this is specific url blocking.
But not woking this.....
function pageDomainCheckInit(event:Event):void {
var url:String=stage.loaderInfo.url;
var urlBeginninng:Number=url.indexOf("://")+3;
var urlTermination:Number=url.indexOf("/",urlBeginninng);
var pageDomain:String=url.substring(urlBeginninng,urlTermination);
var LastDot:Number=pageDomain.lastIndexOf(".")-1;
var CharacterAfterDomain:Number=pageDomain.lastIndexOf(".",LastDot)+1;
pageDomain=pageDomain.substring(CharacterAfterDomain,pageDomain.length);
if (pageDomain!="www.somedomain.com/test/index.swf") {
warning_txt.text="This file is running on the wrong pageDomain. Content Access Restricted!";
closeBoxTop.visible = true;
} else {
warning_txt.text="Yes Player Visible";
closeBoxTop.visible = false;
stage.removeEventListener(Event.ENTER_FRAME, pageDomainCheckInit);
stage.addEventListener(Event.ENTER_FRAME, pageDomainCheckInit);
have u compared this
if (pageDomain!=www.somedomain.com/test/index.swf) {
if yes then use this
if (pageDomain!='www.somedomain.com/test/index.swf') {
i'm already put it. i selected xml text on top text edit options so..." " are missed.
I would suggest tracing out the value of pageDomain before your if statement to make sure it's what you think it is
I have worked this out in my head so excuse any mistakes
as you can see from my comments I think pageDomain will be something like somedomain.com and you are comparing it to "www.somedomain.com/test/index.swf"
// assume url = http://www.somedomain.com/test/index.swf
var url:String = stage.loaderInfo.url;
// url = http://www.somedomain.com/test/index.swf
var urlBeginninng:Number = url.indexOf("://") + 3;
var pageDomain:String = url.substring(urlBeginninng, urlTermination);
// pageDomain = www.somedomain.com
var CharacterAfterDomain:Number = pageDomain.lastIndexOf(".", LastDot) + 1;
pageDomain = pageDomain.substring(CharacterAfterDomain, pageDomain.length);
// pageDomain = somedomain.com
warning_txt.text=This file is running on the wrong pageDomain. Content Access Restricted!;
} else {
warning_txt.text=Yes Player Visible;
if i put : if (pageDomain!="somedomain.com")
that is woking.
but i want spacific url blocking like "www.somedomain.com/test/index.swf"
then you need to change this code to extract the exact domain you want
e.g. if you want to accept only "www.somedomain.com/test/index.swf"
then simply use something like
if (url != "www.somedomain.com/test/index.swf") {
} else {
different modifications will be needed if you want
only "www.somedomain.com/test/"
or "www.somedomain.com/"
or any other script.
finally i put this: (url != "http://www.prasaar.com/dev/trials/vss/index.swf");
this is woking.
how to validate "http" ?
what do you mean validate http?
you want to test against www.prasaar.com/dev/trials/vss/index.swf rather than http://www.prasaar.com/dev/trials/vss/index.swf?
play around with the string manipulation and trace out the final pageDomain until it's in the format you want
use something like this:
var pageDomain:String = url.substring(urlBeginninng);
if (pageDomain!="www.prasaar.com/dev/trials/vss/index.swf") {
} else {
not working this www.somedomain.com/test/index.swf
working this http://www.somedomain.com/test/index.swf ?
But should n't work in .html main page. i mean play normally.
or
How to get current url not swf path ( like www.somedomain.com/test/index.html).
finally want i mean my swf file work in through html webpage.
if any one enter total swf path then file not download.
there is no real way to find out the html page. You might use externalinterface to talk to the page from the movie.
Now, what actually do you want to achieve by not allowing visitors to view the swf without its surroundings?
