I got Premiere Elements v 9.0 installed on Windows XP last week by IT dept. But something is wrong.
I cannot view any .wmv or .mov files (havent tried any more yet). I add my clips to the project but when playing them all I get is a white screen. In timeline I can see snapshot images as usual.
Can you help us with some hints? I doubt there are any experienced moviemakers at IT at all. I probably need to get the fix and tell them what to do.
The project settings seems perfect. The clip I added in timeline "shows green" (no rendering needed). So I doubt that is the problem.
Please help - I need to start up a real project this week.
What model of camera or camcorder did these video clips come from?
Open the files in a program like G Spot or Media Info and let us know what displays as their resolution, frame rate and, above all, codecs.
http://www.headbands.com/gspot/
Also, have you manually gone to Windows Update and pressed the Custom button to ensure you have even the non-critical updates to your operating system?
I assume you mean your camera is the Canon 500D.
When you go under Edit/Project Properties, what does it show?
You should have set up your project by selecting the settings for DSLR/1280x720p.
If that doesn't work, try setting up a project using the Flip Mino HD settings.
You must have your project set up correctly so that Premiere Elements will install the necessary components for your computer to read these files. (It also helps to ensure you have the latest version of Quicktime, per the program's requirements -- and it doesn't hurt to install the software the came with your camera, which can sometimes install important codecs.)
If you're using version 9, you do have the option to set your project up for DSLR 720p.
Start a new project, select Settings and you should see it listed on the Project Settings option screen.
More information on setting up a project and getting media into it can be found in my free 8 part Basic Training tutorials at Premiere Elements support site Muvipix.com.
When one encounters display issues, the first thing that I recommend checking is the video card/chip's video driver.
What make/model of video display adapter do you have?
What is the currently installed video driver?
Can you go to the video card/chip mfgr's. We site, plug in your card/chip's number, and your OS, and check for an updated driver?
Note: do not trust Windows, or any utility, to tell you if you have the latest video driver. They will be at least 6 mos. out of date.
Note also: if you have a Dell, Lenovo, HP, Toshiba, or other mainstream computer company's system, check on their Web sites, as many re-wrap video drivers from nVidia, ATI/AMD and Intel. If you have an Intel integrated graphics chip, you might have difficulty finding a newer driver, but still look for one.
Do you have a laptop, or desktop computer?
Good luck,
Hunt
When the tech stops by, ask them to give you the details of your graphics display adapter, and then ask them to check on the mfgr's. Web site for the latest driver. Many folk, even computer techs, do not realize that Windows will not give a correct answer, when queried about the driver update. One must go to the mfgr's. site to check, and to download the very latest.
BTW - to gather that info yourself, you can go to Start>Run and type in "dxdiag.exe" (without the " marks), and see for yourself, what you have. It will also tell you what driver version, and its date, you have installed.
Good luck, and hope that the tech will have everything up and running for you,
Hunt
One tech guy was here checking the graphic display etc.
I guess it is the same problem as in this thread http://forums.adobe.com/thread/784748
But we have installed the latest driver form DELL but problem still remains.....This isn´t fun ![]()
Thanks Steve!
I have worked with Adobe Premiere for almost ten years now. I started with the professional version but changed to Elements since it had 90% of everything I needed to a much less cost. I am far from fully skilled yet but I have set up and produced over a 100 projects now and I have never had these problems before.
The only difference this time is a new laptop and a new version of Premiere. And since it this time is equipment owned by my employeer I cannot install and update drivers as easy as if it had been my own. I have to wait for that guy from Dell coming and visiting me and that will probably be tomorrow. I will take a look at your tutorial but I want the Dell guy to do his work first.
Let's put the tech to the test here.
What is the make/model of your video card?
What is the number and date of the installed driver?
Do you have a Dell, HP, Toshiba, Lenovo, or similar?
Many techs will just go to Windows, and let it tell them, if one has the latest video (or audio) driver, and Windows will be ~ 5 mos. out of date. The same for many driver utilities. One needs to check directly.
Good luck, and I hope that the tech is correct, but then that means that something else is going on,
Hunt
A White screen almost always means a wrong display driver. You could (ask the tech guy to) modify the display driver to a version where this issue is not seen. This could mean shifting to an earlier version of the driver. We have seen that an upgrade does not work always. You can also update the system firmware (again for the Dell support) and see if that fixes. An old Optiplex 760 had this issue which was resolved with an update to A05 firmware (also known as BIOS update) from the default A01.
That aside, shifting to Premiere Elements 8 will not be a good idea. That was a version that was very particular about the display driver. At least PrE9 does not crash. PrE8 will actually make your day miserable.
tech guy checked the BIOS but we decided not to roll back to earlier graphic driver since we have corporate rules restricting what program to run on what computer. We might get my installation working but then only for two weeks. Then I will get a completely new installation of OS and drivers completely dictated by IT. They will not allow an older driver - they might approve a new one (but it didnt work).
This will be really delicate....they probably need to convince DELL to release a new driver or I will need to go into the group testing Windows 7 (my laptop is built for that)
Meanwhile....
I tried to install Elements v 10 today - just to try. I got Run-time error 630 or 6030 ( a C++ error). It didn work at all. It asked for serialnumber again and again - I said trial. And it asked again....pew!
I also updated Quicktime.
Do anyone know anything else not including rolling back to older versions of drivers? I would be happy to try!
What is the recommended procedure from this point?
Make an offical report at Adobes product support or Dell support?
I fear a new release of graphical driver is the only solution or if Adobe can do something.
I cannot have an older release of driver than the rest of my organization - there are 42 000 PC users and everything is standardized. Upgrading might be possible (I think) but to rollback a few releases of the grahics driver for all 42 000 PC users would create tremendously lots of problems.
