX2003 + 54
2 ServiceManager-Launcher.dylib 0x248bc2d7 Invoke + 54887
3 ServiceManager-Launcher.dylib 0x248bb376 Invoke + 50950
4 ServiceManager-Launcher.dylib 0x248ba227 Invoke + 46519
5 ServiceManager-Launcher.dylib 0x248ba279 Invoke + 46601
6 ServiceManager-Launcher.dylib 0x248ba303 Invoke + 46739
7 ServiceManager-Launcher.dylib 0x248b4706 Invoke + 23190
8 ServiceManager-Launcher.dylib 0x248b48ef Invoke + 23679
9 ServiceManager-Launcher.dylib 0x248b54cf Invoke + 26719
10 ServiceManager-Launcher.dylib 0x248b55cd Invoke + 26973
11 ServiceManager-Launcher.dylib 0x248b89b8 Invoke + 40264
12 ServiceManager-Launcher.dylib 0x248b8c61 Invoke + 40945
13 ServiceManager-Launcher.dylib 0x248b928f Invoke + 42527
14 ServiceManager-Launcher.dylib 0x248b948c Invoke + 43036
15 ServiceManager-Launcher.dylib 0x248ab11a Login + 1654
16 ServiceManager-Launcher.dylib 0x248ac6f7 Login + 7251
17 ServiceManager-Launcher.dylib 0x248b99fb Invoke + 44427
18 ServiceManager-Launcher.dylib 0x248bbf49 Invoke + 53977
19 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
20 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 11:
0 libSystem.B.dylib 0x9a210b5a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x9a23e6e1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x9a26d5a8 pthread_cond_timedwait_relative_np + 47
3 ...ia.Flash Player.authplaylib 0x230d60e7 0x22c86000 + 4522215
4 ...ia.Flash Player.authplaylib 0x22e669de 0x22c86000 + 1968606
Thread 12: Java: Exception Handler Thread
0 libSystem.B.dylib 0x9a210afa mach_msg_trap + 10
1 libSystem.B.dylib 0x9a211267 mach_msg + 68
2 libSystem.B.dylib 0x9a27cc78 mach_msg_server + 520
3 libjvm.dylib 0x4f110974 jio_snprintf + 45283
4 libjvm.dylib 0x4f1107f7 jio_snprintf + 44902
5 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
Thread 13: Java: Gang worker#0 (Parallel GC Threads)
2 libjvm.dylib 0x4f3a6ac6 JVM_RaiseSignal + 385574
3 libjvm.dylib 0x4f10f8d9 jio_snprintf + 41032
4 libjvm.dylib 0x4f399d64 JVM_RaiseSignal + 332996
5 libjvm.dylib 0x4f399e41 JVM_RaiseSignal + 333217
6 libjvm.dylib 0x4f10f40b jio_snprintf + 39802
7 libjvm.dylib 0x4f125271 jio_vsnprintf + 405
8 libjvm.dylib 0x4f12515b jio_vsnprintf + 127
9 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
10 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
11 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 14: Java: Gang worker#1 (Parallel GC Threads)
Thread 15: Java: Gang worker#2 (Parallel GC Threads)
Thread 16: Java: Gang worker#3 (Parallel GC Threads)
Thread 17: Java: Concurrent Mark-Sweep GC Thread
2 libjvm.dylib 0x4f3a6b96 JVM_RaiseSignal + 385782
3 libjvm.dylib 0x4f3a6f61 JVM_RaiseSignal + 386753
4 libjvm.dylib 0x4f399d80 JVM_RaiseSignal + 333024
7 libjvm.dylib 0x4f1c8323 JVM_Close + 13811
8 libjvm.dylib 0x4f1c8291 JVM_Close + 13665
9 libjvm.dylib 0x4f12b97b jio_vsnprintf + 26783
10 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
11 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
12 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 18: Java: VM Thread
7 libjvm.dylib 0x4f1984eb JVM_Lseek + 157928
8 libjvm.dylib 0x4f19817b JVM_Lseek + 157048
Thread 19: Java: Reference Handler
4 libjvm.dylib 0x4f3a27a0 JVM_RaiseSignal + 368384
5 libjvm.dylib 0x4f3e5a0a JVM_RaiseSignal + 643434
6 libjvm.dylib 0x4f1a5c28 JVM_MonitorWait + 203
7 libjvmlinkage.dylib 0x248dae75 JVM_MonitorWait + 69
8 ??? 0x5090b9d9 0 + 1351662041
9 ??? 0x50903e31 0 + 1351630385
10 ??? 0x50903e31 0 + 1351630385
11 ??? 0x50901374 0 + 1351619444
12 libjvm.dylib 0x4f1997ff JVM_Lseek + 162812
13 libjvm.dylib 0x4f199573 JVM_Lseek + 162160
14 libjvm.dylib 0x4f1a5a3d JVM_StartThread + 2922
15 libjvm.dylib 0x4f1a5931 JVM_StartThread + 2654
16 libjvm.dylib 0x4f1a58af JVM_StartThread + 2524
17 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
18 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
19 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
20 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
21 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 20: Java: Finalizer
9 ??? 0x50af5b40 0 + 1353669440
10 ??? 0x50901374 0 + 1351619444
11 libjvm.dylib 0x4f1997ff JVM_Lseek + 162812
12 libjvm.dylib 0x4f199573 JVM_Lseek + 162160
13 libjvm.dylib 0x4f1a5a3d JVM_StartThread + 2922
14 libjvm.dylib 0x4f1a5931 JVM_StartThread + 2654
15 libjvm.dylib 0x4f1a58af JVM_StartThread + 2524
16 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
17 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
