RawrArt
Quotation marks look like ">" in one InDesign document
Mar 20, 2012 10:57 AM
Tags: #wrong #indesign #incorrect #quotation #symbol #> #weird #" #quote #quote_marks #quotation_marks #' #weird_symbol
At my job I am updating an old InDesign file in CS5 with new content. Whenever I press the " or ' I get >> or > (not exactly, but it's a symbol that looks very similar to  >> or >). I have never had this problem and can't understand why it is doing this. There is nothing else in the document that makes the wrong symbol when the key is pressed.
I am using a Mac and none of that stereotypical IT advice helps (reset the computer, open and close the program, etc.)
I also already went into preferences & selected typographer's quotes, then changed the quote settings in Preferences > Dictionary to be the correct typographer's quotes, but it makes no difference. I feel like this should have been the solution to the problem.
Any ideas? I'm getting tired of making the proper quote mark in another document and copy-pasting it whenever I want to use one (the only thing that works).
    Mar 20, 2012 11:02 AM   in reply to RawrArt
    You have  French assigned to the text.
    Mar 20, 2012 11:16 AM   in reply to RawrArt
    The solution is to change the language to English.
    Bob
    Mar 20, 2012 11:17 AM   in reply to RawrArt
    Check the Preferences > Dictionary > Double Quotes and Single Quotes (click the pull down to see various quote marks and select appropriate)
    Mar 20, 2012 11:52 AM   in reply to Bob Levine
    .. In addition, on itself changing the language assigned will NOT change the current characters (which are named "guillemots", by the way) into the Wnglish counterparts. You need to delete them and re-insert. But you can use Find-and-change for that.
    The link between preferences, language, and quotation marks is that the " and ' keys do NOT insert these symbols immediately. InDesign first checks the language that is applied to the text where you are inserting these characters. Hen it looks up in the Preferences for what actual characters to insert; and those end up in your document.
    Those "Dictionary" language settings are for something else.
    Mar 20, 2012 11:53 AM   in reply to [Jongware]
    "Wnglish" is a typo, rather than sth. like a Welsh-influence mix language ...
    Mar 20, 2012 11:58 AM   in reply to RawrArt
    I was referring to Language on the character palette or under advanced character formats in the paragraph styles palette.
    In my setup, as long as the language is English: USA, I always get English quotes. Changing the style of the quotes in Preferences has no effect. But it does have an effect if the language is English: Canadian (Adobe must figure  Canadians are bilingual or something.)
    Mar 20, 2012 12:00 PM   in reply to RawrArt
    You might try double checking your questions to make sure they’re clear.
    Bob
    Mar 20, 2012 12:22 PM   in reply to RawrArt
    and Jeffrey_Smith I said earlier that I already tried that. Please double-check your answers to make sure they are worthwhile!
    <<sorry>>
    Oops, I had French assigned... Let me change that, now let's see...
    "sorry"
    Message was edited by: Jeffrey_Smith
    Mar 21, 2012 7:47 AM   in reply to [Jongware]
    I've been blundering more than usual lately, so in all fairness I really should not draw attention to a  minor typo.  But then it turns out Adobe may be responsible for confusion over "guillemet" vs. "guillemot."
    David
