InDesign server CS 5.5 - app.scriptArgs.get doesn't work in jsx script or simpleclient problem
Jan 24, 2012 5:38 AM
Hello
I'm working with Adobe InDesing Server CS 5.5 and having problem that *.jsx script is not able to read input parameters passwd from sampleclient.exe or SOAP (same story in both cases)
I run following command:
     sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" param1="1"
also
     sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" param1=1
and even
     sampleclient.exe -host localhost:8080 "c:\CreateJPEG.jsx" "param1=1"
app.scriptArgs.get("param1") is always FALSE (see script body below).
Please help, I couldn't find an answer anywhere. All documents stats that this should work in a way I described, but it doesn't. Script is performed but param1 is not set.
Here is the script:
#target  InDesignServer
app.scriptPreferences.version = 7.0;
main();
function main()
  var eRet;
  if (app.scriptArgs.get("param1"))
    var sXMLFilePath = "C:\\CreateJPEG.xml";
    var eRet = app.createJpeg (sXMLFilePath);
    Calculating status...
    Feb 7, 2012 4:12 AM   in reply to hxkris-dev
    Try this: pass the parameter to the main function:
    var param1 = app.scriptArgs.get("param1");
    main(param1);
    function main(param)
      if(param)
    Mar 20, 2012 6:58 AM   in reply to hxkris-dev
    First try: if(app.scriptArgs.isDefined('param1'));
    Second, use: app.scriptArgs.getValue('param1') to get the Value of the param
