Hi!
We're connected to a turbobridge.com conference. It sends 2 SIP OPTIONS messages every 10 seconds, and FMG responds 501: not implemented. Can we implement it somehow, or specify an answer?
Also, I've set the doRegister function to 0, but the FMG reregisteres the call very often, about every 115 secs. I changed the registrationExpiration, but it's still being called according to the wireshark trace. Is that a bug? How can I get less SIP REGISTER calls? It makes glitches in the audio every 2 minutes.
Thank you,
Gabor
Gabor,
Can you please share the wireshark capture of SIP Option & FMG reply with 501 ?
FMG shouldn't register when doRegister is set to 0. Does removing, doRegister tag completly helps ?
If it was a bug, seem to have been fixed in the upcoming version
-Pankaj
When removing the doRegister tag, it works fine, thanks.
I'd like to share the Wireshark capture, but not in public. Is it okay if I send it to fmg@adobe.com?
Gabor
you may send captures to pyadav at adobe dot com
