Examine Document is now called "Remove Hidden Information" in Acrobat X, it's under the Protection tab.
http://www.pdfforlawyers.com/2010/12/removing-pdf-metadata-document-markups-using-acrobat.html
You're brilliant and a life-saver! I'm working on an extremely tight deadline and have spent the last frustrating hour with this problem -- and you fixed it!! Thank you!!
I ran into this very problem today, and I was worried that the new fonts, that I had created and used, were causisng the problem. Then I attempted to use your "solution," and it worked!
My annotations were saved, with the document without a problem. Thanks!!!
Hi LoriAUC,
Do you know which is the equivalent for "single-fix ups" in Acrobat 10?
I ran the syntax analysis and it found these issues (screenshot below):
I'm not sure though if these are just trivial problems or the ones that could be the cause of the Error 14.
It did, however, seem to have gotten rid of the Error 14 for now, but when I try to extract pages I still get the "bad parameter" error.
Jay
Here is a technique for identifying all the pages that have invalid annotation objects on them:
1. Document > Extract Pages ...
2. During the extraction, click OK in all the message boxes that appear.
3. After the extraction, look in the destination folder to see which pages are missing. Those are the pages that have invalid annotation objects.
From this point you can try to delete the objects, or simply delete and replace the pages, or implement a different solution. Hope this helps someone.
There are at least two posts here with ideas on how to actually fix a file with this problem. Thank you! I will be trying these in the future.
I just finished fixing a 332 page file with this problem by extracting groups of pages, then saving the extractions. The ones that would not save had bad pages in them. I did this for 45 minutes, narrowing down my groups until I had the 4 offending pages/annotations. Then I combined all the extractions. This method worked, but the others listed here seem less time consuming!
Thanks brennao. This worked for me in a 467 page document with 2 bad pages.
I originally extrcted as single pages, but scrolling through 467 pages looking for missing numbers just wasn't working. Buy doing it in batches of 100, then 50, etc. I was able tto narrow it down pretty quick.
On 3/24/2015 same problems, after Adobe Acrobat 9 pro. crashed while I added text boxes.. When I opened Adobe again, Yes to open the last file which didn't save correctly, then "Invalid Annotation Object" errors on my .pdf file of 96 pages
- first, I had to acknowledge/click the OK button until all " invalid annotation objects" error pop-up windows are gone
(for my file with 96 pages, i had to hit the OK button more than hundreds times - need patience)
- then found out (later) that what I did turn out to be the same steps as following post by davidsdomingo in adobe.forums
davidsdomingo May 28, 2009 1:39 PM (in response to (Holger_Wulf))
•Select the checkbox for "Extract Pages As Separate Files"
•Set the destination to a 'dedicated' folder that won't contain any other files -- that way, you can simply delete the folder when this process is done.
•Click OK.
- after extract the 96-pages file into individual files into a dedicated folder, only 95 got extracted and page 1 was not/can not be extracted.
- I then combined the 95 good extracted pages into a new file name .pdf
- then inserted a good page 1 without error (from the file that was saved previous day, prior to all the changes I made on the corrupted file), re work on page 1
- delete the bad file.
