Mag_74 wrote:
I installed a big update from Nvidia ( 130 Mb ) in windows update. After that it´s working smooth again. Before I was just like many above has explained.
Graphics card drivers are a notorious cause of all sorts of problems. And LR has suffered a lot over the years from old drivers. You can register on the nVidia site to be notified by email every time there is a new update. Win update doesn't always seem to notice them.
Since I don't play games, I only install the basic driver, not the 3D this, that, and the other. The less you have to go wrong, the fewer problems you will get!
Bob Frost
Michel_13 wrote:
Curious thing that even LR3 was a little bit slower from time I installed LR4 beta, replaced now with released LR4.
One of the things that both LR3 and LR4 share is the acr cache, which stores the part-rendered .dat files (for raw files) to speed up going to 1:1 views. I've always been suspicious as to how well they do this sharing, and I would suggest deleting the acr cache (Preferences/filehandling/purge cache) and letting LR4 build a new one without LR3 interfering with it. See if that helps.
Bob Frost
Bob, thanks for your advice, I will try this and see what happen. Another thing I'm trying is to install LR4 alone on another system, with no LR installation at all, to avoid some shared files with LR3 ? This should give the right information if no improvment, where to look : propably graphic driver.
Too many people are just posting the specifications of their PC's/MACS. Anyone with an ounce of common sense can tell from reading this forum that LR4 is running slower than it should and that Adobe are looking in to it.
It doesnt matter if you have 10 "Top of the line" SSD's or a dozen core processor with 64GIG of RAM or the NASA space station. Use LR3 in the mean time, afterall 2 weeks ago thats the only option you ever had!
I can assure everyone that LR4 is leaps and bounds above LR3.X for RAW editing.
No it isn't. Lightroom 4 isn't running slower than it should - for many, many people. It runs slower for some and this apparently does not depend on hardware spec, but more likely on difficult to track down system configuration or driver specialities. There are bugs in Lightroom, bugs in drivers, and some hardware components may not play nicely together, when Lightroom 4 runs.
I too was experiencing extremely sluggish performance. I had 147,000 images in my catalog from LR 3.6. I did have the beta installed and when I installed the final release version of LR 4, I just upgraded my original LR 3 catalog to the new version. After some frustration experiencing slow everything including switching between modules, adding labels and flags, adjustment brush slowness, metadata updating, aquiring thumbnail previews, etc.; I decided to create a brand new catalog, then did a File> "Import from another catalog..." and imported from the catalog that was originally converted from LR3>LR4 and things are way better now. Everything now seems as snappy or snappier than before running LR 3.6. All of my metadata, flags, labels, develop history remained intact. Granted it did take several hours to import that many files but it seems much better now. Not sure if this will help anyone else out, but maybe worth a try for those that are at their wits end on this. I'm running an iMac Core 2 Duo 2.4 GHz, 6 GB Ram, OS X 10.7.3 if anyone cares or needs this info.
I haven't imported any old catalogs yet from LR 3.6. I'm running OS X 10.7.3 on a quad-core i7 machine with 16GB of RAM and an Intel HD Graphics 3000 graphics card. Painting with brushes and moving sliders is incredibly slow, especially painting with brushes. There is also a problem when using my Wacom Intuos 4 tablet and trying to pan around in an image with the grabber hand: the image will not stop moving after I put down the pen (it will keep moving in the last direction I pushed for at least another couple of seconds). But painting with brushes...wow, it's like a throw-back to Aperture 2, only worse.
I followed suit and upgraded my NVIDIA win-64 drivers moving from 280.26 to 296.10. They can sure release a lot of updates in 6 months. Like other posters, I don't play games so usually don't screw with what works and LR3 and Adobe CS5.5 have had no video issues. Following the driver update, performance in all regards, returned to near typical LR3 levels. But I am not sure that Video drivers was the true cause of trouble.
I later realized while upgrading my 2nd Catalog and renaming it that I had forgotten to rename the origional upgraded Catalog properly (I had failed to rename the 11GB preview cache). Of course LR4 built a new cache without any indication that it was doing so and I suspect that is what I was fighting while perfomance was so sluggish. I properly renamed the 2nd converted Catalog (containing 47,727 RAW Nikon Images) and performance remains smooth - almost as smooth at 3.6 (moving between modules remains slower than I am accustomed to but no more show stopping slider and cropping issues.
No way for me to be sure if any of the above truly addressed the problem and I am avoiding the import module untiI I get a few backlogged projects out the door but perhaps my experince and mistakes may help someone.
I've been reading around on this topic, because it seems the higher end your machine, the laggier LR4 becomes. I was using it on a 2011 Mac Mini with a dual-core i5, and I thought it was downright snappy. I see lot's of people that are complaining running quad core processors. Is there any chance this has something to do with the way kernel task scheduler is managing the threads for LR4? some kind of race condition or looping that causes a very inefficient processor that works fine on a dual-core machine but comes out on a quad?
