object doesn't support this property or method
Guest
Mar 13, 2012 Mar 13, 2012
Hi all,
I'm testing AS3 calling Javascript. It works in FF but not in IE8. I'm suspecting is a version problem but not sure.Can someone take a look? TIA  -s
Here is my environment:
OS: Win7 Pro 64bit.
CS4 installed.
then Flash player updated to 11.1 (no touch to the CS4 Flash installation dirs).
Here is the AS3 code:
import flash.external.ExternalInterface;
flash.system.Security.allowDomain("*");
startTest();
function f0():Boolean {
ExternalInterface.call("ff1");
return true;
function startTest():void {
if (ExternalInterface.available) {
  try {
   ExternalInterface.addCallback("f100", f0);
  } catch (error:Error) {
   trace("An Error occurred: " + error.message + "\n");
Here is Javascipt part:
<script type="text/javascript">
   function ff1()   {    alert("From AS")   }
function f101() {    window.setTimeout(f100, 2000)   }
  function f100(){
   var a=document.getElementById("fltest");
  a.f100() // got error message here
window.onload= f101;
</script>
</head>
<body>
<div id="test"><object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#ve rsion=10,0,0,0" width="215" height="318" id="fltest" align="middle">
<param name="allowScriptAccess" value="sameDomain" />
<param name="allowFullScreen" value="false" />
<param name="movie" value="test.swf" /><param name="quality" value="high" /><param name="wmode" value="transparent" /><param name="bgcolor" value="#ffffff" /> <embed src="pet.swf" quality="high" wmode="transparent" bgcolor="#ffffff" width="215" height="318" name="fltest" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/go/getflashplayer" />
</object>
</div>
ActionScript
2.2K
if you're not seing that alert "From AS", you probably have incorrect swf embedding code.  to remedy, use the embedding code published by flash.
i wouldn't expect your addCallback is going to work.  to remedy, check the flash help files for sample callback code.
Guest
Mar 14, 2012 Mar 14, 2012
After remove/reinstall Flash CS4, I cahnged above allowscriptaccess to "always". This time, it works in IE8 but FF shows "a.f100 is not a function"?
Please help.
a.f100 makes no sense.
are you trying to call an actionscript function from javascript?  if so, check the flash help files (externalinterface) for info and sample code on how to use addcallback.
Guest
Mar 19, 2012 Mar 19, 2012
Interesting. Have you ever tried callback yourself?
yes.
