I had really hoped that enough people complained about the interface design. Specifically the small dark fonts on a dark grey background. I find it nearly unusable. I just downloaded the trial of LR4 with hopes that they had addressed this issue. I guess they didn't get enough negative feedback. I really hate it. It seems that it wouldn't take that much in the way of coding to give us an option to change the font color.
This was one of the reasons I didn't upgrade to v3. I must say I'm really disappointed.
The font colors occasionally get complaints. Since the contrast is quite substantial and the fonts easy to read, I'm guessing the root cause of much of this is monitors that are either too bright, have the black point too bright, or some combination.
Have a look here for a quick way to see if that might be your issue.
http://www.normankoren.com/makingfineprints1A.html#gammachart
One Horse wrote:
I can always count on a helpfull reply from you Jeff. Thanks.
You're welcome...note your complaint is coming about 6 years too late. And also note the way the LR UI changed the industry. Seen Capture One? Dark UI. Seen the sneeks of Photoshop CS6? Dark UI. It has set the trend...you may not like it, but it's not gonna change.
I find the dark over-crowded interface with small panels and illegible type totally unusable too.
I downloaded the 30-day Free Trial but I will not be buying LR4.
It surely shouldn't have been too difficult to have provided Users with the ability to change the colours of the UI from the Preferences?
I guess it may be a matter of preference - or I wonder if those that find the interface difficult to read have calibrated/profiled monitors? Obviously the brightness especially of greys will depend on the tone response (gamma curve) of the monitor. On my monitors the grey fonts aren't dark, but quite light - with highlighted text white. I've had no issue of legibility on any size monitor with any of the text.
Just a thought: check screen gamma and overall brightness level.
I love the UI and I'm hypercritical of UIs. Text is fine here on a NEC 22" Spectraview. Lightroom has to accomodate a lot of info, and it's a pretty brilliant job. It runs amazingly well given all it's doing
The things that bother me are lack of time-saving shortcuts for certain things, like no hotkey to cycle through the profiles in develop (when testing to see if camera standard, adobe standard, etc. is the best fit for an image. This is a huge waste of time when processing a shoot. The active area for slider arrows should be a bit bigger too. Overall LR interace and usability gets an 80 or 85/100 from me, with something like Sony Vegas getting a 95% (the most brilliantly designed software ever IMO) and Adobe Premiere at 10% (only program in existence worse is Blender!)
Well here is the short version. I went in and recalibrated my monitor, 30" Cinema Display. My luminance setting was a bit high, set it to 120.4. Results are that the worst module, Develop, is somewhat easier to see, not easy, just easier. The Develop module consists of all dark, small fonts on a dark grey background. The other modules make better use of lighter fonts.
So if I want to use LR4 I guess I'm just going to have to bite the bullet and squint alot.
Thanks for the input....even you Jeff.
I'll side with the OP here. I can read mine pretty well, but "it works for me" answerea re unheklpful, and in nay case, an option to change the colours does seem to make sense...
Personally, I would like to see much more difference between "selected as part of multiple selected images" and the only slightly lighter "selected as the active image". And yes I have an iMac 24" with calibrated screen.
That a different issue than the UI being dark (one that I happen to agree with). It's a problem when the film strip is pretty small for me, not so much a problem when in Library. Feel free to add a Lightroom Freature Request.
johnbeardy wrote:
Too often Lightroom's shades of grey on dark grey are a victory of design subtlety over usability (eg disclosure triangles, warning colours on drives, rgb curves).
I'm quite surprised at this, as they stand out quite strongly on my screen. Is your screen calibrated, and what gamma do you use? Mine's 2.2. Perhaps with 1.8 there might be less contrast between light grey letters and dark grey background?
johnbeardy wrote:
I'll side with the OP here. Too often Lightroom's shades of grey on dark grey are a victory of design subtlety over usability (eg disclosure triangles, warning colours on drives, rgb curves). It would be good to offer a higher contrast setting - call it "100W lights on"?
But that's still just a personal opinion, John - it's not indicative of a problem per se if as many (more?) of us are happy with the colours of the UI.
Like Simon, they stand out nicely on my screen, without being overbearing - and these are 51 year old eyes.
I don't think it's a simple binary right/wrong, and sure, we are only expressing personal opinions - on each side. But you've got to split your "more" between those who positively like it and plenty who just accept it, which is where I'd place myself. While dim greys on dull greys may not be an absolute fault, that doesn't mean they are optimal. Generally I am not in favour of spending development time on UI preferences (eg hiding modules was a small waste of time) but to my 51 year old eyes Adobe could do better here.
The reason I keep banging on asking whether people have calibrated and profiled monitors: to get the best out of Lightroom you really do need to use colour-management, with a calibrated and profiled monitor.
If the people unhelpfully pointing out "it works for me" all have calibrated and profiled monitors then that might be saying something, well, helpful!
