I have a query that is going to run many, many times per day, potentially hundreds of thousands so I want to make sure it's as quick as possible
The purpose is to take a compiled IP number, look it up and relate it back to the country based on data in the table for current IP/countries
There are currently 113,536 records in the country table, It's typically taking around 4ms to 5ms, so it's not exactly slow, but as the use of this particular lookup is going to increase significantly I'd like to make sure I have it as fast as possible.
Here's the current code:
<CFSET ipnumber = (#listgetat(remote_addr,1,'.')# *256*256*256) + (#listgetat(remote_addr,2,'.')# *256*256) + (#listgetat(remote_addr,3,'.')# *256) + #listgetat(remote_addr,4,'.')#>
<CFQUERY name="GetCountry" DATASOURCE="#datasource#">
SELECT TOP 1(countryshort) as countryshort
FROM #ipcountry#
WHERE ipfrom <= #ipnumber# and ipto >= #ipnumber#
</CFQUERY>
The first thought is to try to create a stored proc to see if that generates any performance gain, I've search and read over several documents on setting one up, but I have to admit, I just can't quite grasp it.
I'm wondering if anybody would be kind enough to stick this query into a stored proc for me and let me know what CF code I need to execute it and read the result.
Once I see this done I am sure I'll be able to push forward from there on my own in the future ![]()
Mark
Do you think you could show me how this would look in the stored Proc? I think I could figure out the CF side, it's the SQL stored Proc part that's really getting me ![]()
Btw countryshort is a char(2) and ipfrom and ipto are both big integers
FROM #ipcountry#
</CFQUERY>
Mark
CREATE PROCEDURE yourSpName
@ipnumber BIGINT
AS
BEGIN
DECLARE @sql NVARCHAR(MAX)
SET @sql = N'
FROM ipCountryTable
WHERE ipfrom BETWEEN @ipnumber AND @ipnumber -- Not sure why you are using a range here
EXEC sp_executesql @sql,
N'@ipnumber BIGINT',
@ipnumber
END
I'm not great with stored procedures either, but I think this should help you. SQL Server should be able to get you started as well with creating the procedure. Just make sure you create the procedure within the databse where your IP table is located.
But for the future, this should really have been asked in a SQL Server forum. http://social.msdn.microsoft.com/Forums/en/category/sqlserver
Hi HiTopp
Thanks for the feedback, I'll definitely connect with the SQL forum :)
There are two columns in the table and I need to find the number I have as to where it fits in
1000,2000
2001,3000
etc
so if I have 2500 it is in the 2nd row
Looks like you missed off the ipto >= bit :)
FROM #ipcountry#
</CFQUERY>
Bear in mind that database servers, such as Microsoft SQL Server, will cache the execution plan for parameterized SQL queries which will result in performance gains similar to use of a stored procedure.
You might try using CFQUERYPARAM in your queries. This is also recommended to help prevent SQL injection attacks.
You might also create indexes on the ipfrom column on your table.
ACS LLC wrote:
The logic does not seem to be correct
You have:
I have:
I am looking for a result where ipFROM <= and another column ipTO >=
Bt your statement is just using ipfrom
My mistake. I misread your query. I did not realize you were specifying two different table columns.
ACS LLC wrote:
Sorry for my ignorance on this but how do you define a parameterized SQL Query?
A parameterized query uses bound parameters. In ColdFusion one uses cfqueryparam to add bound parameters.
For example (this assumes that the ipfrom column is a bigint column):
<cfquery name="countryLookup">
SELECT country
FROM ipcountry
WHERE ipfrom <= <cfqueryparam value="#ipnumber#" cfsqltype="cf_sql_integer">
AND ipto >= <cfqueryparam value="#ipnumber#" cfsqltype="cf_sql_integer">;
</cfquery>
References:
CFQUERYPARAM
http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461 172e0811cbec22c24-7f6f.html
Message was edited by: JR \"Bob\" Dobbs Corrected typo in cfqueryparam tags.
Agreed. Just wrapping a query in a stored procedures does not mean it is going to run faster. Look at the table's indexes and examine the execution plan to see how it can be improved. And you really should be using cfqueryparam in all of your queries. Not just for performance, but because you are risking sql injection attacks without it.