I'm finding LR4 is running reasonably well, compared to LR3. However, is it just me that's finding 'waking-up' the sliders a problem?
For those of us who remember up-grading from LR2 to LR3 (at least I think it was that up-grade?), one of the things we had to contend with was re-educating ourselves to 'wheel-click' the slider triangle (or whatever we are supposed to call them) to activate it. I now can't quite remember how it worked in LR2 - I think that by just hovering over the slider (or triangle) it became active if you wanted to simply roll the mouse wheel to make adjustments. Nevertheless, I'm now finding with LR4 that wheel clicking on the slider triangle is hit and miss (more misses than hits). Time and time again, I'm finding that I'm accidentally scrolling up or down the right hand panel. So, I'm now having to re-educate my brain to left click on the triangle before moving my finger to the wheel to begin any adjustments.
I know it's only a matter of an additional move of my finger of about 10mm and takes a fraction of a second, but it's disproportionately frustrating. I hope there is a fix that will come bundled with other 'responsiveness' fixes in due course.
Otherwise, I still remain a huge fan of Lightroom.
I was also experiencing unusable slowness in both the beta and final LR4. After the following tweaks, it's at least as snappy as LR 3, and a bit faster in several areas. First my computer specs.
AMD Phenom II X4 965 processor
8 gigs of ram
5600 RPM 1TB drive
Windows 7 64bit
Here are the things I did to my system to speed it up.
1. Add exclusions to my antivirus real time scan for *.lrcat, *.lrdata, and the location of the directory that holds all my catalogs. The steps vary between antivirus vendors, so check yours for specific steps. The idea here is that your AV is not reading every write Lightroom makes to scan for viruses. This speeds up disk IO in Lightroom quite a bit since there's not another program accessing the files at the same time.
2. Disable windows indexing down your Lightroom catalog tree. You can do this by right clicking on your main catalog folder, and then properties. Under attributes, hit the Advanced button. Uncheck the box for "Allow files in this folder to have contents indexed in addition to file properties". Hit the OK button. On the folder properties panel, hit the OK button again. A Confirm attributes dialog will pop up, Make sure it's asking to disable indexing, and the "Apply changes to this folder, subfolders, and files" radio button is selected. Then hit the OK button. It'll take a bit to process for large catalogs. The idea here is the same as the previous tip. You really don't want anything accessing your catalogs while Lightroom is trying to read/write them.
3. For desktop computers, disable CPU power throttling and hard disk sleep. For laptops, it can shorten your battery time when you're unplugged, and it's up to you if you want to make that tradeoff. You can always switch between profiles too. In the "Power Options" control panel, click on the create power plan link on the left hand side of the pane. Pick the High performance radio button. Name the plan whatever you like. Hit the Next button. Make sure the turn off display and put the computer to sleep dropdowns are set to Never. Hit the Create button. Now on the Power Options control panel, hit the Change plan settings on the right side of the new profile you just created. Then hit the Change advanced power settings. Hit the Hard disk twistie to open it, and then open the Turn off hard disk after twistie. Click on the blue part of the Setting: under the "turn off hard disk after" twistie. Set it to 0. That disables the hard disk sleep. Hit the OK button. Then on the Edit Plan Settings window, hit Cancel. (kind of counterintuitive, but it saved the hard drive setting. Make sure your new plan is selected in the Power Options control panel, and close that window. This ensures your system always has 100% cpu resources, and the hard drive never shuts down. The default usually slows down the CPU to save energy when the computer is idle. However, there's a ramp-up delay that can cause things like sluggish sliders in lightroom. You also don't want to be waiting for your hard disk to spin up if it goes to sleep.
4. When you start Lightroom, It's CPU usage at normal priority seems very conservative. Anything else that wants CPU time gets it, interfering with Lightroom. You can fix this by starting Lightroom, and then hitting control-alt-delete, and opening "Start Task Manager", Go to the processes tab, and click on the "Image Name" heading to sort the list alphabetically. Then find lightroom.exe, and right click on it and select Set CPU Priority in the popup menu. Then select either "Above Normal", or "High". Either one should work, but I use High. At this point Lightroom should be very responsive. The only problem with this step is you need to do it every time Lightroom starts. There is a way to save the priority however. I found a neat program called Prio Priority Saver. Google it. Once installed, it will save your priority choice you make in the above task manager step. I'm sure there are others as well. Prio is free for personal use, and $20 for your business.
I hope these tips help you, but as always; "your mileage may vary" These steps are what got me to the point where Lightroom 4 became fun again. The next thing I plan on doing is getting a SATA3 SSD to run my current catalog on, archiving to the 1TB drive whenever I switch catalogs. That'll remove any disk lag I've got from my slow slow hard drive.
Good luck!
I am finding version 4 to be very slow also, I'm hoping building 1:1 previews of my entire library (doing it now, will take a few hours I'd imagine) will help out. If it does I'll report back.