18 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
Thread 21: Java: Surrogate Locker Thread (Concurrent GC)
6 libjvm.dylib 0x4f10f34e jio_snprintf + 39613
7 libjvm.dylib 0x4f1b6efa JVM_IsPrimitiveClass + 6366
8 libjvm.dylib 0x4f1b6dc4 JVM_IsPrimitiveClass + 6056
9 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
10 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
11 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
12 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
13 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 22: Java: Signal Dispatcher
0 libSystem.B.dylib 0x9a210b36 semaphore_wait_trap + 10
1 libjvm.dylib 0x4f1b7766 JVM_IsPrimitiveClass + 8522
2 libjvm.dylib 0x4f1b7144 JVM_IsPrimitiveClass + 6952
3 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
4 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
Thread 23: Java: C1 CompilerThread0
7 libjvm.dylib 0x4f1be89a JVM_Write + 362
8 libjvm.dylib 0x4f1b891c JVM_IsPrimitiveClass + 13056
9 libjvm.dylib 0x4f1b86c6 JVM_IsPrimitiveClass + 12458
10 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
11 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
12 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
13 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
14 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 24: Java: Low Memory Detector
7 libjvm.dylib 0x4f1ba40e JVM_IsPrimitiveClass + 19954
8 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
9 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
Thread 25: Java: VM Periodic Task Thread
4 libjvm.dylib 0x4f1bc76d JVM_IsPrimitiveClass + 29009
Thread 26: Java: FelixDispatchQueue
11 ??? 0x50903e31 0 + 1351630385
12 ??? 0x50903e31 0 + 1351630385
13 ??? 0x5090430d 0 + 1351631629
14 ??? 0x50901374 0 + 1351619444
15 libjvm.dylib 0x4f1997ff JVM_Lseek + 162812
16 libjvm.dylib 0x4f199573 JVM_Lseek + 162160
17 libjvm.dylib 0x4f1a5a3d JVM_StartThread + 2922
18 libjvm.dylib 0x4f1a5931 JVM_StartThread + 2654
19 libjvm.dylib 0x4f1a58af JVM_StartThread + 2524
20 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
21 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
22 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
23 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
24 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 27: Java: FelixStartLevel
11 ??? 0x5090430d 0 + 1351631629
12 ??? 0x50901374 0 + 1351619444
13 libjvm.dylib 0x4f1997ff JVM_Lseek + 162812
14 libjvm.dylib 0x4f199573 JVM_Lseek + 162160
15 libjvm.dylib 0x4f1a5a3d JVM_StartThread + 2922
16 libjvm.dylib 0x4f1a5931 JVM_StartThread + 2654
17 libjvm.dylib 0x4f1a58af JVM_StartThread + 2524
18 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
19 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
20 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
21 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
22 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 28: Java: FelixPackageAdmin
Thread 29: Java: Code Model Worker
3 libjvm.dylib 0x4f3a6e29 JVM_RaiseSignal + 386441
4 libjvm.dylib 0x4f223a5a JVM_SocketAvailable + 271
5 ??? 0x5090b9d9 0 + 1351662041
6 ??? 0x50903e31 0 + 1351630385
7 ??? 0x50903e31 0 + 1351630385
8 ??? 0x5090430d 0 + 1351631629
9 ??? 0x50904473 0 + 1351631987
10 ??? 0x50903f97 0 + 1351630743
Thread 30: Java: Code Model Worker
Thread 31:
1 libSystem.B.dylib 0x9a26a9c5 nanosleep$UNIX2003 + 188
2 com.adobe.flash.flbridge 0x253b785b ScObjects::Thread::sleep(unsigned int) + 59
3 com.adobe.flash.flbridge 0x253b1de3 ScObjects::BridgeTalkThread::run() + 163
4 com.adobe.flash.flbridge 0x253b7968 ScObjects::Thread::go(void*) + 168
5 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
6 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 32: com.apple.CFSocket.private
0 libSystem.B.dylib 0x9a22fac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x90a9fc53 __CFSocketManager + 1091
Thread 33:
Thread 34: Java: Thread-4
3 libjvm.dylib 0x4f3a7099 JVM_RaiseSignal + 387065
4 libjvm.dylib 0x4f1f4b9d JVM_Sleep + 254
5 libjvmlinkage.dylib 0x248dba68 JVM_Sleep + 72
6 ??? 0x5090b9d9 0 + 1351662041
9 ??? 0x50901374 0 + 1351619444
10 libjvm.dylib 0x4f1997ff JVM_Lseek + 162812
11 libjvm.dylib 0x4f199573 JVM_Lseek + 162160
12 libjvm.dylib 0x4f1a5a3d JVM_StartThread + 2922
13 libjvm.dylib 0x4f1a5931 JVM_StartThread + 2654
14 libjvm.dylib 0x4f1a58af JVM_StartThread + 2524
15 libjvm.dylib 0x4f1a5709 JVM_StartThread + 2102
