I too am getting similar error when attempting a software update. Mac OS X 10.6.7, I do use SourceMate so not sure if that has anything to do with it. I tried changing my java preferences to use 32 bit as I read in another forum post but that didn't help.
Cannot complete the install because of a conflicting dependency.
Software being installed: Adobe Data Modeling Core Components 4.5.310758.v20110503 (com.adobe.model.feature.core.feature.group 4.5.310758.v20110503)
Software currently installed: Shared profile 1.0.0.1301933628200 (SharedProfile_epp.package.java 1.0.0.1301933628200)
Only one of the following can be installed at once:
Adobe Data Modeling Core Components 4.5.310758.v20110503 (com.adobe.model.feature.core.feature.jar 4.5.310758.v20110503)
Adobe Data Modeling Core Components 4.5.304901.v20110217 (com.adobe.model.feature.core.feature.jar 4.5.304901.v20110217)
Cannot satisfy dependency:
From: Shared profile 1.0.0.1301933628200 (SharedProfile_epp.package.java 1.0.0.1301933628200)
To: com.adobe.model.feature.core.feature.jar [4.5.304901.v20110217]
From: Adobe Data Modeling Core Components 4.5.310758.v20110503 (com.adobe.model.feature.core.feature.group 4.5.310758.v20110503)
To: com.adobe.model.feature.core.feature.jar [4.5.310758.v20110503]
In /Applications/Adobe Flash Builder 4.5/eclipse/configuration/config.ini comment the following three lines then launch the FB and try to update.
eclipse.p2.data.area=@config.dir/../p2/
osgi.configuration.area=@user.home/Documents/Adobe Flash Builder 4.5/cascaded/308971/configuration
osgi.configuration.cascaded=true
Please backup the config.ini file and replace once you updated the plugins(with the all the three lines uncommented).
Please let me know if this works.
Regards
Unni G S
I still get the following:
Software being installed: Eclipse IDE for Java Developers 1.3.2.20110301-1807 (epp.package.java 1.3.2.20110301-1807)
Software currently installed: Zend Studio for Flash Builder 4.5.0.v20110330-0922-8J8yCdFQvEteMB1ipqJu8S1Kg6GD (com.zend.php.flashbuilder.all.feature.group 4.5.0.v20110330-0922-8J8yCdFQvEteMB1ipqJu8S1Kg6GD)
ECF Core API 3.1.0.v20100529-0735 (org.eclipse.ecf 3.1.0.v20100529-0735)
ECF Core API 3.1.0.v20100906-1425 (org.eclipse.ecf 3.1.0.v20100906-1425)
Team Support UI 3.5.100.I20100527-0800 (org.eclipse.team.ui 3.5.100.I20100527-0800)
Team Support UI 3.5.101.R36x_v20100825-0800 (org.eclipse.team.ui 3.5.101.R36x_v20100825-0800)
Team Support UI 3.5.102.R36x_v20110203-1036 (org.eclipse.team.ui 3.5.102.R36x_v20110203-1036)
Universal Welcome 3.2.402.r36_v20100702 (org.eclipse.ui.intro.universal 3.2.402.r36_v20100702)
Universal Welcome 3.2.400.v20100517 (org.eclipse.ui.intro.universal 3.2.400.v20100517)
From: Zend Studio Feature 8.0.1.v20101203-1424-Bb7Z97Fh1z-WD1aeVEsRvwW (com.zend.php.feature.group 8.0.1.v20101203-1424-Bb7Z97Fh1z-WD1aeVEsRvwW)
To: org.eclipse.ecf [3.1.0.v20100529-0735]
From: Zend Studio for Flash Builder 4.5.0.v20110330-0922-8J8yCdFQvEteMB1ipqJu8S1Kg6GD (com.zend.php.flashbuilder.all.feature.group 4.5.0.v20110330-0922-8J8yCdFQvEteMB1ipqJu8S1Kg6GD)
To: com.zend.php.feature.group [8.0.1.v20101203-1424-Bb7Z97Fh1z-WD1aeVEsRvwW]
From: Eclipse IDE for Java Developers 1.3.2.20110301-1807 (epp.package.java 1.3.2.20110301-1807)
To: org.eclipse.epp.package.java.feature.feature.group [1.3.2.20110301-1807]
To: org.eclipse.platform.ide 0.0.0
From: EPP Java Package 1.3.2.20110301-1807 (org.eclipse.epp.package.java.feature.feature.group 1.3.2.20110301-1807)
To: org.eclipse.platform.feature.group [3.6.2.r362_v20110210-9gF78Gs1FrIGnHDHWkEcopoN8AmxeZflGDGKQi]
From: Equinox p2 Provisioning 2.0.1.r361_v20100903-897HFa-FX0z-z-ntoaavz0JPX628 (org.eclipse.equinox.p2.user.ui.feature.group 2.0.1.r361_v20100903-897HFa-FX0z-z-ntoaavz0JPX628)
To: org.eclipse.ecf [3.1.0.v20100906-1425]
From: Eclipse Platform 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY (org.eclipse.platform.feature.group 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
To: org.eclipse.ui.intro.universal [3.2.400.v20100517]
From: Eclipse Platform 3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L (org.eclipse.platform.feature.group 3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L)
To: org.eclipse.team.ui [3.5.101.R36x_v20100825-0800]
From: Eclipse Platform 3.6.2.r362_v20110210-9gF78Gs1FrIGnHDHWkEcopoN8AmxeZflGDGKQi (org.eclipse.platform.feature.group 3.6.2.r362_v20110210-9gF78Gs1FrIGnHDHWkEcopoN8AmxeZflGDGKQi)
To: org.eclipse.team.ui [3.5.102.R36x_v20110203-1036]
To: org.eclipse.ui.intro.universal [3.2.402.r36_v20100702]
From: Eclipse Platform 3.6.0.I20100608-0911 (org.eclipse.platform.ide 3.6.0.I20100608-0911)
To: org.eclipse.platform.feature.group [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
From: Eclipse Platform 3.6.1.M20100909-0800 (org.eclipse.platform.ide 3.6.1.M20100909-0800)
To: org.eclipse.platform.feature.group [3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L]
From: Eclipse Platform 3.6.2.M20110210-1200 (org.eclipse.platform.ide 3.6.2.M20110210-1200)
To: org.eclipse.equinox.p2.user.ui.feature.group [2.0.1.r361_v20100903-897HFa-FX0z-z-ntoaavz0JPX628]
This response is not meant for this thread. Ignore it.
