I have a form which is flowed and the rows and table are set to allow page breaks. However, when a cell has more content than will fit on a certain page, it does not go to the next page, it just runs off the end of the page. Does anyone know why?
You need to set up the page as Flowed, so that the content will flow correctly. See this example here that shows the steps in setting up a flowed form with tables: http://assure.ly/gk8Q7a. Also this which looks at Poitioned versus Flowed layouts: http://assure.ly/eSGQMt and http://assure.ly/e2jR0C.
Hope that helps,
Niall
Thanks Niall. From what I can tell, the subform which the table is in is Flowed. The dynamic table is fine. When I add rows everything moves appropriatly and it will even create rows on the next page. The problem only occurs when one cell expands larger than the lengeth of the paper. For instance, on the example you sent me, if the cell that contained "banannas" or "apples" contained enough copy that it expands larger than the whole length of the paper, the copy runs off the end of the page. Does that make sense?
When you say containers up the hierarchy, what do you mean? I have Allow page breaks in content ticked on each of the rows in the table as well as on the whole table itself and the data still flows off the page. I am wondering if it will allow a single cell to be split between two pages. I haven't seen any example where that is the case. A whole table can be split, but can one cell of a table be on two dofferent pages. (I wish my employees would just write less, lol!)
Hey Niall,
Just wanted to see if you had a chance to take a glace at that document. I've looked at it for 3 days and just can't seem to figure out how to make it work. I'm not sure the software supports the ability to spilt one cell between two pages. But not knowing is making me a little crazy. Thanks.
I have had a look. I think you would be better off with flowed subforms instead of tables (given your layout). Buttons and dropdowns will not break over pages in a table, whereas in a subform they will stay at the top of their subform, while other elements break over the page.
Also I would lose a lot of the redundant pages.
Niall
