Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
Mar 19, 2012 7:58 AM
Tags: #export #gps #exif #lightroom4
I have updated GPS coordinates using the new Map module but these are not output with the EXIF when I export JPGs.
I have ensured that Remove Location Info is unchecked.
I welcome any advice
regards
JWW001
    Mar 19, 2012 8:00 AM   in reply to JWW001
    I had the same issue. It has to be toggled several times, then it's OK.
    Check it on, then off again, then save. See if the data  is being exported then.
    Mar 19, 2012 3:53 PM   in reply to JWW001
    Can you post a small JPEG, together with screen shots of the metadata panel and the export dialog here?
    Beat
    Mar 20, 2012 1:26 PM   in reply to JWW001
    OK, I can reproduce what you're seeing. It seems to be happening when exporting a JPEG file with updated GPS data as JPEG. Doesn't happen when changing GPS data on a Raw image and exporting it as JPEG (export contains updated information).
    I would report it as a bug here.
    Beat
    Mar 20, 2012 2:25 PM   in reply to JWW001
    What are the exact steps to produce with a Raw?
    Beat
    Mar 21, 2012 3:46 PM   in reply to JWW001
    OK, I now can see what you mean. It only happens on Raw files if they already contained GPS data in Raw-Exif while importing them.
    Beat
    Apr 7, 2012 9:43 AM   in reply to b_gossweiler
    This was happening to me when the original RAW did not have any GPS data, then added via Map view (and jf Geocodeing plugin via GPX file). I found that the suggestion above of cycling the "remove location info" checkbox in editing publish settings for my service did the trick.
    Steven
    Apr 8, 2012 6:08 AM   in reply to JWW001
    https://img.skitch.com/20120408-rpxkgd9thsg4y9c8ejf9dikif5.jpg
    Maybe your file still hold old data, as the Metadata Status has been changed and not updated?
    Apr 8, 2012 7:27 AM   in reply to JWW001
    Oh... Okay, I just saw that this question was not answered. Hope it gets solved for you!
    Apr 9, 2012 5:02 AM   in reply to JWW001
    I can confirm this behaviour of Geodata not being exported to JPG files by LR 4.0. It works fine for DNG and CR2 files, though.
    I wonder if this has already been fixed in LR 4.1 RC. Did you try LR4.1 already?
    Apr 10, 2012 1:19 PM   in reply to Guenther Blumenstock
    I try LR4.1 RC version but it doesn't works : my GPS coordinates are not output in my export JPGs. I don't understand.
    Note : My GPS coordinates have been saved in my origins JPGs, without problem.