16 libjvm.dylib 0x4f1a5547 JVM_StartThread + 1652
17 libjvm.dylib 0x4f10f4e0 jio_snprintf + 40015
18 libSystem.B.dylib 0x9a23e259 _pthread_start + 345
19 libSystem.B.dylib 0x9a23e0de thread_start + 34
Thread 35:
0 libSystem.B.dylib 0x9a236412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x9a2369a8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x9a2365c6 start_wqthread + 30
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xffffffff ebx: 0x22f545d4 ecx: 0x00000000 edx: 0x2795b13c
edi: 0x2a8ccf70 esi: 0xffffffff ebp: 0xbfffc7e8 esp: 0xbfffc7d0
ss: 0x0000001f efl: 0x00010286 eip: 0x22f50262 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0xffffffff
Binary Images:
0x1000 - 0x1a55feb +com.adobe.flash 11.5.1.349 (11.5.0) <DE07E6C7-786A-A7C8-1CF2-AE74F688B657> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
0x2db8000 - 0x2f32fe3 +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <04C90B5C-DC6D-A2B5-BE9B-193466222BE7> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x2fdb000 - 0x30a8fe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.5.101.12783 (3.5.101.12783) <117ACA20-072D-0AB2-CCB9-0385FF43CB14> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Ad obeAXEDOMCore
0x311a000 - 0x31abff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/lib icucnv.dylib.36.0
0x31ca000 - 0x3297ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUInternationalization.framework/Versi ons/3.6/libicui18n.dylib.36.0
0x32fa000 - 0x33d4fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libic uuc.dylib.36.0
0x3414000 - 0x3dc4fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicuda ta.dylib.36.0
0x3dc7000 - 0x3dd2ff3 +libChar16.dylib ??? (???) <758855AC-2E45-350B-D64E-39422835F760> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libChar16.dylib
0x3ddb000 - 0x3df4fe7 +libCoreTypes.dylib ??? (???) <4943E74A-FB75-ABB7-C34A-967920772CB4> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libCoreTypes.dylib
0x3e16000 - 0x3e25fef +ZLib.dylib ??? (???) /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/ZLib.dylib
0x3e2a000 - 0x4034fe7 com.apple.carbonframeworktemplate 1.0 (1.0) <FB292B4C-FDAC-2E77-7540-CE36B139C5E1> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
0x4372000 - 0x4376ff7 com.apple.JavaVM 13.6.0 (13.6.0) <AF1F7FCD-8FB4-CF43-5433-C98A0B58025B> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x437e000 - 0x5109fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
0x5eee000 - 0x5f32fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
0x5f95000 - 0x5fdbfff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterP ort
0x6050000 - 0x6050fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
0x6054000 - 0x6070ff9 +AdobePDFSettings ??? (???) /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/A dobePDFSettings
0x608a000 - 0x61c5ff2 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <5BD496D2-2E2B-0411-779F-855603C5B2AE> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x61ed000 - 0x66effef +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <7F6464ED-C80E-0267-A225-93B2BE537147> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x6834000 - 0x686ffff +com.adobe.ARE AdobeARE 1.5.02.12659 (1.5.02.12659) <639DF4B8-4D45-0517-4DED-D1CB1FC6EC12> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x6879000 - 0x6893fff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6A0E1ACF-23E8-B966-3B51-8F264E269469> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x689d000 - 0x68beff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <F9DA3036-401B-89A5-9512-B009D29A9B2F> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/Adob eBIBUtils
0x68cb000 - 0x6bbdff7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <0481471E-E075-0782-BA1C-C5A5E23C5565> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/Adob eCoolType
0x6c4a000 - 0x7023ff7 +com.adobe.MPS AdobeMPS 5.5.0.12659 (5.5.0.12659) <F15ACFDA-4804-A70B-CA40-13888F4B8A04> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x715a000 - 0x723dfef +com.adobe.PDFPort AdobePDFPort 2.1.0.12659 (2.1.0.12659) <EAF6E16F-E356-551A-0484-50141914178C> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/Adobe PDFPort
0x7275000 - 0x78aafeb +com.adobe.PDFL 9.9.0 (9.9.0.12659) <0C6CF147-E5A9-7C3F-A25C-CD096C910D4D> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDF L
0x79e0000 - 0x7a06ff6 +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.5.101.12783 (3.5.101.12783) <C7FD5306-E881-A19A-0F40-0E3844278526> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions /A/AdobeAXE8SharedExpat