As one of the "it's okay on my machine..." people, I would add that as the UI is always an area of personal preferences (tastes?), it would surely make sense - from a customer satisafaction point of view - to have some ability of software to have colour choices available to the user. Yes, I know that some coding/testing time would be taken, but it is (as John B noted above) not unknown for coding time to be taken on less than essential cosmetic stuff.
Anthony.
First -- its "ok for me" !
A bit more though ...
-Agfacklack- wrote:
as i said i have an calibrated eizo i work on with LR... but then i have 3 other systems including a laptop with cheap monitors and i just tried them.
i have no problems at all. even the laptop is fine.
i really don´t see a problem with the readability on my systems.
if someone likes the dark UI it or not.. ok that is a matter of personal taste.
but from an ergonomic viewpoint .. i can´t understand the complains.
but i agree, it should be no problem to make the UI configurable.
a slider light gray <-> dark gray and a slider for text brightness should be easy to implement.
Thanks for the concern, guys, but all my computers' screens are routinely calibrated and have been for years and I'm faintly amused you imagine otherwise. I've always felt Adobe could do better - in this, as in too many aspects of Lightroom, we get used to sub-par features, don't you think?
We don't mean you, John - we mean the OP and people like Ann.
Not in this case - I honestly don't consider this to be a problem or even slightly "could be better".
I happen to have a very large and calibrated top-of-the-line NEC display so that is not the issue — although it's brightness is set for accurate Color Proofing for Print.
I simply find the LR GUI a dark, cluttered and depressing environment in which to work (and an eye-straining one too!) and much prefer to work in the broad sunny uplands of Photoshop and Bridge-hosted ACR. (And that combination works extremely efficiently even for this photographer who may return from a Shoot with anywhere between four and eight thousand photographs!)
The ability to choose a lighter interface is essential in my case.
Panels which retracted into docks on the edges of the monitor would get rid of the clutter and provide a bigger working space and then the "develop" panels could open more widely when in use to allow for wider sliders.
Another thing about dark interfaces is that while they may be satisfactory for those who only prepare work for on-screen viewing, they are thoroughly unsuitable for those who prepare work for the Press or Printing in general.
Yet again, I have given another new version of LR (LR4) a fair testing and regret that, for the reasons stated here, I still do not find it to be a program that I will be buying.
Ann:
"Panels which retracted into docks on the edges of the monitor would get rid of the clutter and provide a bigger working space and then the "develop" panels could open more widely when in use to allow for wider sliders...."
Umm, the panels, L&R, Top and Bottom can be set to retract (since always I think)
Anthony.
As already pointed out -- they do.
But there is lots more, if you spend the time to look ...
Yes, might be nice to configure the colours but for me I like it the way it is -- obviously others do not
As Anthony stated you can already do that. You can also already make the develop panel wider to allow for wider sliders. Works great.
Keith Reeder....."we mean the OP and people like Ann". Just exactly what do you do for a living? I happen to make my living doing fine art landscape photography. I have for many years. You're assumption that because we don't like something, we must be "inferior", I find smacks of ignorance and prejudice.
And it still doesn't look good on my calibrated 30" Cinema Display.
I assume you are aware that you can change the background color to light gray or white as you prep for printing...
I would NEVER print from LR!
There is a lot more to to do in professional image-making than merely colour correcting in LR!
I think that LR is probably perfectly fine for amateur photographers and hobbyists but it cannot, and does not, provide the full range of tools that a professional graphic arts person needs. If you are going to buy Photoshop and the rest of the Creative Suite (which is what I do) I find that LR is superfluous to my needs.
For example, when I make Blurb books, I use a CMYK Photohop/InDesign/Acrobat Pro workflow and would never use Blurb's sRGB BookSmart workflow (which is basically what LR4 provides).
It has been interesting to try out the latest version of LR4, and to see the latest gizmos which have been added to it, but I have seen enough to realise that I will NOT be purchasing it when my 30-day trial period ends.
I think a lot of professionals might disagree with you. I do, and I've used Photoshop for 19 years. Don't get me wrong, I love PS, but is it always necessary anymore.Definitely not IMO.
Seems to me that a couple of people here just don't want to like LRx.
They don't know what it can do and have not really looked at it to see what it can do,
I for one will stop posting responses.
Its one thing to say you don't like it, but don't blame it for not having things it does have,
and don't complain about it if you have not spent a few days looking at it, you cannot
know if you spent 10min looking at it.
Then you are missing a lot and prolly have a really convoluted workflow that wastes a lot of your time. I much prefer printing from LR because, well it's vastly more efficient and does the right thing regarding resampling and output sharpening. If you are a graphic artist working for CMYK reproduction, Lightroom was not designed for you. If you are a photographer working in primarily an RGB world, it is. LR is capable of meeting and exceeding Photoshop's printing but with a much better workflow with a lot less user error. It would be useful if your opinion was better informed...really, printing, particularly fne art printing is much "better" from LR. In fact I would go so far as to say if LR did nothing else besides print, I would use it just for printing (of course, it does a lot more).
And this has ZERO to do with the interface...
