Flash Builder Hangs when compiling to AIR App
Jan 18, 2011 12:00 PM
I created a presentation in Catalyst with some embedded objects and some linked objects, then jumped it to Flash Builder to have my developer add in some scripts. We then tried to Export Release Build to create an AIR application. Problem is, it won't pull the linked assets. If I check the box to include the assets it hangs on the compilation. I can just keep clicking the "Finish" button and nothing happens. If I deselect the "Assets" I can click "Finish" it compiles the AIR application, but I'm left with a basically empty application. I don't understand what's happening. Any help please.
Jim
    Jan 19, 2011 5:25 AM   in reply to jblay-design
    This is a known limitation in Flash Builder.
    Please put your linked assets in a new source folder (Project properties -> Flex Build Path -> Source Path -> Add Folder and point to an external folder).
    Unless it is a "source" folder, the compiler ignores assets in linked folders while exporting.
    Anirudh
    Jan 19, 2011 9:54 PM   in reply to jblay-design
    Put assets in another folder, say src_assets and make that the source folder.
    Think of it this way - each src folder is in the default package.
    Mar 19, 2012 7:51 AM   in reply to jblay-design
    This sounds a lot lik emy problem, with the iOS version not compiling, but mine are included in the src-assets-mp3 folder. When I try to compile for iOS it just hangs, though it compiles for Android fine... I am trying the same thing you suggested, Ill post here if it helps me also.