0x7a19000 - 0x7a40fed +com.adobe.AXE16SharedExpat AdobeAXE16SharedExpat 3.5.101.12783 (3.5.101.12783) <13B60B50-7241-73D6-E551-6E2E3E0AD7ED> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Version s/A/AdobeAXE16SharedExpat
0x7a53000 - 0x7aabff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x7abb000 - 0x7b28fef +com.adobe.FileInfo.framework Adobe XMP FileInfo 5.2 -i 1 (debug) (61.141987) <ABF47D32-C58A-F9CE-E753-F0F906B13F7E> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x7b45000 - 0x7ce4fe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x7d4d000 - 0x8adefeb +com.adobe.psl AdobePSL 12.0.0.12659 (12.0.0.12659) <03D5B098-AD3C-FB84-0D0D-7DE57C025F3F> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x8e46000 - 0x902cff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Ad obeLinguistic
0x90ba000 - 0x90beffc +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A /AdobeCrashReporter
0x90c4000 - 0x9388ff3 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54BE6966-C47D-08E4-D08A-36B4949DE849> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x968d000 - 0x97e7fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <549A0950-E4E2-F867-2A0D-ABFC00A56E54> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x993d000 - 0x9c5efe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <3F958167-F680-C012-8CCA-424B65E75F9C> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadam eve
0xa124000 - 0xa192ffb +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0xa1a9000 - 0xa1ffffb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSess ion
0xa248000 - 0xa27dfef +com.adobe.pip ??? (5.5.0.1265) <660E209C-F595-AB0B-FB5E-C8FC1527CF4D> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
0xa288000 - 0xa3c0fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServi ces
0xa402000 - 0xa408ff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <615D7334-B103-3FE9-2150-1BA67D6B541F> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/bo ost_date_time
0xa419000 - 0xa424fff +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <84E8374D-5DB8-E2F5-8677-D9D715FC04CE> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/b oost_filesystem
0xa438000 - 0xa4b7fff +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <DA8506EE-FC4B-7FE3-0B8B-75889386B07C> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_ regex
0xa51b000 - 0xa525ffb +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <CFE6F1B2-7A2E-9D22-EE9F-267F765FE0F6> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boos t_signals
0xa538000 - 0xa53aff3 +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <084DB300-4206-FDCD-EC2F-1D54F0A13E1D> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost _system
0xa542000 - 0xa54affb +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <79DF91DA-997F-5806-D847-667A7AE3FE6A> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boos t_threads
0xa55a000 - 0xa6f7ff7 +com.adobe.AFlamingo AFlamingo 2.1.402.12783 (2.1.402.12783) <B34C21DA-5AF0-47BD-5375-375414ACC9CD> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflaming o
0xa8c6000 - 0xa8c9ffc +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0xa8d0000 - 0xa9e2ff7 +FlashIK Framework ??? (1.0) <8EB8A2F0-C7B0-63FC-28A0-D69E43B0AE92> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
0xaa74000 - 0xaabaff7 +PFF Framework ??? (1.0) <8256E961-D8D3-0515-5FB9-A75C1D440923> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
0xaae4000 - 0xb4e4fef +com.adobe.AFlame AFlame 1.1.5.12783 (1.1.5.12783) <842BEADF-C618-794C-DA88-3BE4C23A697F> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
0xb6b7000 - 0xb6e0ff3 +com.adobe.contextui.framework contextui version 5.0.0 (5.0.0.150919) <3D09FEF1-1029-490D-0B74-9E54098EF9E3> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/contextui.framework/Versions/A/contextu i
0xb71c000 - 0xb720ff7 JavaLaunching ??? (???) <3C53D78E-64EE-5147-0ECB-EC813B40D6EE> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/ JavaLaunching
0xb726000 - 0xb766ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0xb77f000 - 0xb834fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0xb87a000 - 0xb87dfe3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.150919) <318AE6D8-5D2E-B899-A4A9-40DBBED181BF> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvafl ashview
