Ravenant211
Possible to create a second handle on a point without moving the first one?
Mar 17, 2012 7:15 PM
Hello again,
Just had a question about something that often drives me crazy. Sometimes when I'm modifying an object (especially text that has been turned into outlines for logos etc) There are points on the path that I want/need to remove. Many of the times the points I'm removing had part of the curve that made the path look nice and smooth. For some reason Illustrator likes to create two points overlapping each other with a handle extending in opposite directions for each instead of one point with two handles...
In the cases where I have a point on a path with only one handle, whether it overlaps another point or not, is there a way to create a new handle on the opposite side where a handle doesn't exist without moving the handle that is already there? I hate fiddling with the path for 10 minutes afterwards trying to get everything back into the same position again. I would like to be able to drag out a new handle while locking the old handle in place, but the initial behavior of the convert anchor point tool seems to be to get rid of the old existing handle and recreate two new handles which resets everything.
Is there a way around this? A tool behavior option or maybe even a different tool that will let me just add the one handle to the point that is missing without moving or deleting the existing handle on that point? If it matters I'm using Illustrator CS5.5. Thanks for any help in advance!
    Mar 17, 2012 8:36 PM   in reply to Ravenant211
    There's no one-step solution for this natively. One method would be to turn on Smart Guides, drag out a vertical and horizontal guide, snapping to the original handle, extend both with the convert anchor point tool, and reposition the first handle, snapping to the guide intersection.Then you'll need to unlock the guides and delete them.
    However, if you're willing to use a third-party plug-in, the PathScribe tool (part of the VectorScribe plug-in) can extend a single handle without altering the first.
    But even better, it has a command "Remove redundant points," which automatically merges the two one-handled points into a single two-handled point -- saving you from having to manually fiddle with the handles at all.
    DF
    Mar 17, 2012 10:02 PM   in reply to Ravenant211
    look at this post, a script is suggested to remove overlapping anchors
    http://forums.adobe.com/message/4022249
    Mar 18, 2012 3:24 PM   in reply to Ravenant211
    I thought there had to be a native solution and I was just somehow missing it completely... maybe they don't want to step on the 3rd party vendor's toes who have made plug-ins to deal with this sort of thing? Illustrator has been around a looong time now, seems like they would have come across this more than a few times...
    Users certainly have come across these sorts of issues, and pleaded with Adobe (both in this forum and elsewhere) to improve and modernize the core functionality instead of just adding new features -- but in most cases, version after version has come and gone without much change, even if small, easy changes are being asked for. Take the pen tool, for example -- 15 versions in, and toggling Smart Guides still breaks the current path you're drawing!
    I doubt Adobe would have any qualms about developing their own native solutions if they saw fit -- more likely it's just a business decision involving resource allocation and revenue projections and all of that.
    Which is a shame, but at least we have scripts and third-party developers to step up to the plate and fill in some of the gaps.
    DF
