Problems with new crop functions and old crop actions
Mar 22, 2012 11:55 AM
Tags: #watson #pbf
I discovered that my actions imported from CS4, which contain preset dimensions for the crop window, do not function as written UNLESS the crop tool is activated before running the action. These actions are designed to open the crop window at a specific dimension, then stop, allowing me to move the crop window to the desired postion, then continue with the cropping and, finally, interpolation back to original image dimensions. However, in CS6, if you run these actions with any tool enabled OTHER THAN THE CROP TOOL, the crop window appears at the perimeter of the image. With the crop tool enabled, the actions function as written. Hopefully you can fix this before the final release.
I'm running Win 7 Pro on 64 bit machine, and the above problem occurred running the 32 bit CS6.
Mike
#3145092
    Mar 22, 2012 10:29 AM   in reply to mfurtman
    you can set the crop tool to behave like the old one (classic mode).
    that doesn´t  help?
  • PECourtejoie
    Jan 11, 2006
    Mar 22, 2012 10:30 AM   in reply to mfurtman
    Hi, it is possible to record tool selection, and also through tool presets selection.
    Mar 22, 2012 11:04 AM   in reply to mfurtman
    Can I get one of the actions in question so we can see what it is being asked to do?
    Pattie
    Mar 22, 2012 1:01 PM   in reply to mfurtman
    Thanks. Sounds like QE is able to reproduce. We'll investigate.
    Mar 22, 2012 11:57 AM   in reply to mfurtman
    Thanks. Good to have that additional info. Appreciate the report.
  • PECourtejoie
    Jan 11, 2006
    Mar 22, 2012 1:02 PM   in reply to mfurtman
    Mike, did using a tool preset in the action to select the crop tool works, as suggested higher?
    Mar 23, 2012 11:37 AM   in reply to mfurtman
    Thanks for all the feedback here, I think we understand the issue and we will add it to our known issues.
    FAQ: What are the known issues so far in Photoshop CS6 Beta
    Pattie