0xb8f6000 - 0xb8f7ff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xbbf0000 - 0xbbf8fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0xbf78000 - 0xbfe3fe7 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtser vices
0xed5b000 - 0xedcbfeb +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_c aps
0x10086000 - 0x100aafe7 GLRendererFloat ??? (???) <AD081A9B-1424-1F17-3C68-9803EBA37E8D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
0x100d2000 - 0x100d4ff7 +com.macromedia.Flash.FLfile 11.5.0.325 (11.5.0) <21E1B8AE-CB7E-7019-218F-A9AC206C88B5> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
0x100e1000 - 0x100e2ff7 ATSHI.dylib ??? (???) <F06AB560-C2AF-09F6-7328-773E43CA2713> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x100e7000 - 0x100f5fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0x10109000 - 0x10119ff3 +com.yourcompany.PointGrid ??? (1.0) <1572B151-C83B-B62E-A9C5-F741706082E5> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
0x1012f000 - 0x10141ff7 libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0x10145000 - 0x10149ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1014e000 - 0x10154ff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10159000 - 0x1015aff3 +com.macromedia.Flash.flastoragelib 9.0 (9.0) <841F9AEF-0220-C997-42CA-30BB849C5089> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLASto rageLib
0x1015f000 - 0x10173ff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x2292d000 - 0x22aa6ff7 GLEngine ??? (???) <64C74F67-44B5-7DEF-CCA6-C8A9FF9BB60A> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
0x22c86000 - 0x23678ff3 +com.macromedia.Flash Player.authplaylib 10.2.153.2 (10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlay Lib
0x23c72000 - 0x23c77ff7 libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libFontStreams.A .dylib
0x23fbe000 - 0x23fe7fef +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
0x23ff9000 - 0x24014ffb +com.adobe.adobe_oobe_launcher Adobe OOBE Launcher 2.0.0.36 (BuildVersion: 2.0; BuildDate: Mon Jan 24 2011 21:49:00) (2.0.0.36) <F7F307A6-C498-6939-4C70-105D4AE3B7AE> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/ A/adobe_oobe_launcher
0x24038000 - 0x24071ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 2.0.0.15 (2.0.0.15) <3A9CF871-6678-90BB-3770-CDBF56AF21D5> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions /A/UpdaterNotifications
0x248a9000 - 0x248ccfe7 +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <F2933B29-0CC1-00B4-1778-BF44110851F8> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
0x248da000 - 0x248e1ffb libjvmlinkage.dylib ??? (???) <40E32914-14BE-2928-DA0B-AE59EA90565A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libjvmlinkage.dylib
0x250d4000 - 0x250dbff7 libverify.dylib 1.0 (1.0) <139B0D99-83BA-17B5-F87E-7F4394A9721D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libverify.dylib
0x25140000 - 0x2515eff7 +com.adobe.flash.cs55.airAndroid 11.5.0.0 (11.5.0) <7BFBDD83-2B68-53BB-0E0D-43C105CB5719> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5_Android.bundle/Contents/MacOS/Air2_5_Android
0x25173000 - 0x25195ff7 +com.adobe.flash.cs55.air 11.5.0.0 (11.5.0) <1329BBFC-ED3D-C787-92B6-A63177C2552B> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5.bundle/Contents/MacOS/Air2_5
0x2526a000 - 0x25272ff7 JavaNativeFoundation ??? (???) <D913A75C-706D-9A4D-8C85-217150728CDE> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/Jav aNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x2527b000 - 0x25287ff7 libzip.jnilib ??? (???) <BCA39E98-9EE6-0ED6-C89C-8EF684787639> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libzip.jnilib
0x2530d000 - 0x25329ff7 libjava.jnilib ??? (???) <E6EDF6A8-3A41-2F7C-7FEF-97E06DC4A7E5> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries /libjava.jnilib
0x25396000 - 0x253d7ff3 +com.adobe.flash.flbridge 11.5.0.325 (11.5.0) <72AC5C1A-8338-C772-EF75-D30229D44F9C> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
0x26947000 - 0x269acfe7 +com.yourcompany.Brush ??? (1.0) <514A0F0D-DA07-9F32-B3A8-A1F1C12BF0E3> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
0x26c4e000 - 0x26cd7ff7 +com.yourcompany.Collision ??? (1.0) <F7BEA1C6-99F5-FBA8-F960-20F7DC0CE06F> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
0x40000000 - 0x400d1fe7 +com.adobe.JP2K 2.0.0 (2.0.0.12659) <88D70F2A-FFBA-EEB2-123D-42F4EB7CF4E3> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2 K
