maxwel11
A Problem with online stream player
Mar 19, 2012 3:10 AM
actually i got whole player working well but all my problem is when the stream is loaded at first time when swf is loaded by browser the stream begins to play and everything is fine with that but main problem is that when i press the stop button then play button again the stream don begin from current stream time (like it don play from now stream point) but it plays from the begining from the time the swf file was loaded very begining (when swf was loaded and stream was autoplayed) and this is my main problem tried experiencing with problem for lonnng time but no use. any idea?
here main part of code:
var snd:Sound = new Sound();
var volnum:Number = 1;
var context:SoundLoaderContext = new SoundLoaderContext(8000, true);
snd.load(songURL, context);
var channel:SoundChannel;
channel = snd.play();
isPlaying = true;
addEventListener(Event.ENTER_FRAME, onEnterFrame);
var bytes:ByteArray = new ByteArray();
function playSound(event:MouseEvent):void {
          if (isPlaying == false) {
                    isPlaying = true;
          } else {
function stopSound(event:MouseEvent):void {
          channel.stop();
          isPlaying = false;
playBtn.addEventListener(MouseEvent.CLICK, playSound);
stopBtn.addEventListener(MouseEvent.CLICK, stopSound);
volDownBtn.addEventListener(MouseEvent.CLICK, volumeDown);
volUpBtn.addEventListener(MouseEvent.CLICK, volumeUp);
wish anyone can help with that problem that took me while without finding a solution
thanks alot
Replies 1 2 Previous Next
    Mar 19, 2012 3:38 AM   in reply to maxwel11
    snd.play() will always start the playback from the beginning
    public function play(startTime:Number = 0, ...):SoundChannel
    to resume where it was stopped use this
                   channel = snd.play(channel.position);
                   isPlaying = true;
    Mar 19, 2012 3:51 AM   in reply to maxwel11
    well if you are viewing this in a browser you would need to clear the browsers cache in order to see the new swf. however you can try 2 things.
              trace("pre stop position: " + channel.position);
              channel.stop();
              trace("post stop position: " + channel.position);
              isPlaying = false;
    and
                   trace("play position: " + channel.position);
                   isPlaying = true;
    and let me know the output from the 3 trace statements
    if you are running this in a browser, you will need to find the flashlog.txt file on your machine
    (e.g. C:\Users\{username}\AppData\Roaming\Macromedia\Flash Player\Logs)
    Mar 19, 2012 4:17 AM   in reply to maxwel11
    sorry i don't understand. you want it to play from the beginning?
    then use the code you had before snd.play()
    Mar 19, 2012 4:35 AM   in reply to maxwel11
    ok, if i understand you correctly that means you will have reload the sound when you click play.
                   isPlaying = true;
              channel.stop();
              isPlaying = false;
    this will stop the stream when stopSound is called
    and then when you call playSound the snd object will get the latest stream from the server and start playing again
    Mar 19, 2012 5:10 AM   in reply to maxwel11
    right ok this is because you can't reload a Sound sorry I didn't look into that before
    try something like
                   snd = Sound();
                   isPlaying = true;
    Mar 19, 2012 5:26 AM   in reply to maxwel11
    what's on line 69 of frame 3?
    Mar 19, 2012 5:27 AM   in reply to _spoboyle
    sorry think i just spotted it
    replace
    snd = Sound();
    with
    snd = new Sound();
    Mar 19, 2012 6:28 AM   in reply to maxwel11
    I have constrcuted a demo project to try and simulate your problem. I've got it working and indeed my example doesn't play anymore sound after you stop and play twice.
    However I don't get the error you are seeing I just get no sound, and I do have a valid sound channel after calling play for the thrid time. this is very odd I've try and look into it but i'm running out of ideas
    Mar 19, 2012 7:09 AM   in reply to maxwel11
    btw there is a hack you could use to get it working.
    instead of stopping the sound playback with channel.stop()
    you could just mute the channel until the user clicks play and then restore the previous volume.