Since the table name is hard coded, there really is not a need for dynamic sql in this query.
Message was edited by: -==cfSearching==-
So you're saying that by using the cfqueryparam that the execution will actually be faster?
(Btw Yes it's a bigint, so I presume all cfsqltype are integer if it's tinyint, int, bigint)
SELECT country
FROM ipcountry
</cfquery>
btw Is a query like this as quick as a stored proc? Is there any performance benefit to the stored proc over this approach?
Yes it's a bigint, I presume all cfsqltype are integer if it's tinyint, int, bigint
No, each has a different capacity, which is why they are assigned different cfsqltypes. Refer to the documentation for cfqueryparam linked above.
Bind parameters encourage databases to cache the query execution plan to enhance performance when the same statement is executed multiple times. But many factors affect execution and performance. There is no one-size-fits-all answer. You need to use the available SQL query tools and examine the actual execution plans for your queries yourself.
ahhh ok, JR "Bob" had mentioned, that the command presumed it was a bigint which through me because the type in the example was cf_sqp_integer
So what I actually need is
SELECT country
FROM ipcountry
WHERE ipfrom <= <cfqueryparam value="#ipnumber#" cfsqltype="CF_SQL_BIGINT">
AND ipto >= <cfqueryparam value="#ipnumber#" cfsqltype="CF_SQL_BIGINT">;
</cfquery>
Do you believe that there are cases where the same CFquery which is bound correctly vs a stored proc could give different performance results? Differences that are worth actually bothering about?
The performance benfits of using stored procs come from the database server re-using the same execution plan. Execution plans can also be re-used for SQL statements with bound parameters, so the performance benefits *should* be about the same. You would need to use your database's performance monitoring tools to test this assumption. Not all database systems act the same in how they optomize queries.
I also agree with cfsearching's statement that there is no single right solution to improving query performance. That being said; I *suspect* that creating an index on the columns used in your WHERE clause will be more beneficial than creating a stored proc. I encourage you to investigate the performance monitoring tools available for your database product. Forum users don't have access to your organization's database so any advise we give is limited.
I placed the same code, one with my old SQL the other with a the CFQUERYPARAM and ran repeated tests, now it might not be a great tests because it's just me repeating it rather than a request for different data, the results were 3ms now and again, some 5ms and mainly 4ms response on both, didn't really notice any difference, of course on such a fast query unless it's under a ton of load with many requests for different responses I guess that I won't know for sure.
Execution time alone is not a good measurement. Like I mentioned earlier, you must examine the execution plan. Look at how the statement is processed. Does it result in a table scan? Or does it utilize indexes? Does it peform an index scan or seek? Etecetera. That is one of the best tools in your arsenal for guaging performance (which you seem to be avoiding *hint*, *hint*).
For such a simple query, agreed. But do not just guess. Use your query tools to examine the plans and create an effective index.
I am the first to admit that I am no SQL Guru, I know enough to get things functioning with no issues. Right now I just add an index and go with default values, I see you can change the order and maybe other parameters. Is default setting not enough? Appreciate any pointers on this one ![]()
Mark
Lol, I have no idea. The "best settings" will vary based on your application, data and queries. You are the only one that has access to
them. So only you can determine if the settings have the desired effect.
You have to dig in and start looking at the execution plans. There is a
lot to digest, and they take a while to fully understand. But that is
the only way to examine the efficiency of your sql, determine if
indexes are utilized, compare performance, etcetera.
http://msdn.microsoft.com/en-us/library/ms189562%28v=SQL.90%29.aspx
http://msdn.microsoft.com/en-us/library/ms178071.aspx
http://www.simple-talk.com/sql/performance/execution-plan-basics/
Sorry, but sometimes the truth hurts ;-) Honestly, I do not always relish pouring over thick tomes of documentation myself. But it has to be done because general advice can only carry me so far. Ultimately, I am the one responsible for coding and maintaining my applications. Since there is no learning by osmosis (though sometimes I wish there were ;-) some things I just have to learn by reading and doing myself. It is just part of the job.