0x4b800000 - 0x4b915fff +com.yourcompany.Stroke ??? (1.0) <2DCF3D57-AEF2-C4EB-8677-135673A4BE47> /Applications/CS55/Adobe Flash CS5.5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
0x4f100000 - 0x4f463ff7 libjvm.dylib ??? (???) <17C6BF39-5F82-97C0-38D3-0D469F5F825F> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bund le/Libraries/libjvm.dylib
0x8f5b9000 - 0x8fa8efef com.apple.GeForce7xxxGLDriver 1.6.36 (6.3.6) <357D71A1-991B-5538-8A92-B4BB89097A97> /System/Library/Extensions/GeForce7xxxGLDriver.bundle/Contents/MacOS/ GeForce7xxxGLDriver
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
0x9003c000 - 0x90046fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x90080000 - 0x900a6ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x900a7000 - 0x900a7ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x900a8000 - 0x90109fe7 com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x9010a000 - 0x901a5fe7 com.apple.ApplicationServices.ATS 275.19 (???) <9FA31967-CF14-B033-EB8D-570561D12A13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x901a6000 - 0x9025efeb libFontParser.dylib ??? (???) <D57D3834-9395-FD58-092A-49B3708E8C89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9025f000 - 0x9026aff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x902f7000 - 0x9035bffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x9035c000 - 0x90386ff7 com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x90603000 - 0x9082eff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x9082f000 - 0x908ccfe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x908cd000 - 0x90965fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90966000 - 0x90a22fff com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x90a23000 - 0x90b9efe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x90b9f000 - 0x90bd2fff libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x90bd3000 - 0x9108eff7 com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
0x9108f000 - 0x91096ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x91097000 - 0x910b2ff7 libPng.dylib ??? (???) <25DF2360-BFD3-0165-51AC-0BDAF7899DEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x910e1000 - 0x9113bfe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
0x9133f000 - 0x9146cffb com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
0x9146d000 - 0x9178dff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x9178e000 - 0x9179fff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91915000 - 0x9195bff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x9195c000 - 0x91a9ffef com.apple.QTKit 7.7 (1787) <3B47A1A0-7AB5-C1C9-42DE-5993D1012D47> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91aa0000 - 0x91e0bff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91e0c000 - 0x9207dfef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9207e000 - 0x9208cff7 com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9208d000 - 0x9208dff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x9208e000 - 0x921cbfe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x922be000 - 0x926f3ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x92707000 - 0x92a01fef com.apple.QuickTime 7.6.6 (1787) <AC48EAD9-7201-7CE6-C826-41B12963FECF> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92a02000 - 0x92a03ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92a04000 - 0x92ab2ff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x92b54000 - 0x92b54ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x92b55000 - 0x92b5aff7 com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x92b5b000 - 0x9343eff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9343f000 - 0x935c1fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
0x937a6000 - 0x938a8fef com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
0x938a9000 - 0x938affff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x938ec000 - 0x938f6ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x938f7000 - 0x938fbff7 libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x938fc000 - 0x9393fff7 libGLU.dylib ??? (???) <FB26DD53-03F4-A7D7-8804-EBC5B3B37FA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x93940000 - 0x939aeff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
0x939af000 - 0x93ab0fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