    It ain't pretty but if there is no other way it should work.
    also you use
    context = new SoundLoaderContext(8000, true);
    and the url I have been connecting too has a invalid securityPolicy file and so unless you need specific function calls in flash it might be worth trying
    (their crossdomain file seems invalid as well)
    context = new SoundLoaderContext(8000, false);
    but maybe you don't have the same problem as me
    Mar 19, 2012 7:11 AM   in reply to _spoboyle
    I'll jsut add one more thing
    on the second time of pressing "play" I am not receiving an OPEN event, which I believe is what's causing the issue
    but I cannot tell why I am not receiving the OPEN event
  • kglad
    Jul 21, 2002
    Mar 21, 2012 2:03 PM   in reply to maxwel11
    there are too many messages to follow this thread.  summarize in one message the current state of your issue just as if it were your first post.
  • kglad
    Jul 21, 2002
    Mar 22, 2012 7:38 AM   in reply to maxwel11
    you don't have an open event listener in playSound so that's why you're not seing an open event.  use:
            if(snd){
                snd.removeEventListener(Event.OPEN,f);
            snd = new Sound();
            snd.addEventListener(Event.OPEN,f);
            channel=snd.play();
            isPlaying=true;
    function f(e:Event):void{
    trace(e);
    and i don't see any problem repeatedly playing/stopping a sound using your code.
    Mar 22, 2012 9:06 AM   in reply to kglad
    hey kglad
            if(snd){
            snd = new Sound();
            channel=snd.play();
            isPlaying=true;
    trace(e);
    nor did I until I actually tried it
    in the project I set up I did have an OPEN event listener and noticed it wasn't being received after the 3rd time of playing the stream
    I have a single class example if you want me to email it over or anything so you can see what's going on
  • kglad
    Jul 21, 2002
    Mar 22, 2012 10:09 AM   in reply to maxwel11
    it worked for me numerous times but i didn't use a "streaming" server, are you?
    what's the mp3's url?  what's the url of your test html?
  • kglad
    Jul 21, 2002
    Mar 22, 2012 10:10 AM   in reply to kglad
    oh, i see the sounds url.
    that's the sound's server issue.  it's not allowing repeated downloads of its sound.  they probably don't want users screwing around with their bandwidth.
  • kglad
    Jul 21, 2002
    Mar 22, 2012 1:26 PM   in reply to maxwel11
  • kglad
    Jul 21, 2002
    Mar 22, 2012 1:31 PM   in reply to maxwel11
    exactly.  that's what i said.  it's a server streaming issue.
    at least, that's what it looked like to me before because someone had posted security context error 2000.
  • kglad
    Jul 21, 2002
    Mar 22, 2012 5:55 PM   in reply to maxwel11
    you can make some things work:  http://www.kglad.com/Files/forums/streamError2.html
    (left button starts, right stops)
  • kglad
    Jul 21, 2002
    Mar 23, 2012 8:36 AM   in reply to maxwel11
    yes, that's using your streaming url.
    if that is working the way you want, the key is closing the stream (if it's still open - using the sound class'es close() method) before trying to open another stream.  that server does not like multiple streams open at one time.
    here's the code:
    import flash.media.Sound;
    import flash.media.SoundChannel;
    import flash.net.URLRequest;
    import flash.events.IOErrorEvent;
    import flash.events.Event;
    var snd:Sound;
    var isPlaying:Boolean;
    var isStreaming:Boolean;
    var songURL:URLRequest = new URLRequest('http://radio.virtualdj.com:8000/;stream.nsv');
    b.addEventListener(MouseEvent.CLICK,playSound);
    c.addEventListener(MouseEvent.CLICK,stopSound);
        if (isPlaying==false) {
            if (snd) {
                snd.removeEventListener(Event.OPEN,openF);
                snd.removeEventListener(Event.COMPLETE,completeF);
                snd.removeEventListener(IOErrorEvent.IO_ERROR,errorF);
            snd = new Sound();
            snd.addEventListener(Event.OPEN,openF);
            snd.addEventListener(Event.COMPLETE,completeF);
            snd.addEventListener(IOErrorEvent.IO_ERROR,errorF);
            channel=snd.play();
            isPlaying=true;
        channel.stop();
        if(isStreaming){
            snd.close()
        isPlaying=false;
    function completeF(e:Event):void{
        isStreaming = false;
    function openF(e:Event):void {
        isStreaming = true;
    function errorF(e:IOErrorEvent):void{
        trace(e);
1 2 Previous Next
Actions
Incoming Links