Hello All,
Eclipse update can not be used to updater FB4.5 to FB4.5.1.
Right way to update would be to use "Help --> Search for Flash Builder Updates" menu item. This action will launch "Adobe Application Manager" which will present you with the available and applicable FB related updates. Make sure that in "AdobeApplicationManager->Preferences" you have FB checked.
Try it and let us know.
-Jayesh Viradiya
FB Team
I just ran into the same problem on a new installation of Flash Builder Pro 4.5, note that the Adobe Application Manager did perform an update before I first launched FB myself. Definately not something I would expect either.
Can you say what settings yoiu did use, might be helpful to share (and it sounds like you turned off the updates to avoid the conflicting update error).
I now have the installation working, but did not comment exactly the same lines as Unni's solution. I found the following article in Adobe's knowledge base:
http://kb2.adobe.com/cps/895/cpsid_89514.html
This article refers to the problem where third party plug-in are installed in the user directory rather than the Flash Builder application directory. You can force installation into the application directory by commenting out these lines:
osgi.configuration.area=@user.home/Documents/Adobe Flash Builder 4.5/cascaded/<build number>/configuration osgi.shared.configuration.area=file\:configuration osgi.configuration.cascaded=true
I commented out these lines, and the update worked. It looks like the problem is competing dependencies between FB4.5 user and application directories. By removing the reference to your user directory, everything can be updated, everything in your Flash Builder 4.5 application directory. I am still curious why Unni commented the "eclipse.p2.data.area=@config.dir/../p2/" line.
Adobe should really comment on a solution or fix this issue. I suspect I'm going to run into problems later, now that I have updated the application directory, but Adobe *did* recommend this approach for other plug-ins in their knowledge base.
i'm using Flash Builder 4.6 for PHP and tried uncommenting the config lines and still get these errors.
In addition, i want to install the ADT Plugin to do native android development and get the same error. This is really frustrating since i just want to use 1 IDE for all my dev. Please HELP!!
Software currently installed: BlackBerry Tablet OS Plugin for Adobe Flash Builder 1.2.0.201110311231 (com.qnx.tools.flashbuilder45.feature.group 1.2.0.201110311231)
Software currently installed: Zend Studio for Flash Builder 4.5.1.v20110609-1000-8J8yCeFQvEteMB6jnqJy3X1Kg6GL (com.zend.php.flashbuilder.all.feature.group 4.5.1.v20110609-1000-8J8yCeFQvEteMB6jnqJy3X1Kg6GL)
Core File Systems 1.3.0.v20100526-0737 (org.eclipse.core.filesystem 1.3.0.v20100526-0737)
Core File Systems 1.3.1.R36x_v20100727-0745 (org.eclipse.core.filesystem 1.3.1.R36x_v20100727-0745)
Views 3.5.0.I20100527-0800 (org.eclipse.ui.views 3.5.0.I20100527-0800)
Views 3.5.1.M20110202-0800 (org.eclipse.ui.views 3.5.1.M20110202-0800)
From: BlackBerry Tablet OS Core Shared 1.1.0.201110311231 (com.qnx.tools.bbt.core 1.1.0.201110311231)
To: bundle org.eclipse.core.filesystem [1.3.1,2.0.0)
From: BlackBerry Tablet OS Plugin for Adobe Flash Builder 1.2.0.201110311231 (com.qnx.tools.flashbuilder45.feature.group 1.2.0.201110311231)
To: com.qnx.tools.bbt.core [1.1.0.201110311231]
From: Zend Studio Feature 8.0.1.v20101203-1424-Bb7Z98Fh1z-WD1aqSLsR8mU (com.zend.php.feature.group 8.0.1.v20101203-1424-Bb7Z98Fh1z-WD1aqSLsR8mU)
From: Zend Studio for Flash Builder 4.5.1.v20110609-1000-8J8yCeFQvEteMB6jnqJy3X1Kg6GL (com.zend.php.flashbuilder.all.feature.group 4.5.1.v20110609-1000-8J8yCeFQvEteMB6jnqJy3X1Kg6GL)
To: com.zend.php.feature.group [8.0.1.v20101203-1424-Bb7Z98Fh1z-WD1aqSLsR8mU]
To: org.eclipse.core.filesystem [1.3.0.v20100526-0737]
To: org.eclipse.ui.views [3.5.0.I20100527-0800]
To: org.eclipse.ui.views [3.5.1.M20110202-0800]