0x93ab1000 - 0x93b31feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x93b32000 - 0x93b42ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x93b43000 - 0x93c69fe7 com.apple.WebKit 6534.52 (6534.52.7) <A2FC4307-01BE-DC9E-82FE-68B13F3839A9> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x93c9e000 - 0x93ca1ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x93caa000 - 0x93cadff7 libCoreVMClient.dylib ??? (???) <F58BDFC1-7408-53C8-0B08-48BA2F25CA43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x93cae000 - 0x93dbaff7 libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x93dbb000 - 0x93ddbfe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
0x93ddc000 - 0x93de4ff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
0x93de5000 - 0x94236fef com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x94237000 - 0x94280fe7 libTIFF.dylib ??? (???) <579DC328-567D-A74C-4BCE-1D1C729E3F6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94489000 - 0x94489ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x9448a000 - 0x944e0ff7 com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x94500000 - 0x945b9fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x946a9000 - 0x946a9ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x946aa000 - 0x9478afe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x9478b000 - 0x94856fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x94857000 - 0x9489bff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9489c000 - 0x94990ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
0x94991000 - 0x9499cff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94a7b000 - 0x94ae5fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x94ae6000 - 0x94b0eff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
0x94b0f000 - 0x94cd1feb com.apple.ImageIO.framework 3.0.4 (3.0.4) <027F55DF-7E4E-2310-1536-3F470CB8847B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x94cd2000 - 0x94d03ff7 libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x94d04000 - 0x94d06ff7 libRadiance.dylib ??? (???) <5920EB69-8D7F-5EFD-70AD-590FCB5C9E6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94d07000 - 0x94d4bfe7 com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x94d4c000 - 0x94d64ff7 com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94d65000 - 0x94d69ff7 IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x94d94000 - 0x94dd2ff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x94dd3000 - 0x94dd4ff7 com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x94e74000 - 0x94e75ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
0x94e76000 - 0x94eb7ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94eb8000 - 0x94fe6fe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94fe7000 - 0x95231fef com.apple.JavaScriptCore 6534.52 (6534.52.7) <AF71FCC7-B8BF-2DA6-C538-6B7C47F95B2D> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x95232000 - 0x95232ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95233000 - 0x952aefff com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
0x952af000 - 0x952c3ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x952e9000 - 0x9531cff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x95434000 - 0x95464ff7 com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
0x95698000 - 0x9569fff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x956a0000 - 0x957a2fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x957a8000 - 0x957efffb com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
0x957f0000 - 0x957fefe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
0x957ff000 - 0x95802fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x95803000 - 0x95813ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x95814000 - 0x95856ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <29E5ABCF-6D8A-0CE0-B480-C7D240FF8575> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x95ed3000 - 0x95f65fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x95f9f000 - 0x95fa1ff7 com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x95fa2000 - 0x95fabff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x95fac000 - 0x95facff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x95fce000 - 0x96050ffb SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x96051000 - 0x960fefe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x960ff000 - 0x96364feb com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x96365000 - 0x96387fef com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x963fd000 - 0x965dffff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
