I am trying to setup a password that goes from a motion tween to a stationary position where the password_ textfield and username_ textfield are then displayed. From their all I want is "if" the username_.text and password_.text match, gotoAndPlay(16) "else" textBox_.text = "invalid id". Thats it in a nutshell. Where in my script am I going wrong? It says "else is unexpected"? Please help ![]()
NOTE: The "id_.text = username_.text is something as just a "Logged in as:" thing, but that has only worked once, then I fiddled with the code some more as when it worked, it wasnt by the name or password, it was just "username_".
//startScript
enter_.addEventListener(MouseEvent.CLICK, loginEnter);
function loginEnter(event:MouseEvent):void {
if (username_.text === "Admin" && password_.text === "admin")
if (username_.text === "name" && password_.text === "pass1")
if (username_.text === "name" && password_.text === "pass2")
if (username_.text === "name" && password_.text === "pass3")
if (username_.text === "name" && password_.text === "pass4")
if (username_.text === "name" && password_.text === "pass5")
if (username_.text === "name" && password_.text === "pass6")
if (username_.text === "name" && password_.text === "pass7")
if (username_.text === "name" && password_.text === "pass8")
if (username_.text === "name" && password_.text === "pass9")
gotoAndPlay(16) && id_.text = username_.text
} else {
textBox_.text = "Incorrect ID";
//endScript
Thanks in advance! ![]()
har678
you should use one if statement and or instead of these i guess and why using ===? instead of == ?
if((username_.text == "Admin" && password_.text == "admin") || (username_.text =="name" && password_.text == "pass1")|| etc )
else
try this
i guess it should work
is this what you meant? Or just one line with "or" between the brackets?
//startScript
if(username_.text == "Admin" && password_.text == "admin");
} and or {
if(username_.text == "user" && password_.text == "pass");
} and or {
if(username_.text == "user1" && password_.text == "pass1");
} gotoAndPlay(16);
//endScript
action script takes or as this || u cant write or
you write this || and in the if loop u dont put semi colon
if((username_.text == "Admin" && password_.text == "admin") || (username_.text =="name" && password_.text == "pass1") || (username_.text == "name" && password_.text == "pass2") || ((username_.text == "name" && password_.text == "pass3") ||
you continue like this , get the idea
// ur condition goes here
else
is this a timeline script ?
Yes and it is seperate from the items on the main screen. Unfortunately all is working except the display name (id_.text) and gotoAndPlay(16). I am still tryin to work it out, but if you find a fault in the code below, may you please point it out ![]()
//startScript
if((username_.text == "Admin" && password_.text == "admin") || (username_.text =="name" && password_.text == "pass1"))
gotoAndPlay(16) && id_.text == "Welcome " + username_.text;
else
//endScript
enter_ = button
id_ = display name
textBox_ = status textfield
username_ = username textfield
password_ = password textfield
NOTE: The textfields are actually "Classic Text" "Input Text" bars, and the display name is a "Classic Text" "Dynamic Text" bar. They are not "TLF Text"
They were the details to what they equal.
After fiddling with the code a little more it is finally all working ![]()
//startScript
if((username_.text == "Admin" && password_.text == "admin") || (username_.text =="name" && password_.text == "pass"))
id_.text = username_.text;
gotoAndPlay(16);
else
textBox_.text = "Invalid ID";
//endScript
The problem I was facing is the "id_" and "textBox_" had to be "Dynamic Text" and the "username_" and "password_" had to be TFL Editable. As well as that, the "textBox_.text" and "id_.text" had to have one equal bar (=) instead of the suggested two (==), but all-in-all you helped me very well and I would never have figure that code if it werent for you ![]()
Thankyou! ![]()
Quote: mr.shumi
//startScript
gotoAndPlay(16);
else
//endScript