My LR4 system is an early 2011 Macbook Pro with 8GB RAM and quad 2.4GHz i5. Every other CS5.5 piece of software runs silky smooth, just Lightroom being a problem child. I am hoping the preview build will help, otherwise I'm stuck with a combination of Finder and Photoshop. ![]()
I think Subdood has found part of the problem... disk access. All the
posts talk of systems with real fast processors, lots of memory.. but no
comments about the disks. I compared disk access between LR 3.6 and
LR4.0 and found that LR4 really pounds the disk for every import, slider
move, etc. when compared to LR3.6
Doing what Subdood says does reduce the disk access and improves
performance... but the real question is why does LR4 thrash the disk?
I know ADOBE is working on this but this may be a area they may want to
investigate.
Well, before I did the tweaks I did, it was hitting the disk hard every slider movement. Now it seems to be less severe. I think it is indeed updating the database real time, and if you know SQLite, you know it's not exactly the highest performing SQL engine out there. It is however, free, and available for every platform, and easy to manage with automation. It's the lowest common denominator.
It seems it's updating the database every single action that generates an event in the history. What they could do, is cache the updates to ram, and flush them either when the user is idle, or at regular intervals. It seems like Lightroom 3 did that to me. There's a performance issue there that I'm sure Adobe will find and resolve, but I'm 90% of the way towards being 100% happy with Lightroom 4 after futzing some more performance out of Windows.
the same thought I had, I can't image Adobe would design it to write to the HDD ith every single slider movement. It's not causing me any trouble, but if it is set up that way it would seem a performance gain could be realized by caching to ram
My files and catalogs are on external HD's BUT they are USB 3.0. Access on the sliders is fast IF the second monitor is off. My issue seems to be with the video draw to the second monitor. I have an i7 running Win 7 Pro, with 12 gigs ram, and an nVidia GTX 260 with 2 gig RAM. The latest drivers as of today are loaded. The slider slow down on my setup only occurs with the second monitor enabled. With the second monitor off, the slider is almost instaneous. With it on, a 1 - 2 second delay, especially on the new sliders... I am using LR4 (as opposed to LR3 - had same setup on LR3 with no issues) The intesting part is that it doesnt matter if I am using process 2010 or 2012, the deciding issue in LR4 (for me) is if the twin monitors are on. One monitor and the speed is fine. Everything thing else, including all the plug-insn(OnOne, Nik, Alienskin) all work fine.
I just completed an intense seesion of keywording, metadata entry, and cataloging of MOV files in LR4.
I was expecting the work to translate to all products in the CS line. To my chagrin, none of the work transfers into Bridge, OnLocation, or Premiere, we just expected that keywording and metadata entry would be consistent throughout the line. Consistency in the handling and displaying of metadata (along with severe slowness issues) across the CS line needs to be addressed.
Back to square one on this task.... On the plus side, at least we caught this pitfall in the first week rather than at the end of a cataloging marathon. I dislike complaining...However, you should know that trusting Adobe and LR4 just cost me four days of my time/labor and several hundred dollars in (wo)man hours. Testing the metadata fields (between software you intend to use for handling your files) early in the game; This is the unfortunate lesson of the day.
Agreed. I've just done a lot of expts and the second monitor is the critical
thing. I can have noise adjustment, lens profiles, chromatic abberation etc
all on and working fine, UNTIL I say show the second monitor and then the
slider response almost stops - only works in jerks after a second or two.
Win7x64
Bob Frost
Any readers using two monitors where it's slow with the second, what type
card are you using?
I noticed BoHandsome and I are both using GTX260 NVidia cards. Mine was a
special that came from Dell with 2 gigs onboard.
Mmm. Mine is a nVidia too - GTx460. I don't have any ATI cards to swap it
out.
Bob Frost
Hi Bob,
I'm experiancing the same high CPU usage when I have 2nd monitor active too.
WorkStation
Actions completed to date
Sumamry
I'm sure the actions I have performed have made some fine-tuned improvments. The main issue is still the CPU usage with the secondary monitor active and I'm still getting delayed responce on occasions when sliding development settings. These are worse when 2nd Monitor is enabled. This was never the case in Lightroom 3.6 and I can hear my CPU fan going mental for the first time. Lets hope 4.1 is arround the corner to address this issue.
Nvidia GTX560TI 2048MB Graphics Card.
I also experience very slow performance when using two monitors. Are there
any AMD users using two monitors to give some feedback?
Just ordered an ATI card, so I'll be able to test this theory tomorrow!
Bob Frost
try this; backup all the lightroom (v.3 and v.4) preferences file ("ligthroom 3 preferences.agprefs" or "ligthroom 4 preferences.agprefs"), then delete ALL the preferences files, let lightroom create new preferences file when it starts. O ya start lightroom 4 first, let lightroom 4 create fresh preferences file not imported from lightroom 3 preferences file.
Good luck
Adobe has a good doc on optimizing LR here
http://kb2.adobe.com/cps/400/kb400808.html
Things like upping the CR cache can make a big difference (up to 20gb or so if you can). LR4 can definitely run very fast.