0x965e0000 - 0x96dcf557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x96e4a000 - 0x97028feb libType1Scaler.dylib ??? (???) <59FE1036-1BC2-1A8E-F7C6-E0CC15A4D6D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x9702a000 - 0x97051ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
0x97052000 - 0x97064ff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x97065000 - 0x97072ff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x97073000 - 0x97397fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x97398000 - 0x973f5ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x973f6000 - 0x974a2fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x974a3000 - 0x974afff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x974e3000 - 0x974edff7 com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x97519000 - 0x9792fff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x979ba000 - 0x979dbfe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x979dc000 - 0x97a55ff7 com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
0x97a78000 - 0x97aaefff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x97aaf000 - 0x97aecff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x97b74000 - 0x97beefff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97bef000 - 0x97c97ffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x97c98000 - 0x97ce5feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x97ce6000 - 0x97d29ff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x97d2a000 - 0x97d3ffff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x97d40000 - 0x97d54fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x97d61000 - 0x97db4ff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x9814f000 - 0x981beff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <706684C7-AFA0-B036-274A-D02F8961DED5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x981bf000 - 0x98f27fe7 com.apple.WebCore 6534.52 (6534.52.11) <28DB69F5-ACE5-2A67-4DC1-39EED479B56B> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/Web Core.framework/Versions/A/WebCore
0x98f28000 - 0x98f80fe7 com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x98f9a000 - 0x98f9dffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x98f9e000 - 0x98fbafe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x98fbb000 - 0x98fbfff7 libGIF.dylib ??? (???) <2123645B-AC89-C4E2-8757-85834CAE3DD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x99f16000 - 0x99f16ff7 com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x99f17000 - 0x99f36ff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x99f37000 - 0x99f71ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <038731B1-CC44-3943-E3DE-4BAAA203EB72> /usr/lib/libcups.2.dylib
0x99f79000 - 0x99fc9ff7 com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x99ff1000 - 0x9a02eff7 com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
0x9a03d000 - 0x9a061ff7 libJPEG.dylib ??? (???) <EA97DEC5-6E16-B51C-BF55-F6E8D23526AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9a062000 - 0x9a068fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9a069000 - 0x9a0a4feb libFontRegistry.dylib ??? (???) <AD45365E-A3EA-62B8-A288-1E13DBA22B1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9a0a5000 - 0x9a17ffff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x9a1c9000 - 0x9a1c9ff7 com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9a1ca000 - 0x9a20fff7 com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
0x9a210000 - 0x9a3b7ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/CS55/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba916ff7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7 libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: MacPro1,1, BootROM MP11.005D.B00, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 6 GB, SMC 1.7f10
Graphics: NVIDIA GeForce 7300 GT, NVIDIA GeForce 7300 GT, PCIe, 256 MB
Memory Module: global_name
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
PCI Card: NVIDIA GeForce 7300 GT, sppci_displaycontroller, Slot-1
Serial ATA Device: WDC WD2500JS-41SGB0, 232.89 GB
Parallel ATA Device: SONY DVD RW DW-D150A
USB Device: iPhone, 0x05ac (Apple Inc.), 0x1294, 0xfd100000 / 2
USB Device: PTZ-631W, 0x056a (WACOM Co., Ltd.), 0x00b5, 0x3d100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8206, 0x5d200000 / 3
USB Device: Logitech USB Headset, 0x046d (Logitech Inc.), 0x0a01, 0x5d100000 / 2
FireWire Device: built-in_hub, Up to 800 Mb/sec
