I discovered that my actions imported from CS4, which contain preset dimensions for the crop window, do not function as written UNLESS the crop tool is activated before running the action. These actions are designed to open the crop window at a specific dimension, then stop, allowing me to move the crop window to the desired postion, then continue with the cropping and, finally, interpolation back to original image dimensions. However, in CS6, if you run these actions with any tool enabled OTHER THAN THE CROP TOOL, the crop window appears at the perimeter of the image. With the crop tool enabled, the actions function as written. Hopefully you can fix this before the final release.
I'm running Win 7 Pro on 64 bit machine, and the above problem occurred running the 32 bit CS6.
Mike
#3145092
Patti,
Here's a screen capture of the crop action. The action is designed to stop at the first step, allowing me to drag the crop box to wherever I want. The box normally appears roughly centered. However, in CS6, this only works if the crop tool is pre-selected before running the action. If any other tool is active, the crop box expands to the perimeter of the image.
Mike
Thanks for all the feedback here, I think we understand the issue and we will add it to our known issues.
FAQ: What are the known issues so far in Photoshop CS6 Beta
Pattie
