How can I make sure a bezier control point remains at the same angle with it's anchor while dragging it to a different length?
It's not complicated and seems so fundamentally necessary I can't believe there isn't an easy way to do this in AI. In Fontlab Studio and Fontographer, option-dragging a control point maintains the angle. For the first time, I have AI available and wanted to create the vector paths for my font's glyphs in AI and copy them over since the tools are mostly better.
I simply want to move any particular bezier control point nearer to, or farther from it's anchor without changing the angle of the line between the two. i.e. change the pull on the adjacent curve without changing the direction of the pull
I tried what Monika suggested, with the scale tool. Holding shift while scaling does maintain the angles of the control points because scaling is the same in both directions, but on the downside, both bezier controls are always scaled, and I rarely want to scale both at once.
Metacarpal,
Now that I finally get it (I hope), you may try this silly way, using Smart Guides which will tell you what you need to know:
1) Direct Select the Anchor Point,
2) Switch to the Line Tool and drag with it from the Handle to the Anchor Point (not the reverse, you will know why if you try),
3) Switch back to the Direct Selection Tool and click the original path to get the Anchor Point and Handle(s) visible,
4) Drag the desired handle along the Line Segment,
5) Delete the Line Segment.
In step 2) the anchor and handle disappear as soon as I click with the line segment tool, of course, so I don't necessarily know where the anchor was, to drag to it. When I want to reselect the anchor in step 3), it may not be possible with the new line segment anchor sitting on top of it.
If you're designing a font in Illustrator, you really ought to look (as Monika suggested in the very first reply) at the plug-in VectorScribe. Its PathScribe tool lets you extend/retract a handle without changing its angle (with Option, as you are used to), as well as other niceties for font design like numerical handle positioning, moving anchor points to their nearest tangencies, and Smart Removing anchor points. It's by Astute Graphics.
DF
I agree with that VectorScribe is good at manipulating anchors point & handles in decents ways. Sad all this is notbuild in Illustrator!
You can watch some video here: http://bit.ly/VS-Movies
Metacarpal,
When you drag from the Handle, which has just disappeared, in the direction you have just seen and follow/probe the original path, Smart Guides will say anchor point when you are there.
I apologize for my being too curt, at least in 3), here is an amended version:
3) Switch back to the Direct Selection Tool and click the adjacent segment (beside the Line Segment) of the original path to get the Anchor Point and Handle(s) visible,
Obviously, any improvement in the tooling, or the use of (more or less costly) plugins, would ease the way, but some of us still prefer the challenge of limping along with Illy and a few free additions.
At least here it is true that what does not kill you makes you stronger.
I'm not a 100% sure what you mean.
Lets say you have a line which is tilted 26,85 degrees. You want to resize this line to make it longer at either direction but still maintain the exact angle. If you use the selection too to resize it, you can just hold down the SHIFT key and it will be resized at the same angle. But maybe this is not what you're looking for ![]()
