Hello,
I have a problem with the comparison of strings:
If I compare the values 0,5 and 5,0 I will get the result that the values are equal (Case 1).
If I compare the values 0.5 and 5.0 the comparison will be correct (Case 2).
If I compare the values with the method 'compare()' the comparison is correct (Case 3).
Why is the result of case 1 wrong? Is there an explanation or is this a bug?
<cfscript>
// wrong comparsion
writeoutput("Case 1: comparsion with 'if' and '==' <br>");
string_one = "0,5";
string_two = "5,0";
writeoutput("values: <font color=green>String one: #String_one#</font> - <font color=red> String Two: #string_two#</font><br><br>");
if (string_one == string_two) {
writeoutput("wrong result after the comparsion: #string_one# is not #string_two#<br><br>");
else {
writeoutput("right result after the comparsion: #string_one# is not #string_two#<br><br>");
writeoutput("===============================<br>");
// right comparsion
writeoutput("Case 2: comparsion with 'if' and '==' <br>");
string_three = "0.5";
string_four = "5.0";
writeoutput("values: <font color=green>String three: #String_three#</font> - <font color=red> String four: #string_four#</font><br><br>");
if (string_three == string_four) {
writeoutput("wrong result after the comparsion: #string_three# is not #string_four#<br><br>");
else {
writeoutput("right result after the comparsion: #string_three# is not #string_four#<br><br>");
// right comparsion
writeoutput("Case 3: comparsion with 'compare' <br>");
string_five = "0,5";
string_six = "5,0";
writeoutput("values: <font color=green>String five: #String_five#</font> - <font color=red> String six: #string_six#</font><br><br>");
if (compare(string_five,string_six) EQ 0){
writeoutput("wrong result after the comparsion: #string_five# is not #string_six#<br><br>");
else{
writeoutput("right result after the comparsion: #string_five# is not #string_six#<br><br>");
writeoutput('</strong>');
</cfscript>
Someone from Adobe has explained this to me. Believe it or not, both "0,5" and "5,0" - to CF - mean 0th May 2012... which equates to 30 April 2012 ("of course" we all cry, whilst slapping our foreheads ;-).
Example:
<cfset d1 = "0,5">
<cfset d2 = "5,0">
<cfoutput>
#dateFormat(d1)#<br />
#dateFormat(d2)#<br />
</cfoutput>
Sometimes I am still astounded by CF.
Not in a good way.
Adam
That is so weak, and is the kind of thing that's making me lean away from CF and towards strongly-typed languages like C#. That's just stupid.
That's a polite version of what I said to the Adobe chap (not that it was his fault, but he was the one in my line of fire at the time. I shoot the messenger on a regular basis too ;-).
Adam
Owain North wrote:
I'd imagine it's evaluating it as a list, and the two lists are the same despite ordering.
Difficult for us to sell, isn't it?
Does indeed make the eyes water.
It gets even better.
<cfif "0,0000005" eq "5,0">
EQ
<cfelse>
NEQ
</cfif>
gave me EQ.
Speedtossi,
Referring to the news Adam brought from Adobe, I was also surprised when I first found out that isDate("0a") and isDate("3p") both return Yes. I suppose the moral is, when comparing strings, use compare or compareNoCase. When comparing numerical values, don't surround them with quotes.
Came across this while trying to find a solution wondering if anybody can point me in the right direction
I have two lists, let's say
list1="a,b,c,d"
list2="b,c,d,a"
Is there a quick and easy way to compare the two lists and see if they have exactly the same elements or differ in some way, I don't need to know how they differ, just that they are indeed different, order is not relevant to me either, just the values in the list.
Using COMPARE does not work as it just seems to look at it as a string rather than a list
Without getting into loops and code, is there a command for this (I am using CF8)
Btw Just to clarify list1 would be a #valuelist()# from a SQL query, the other one would already exists as a hard coded list <CFSET list2="">
Mark
I was just about to post
I took a step back and made sure that the hard coded list was always sorted, and also applied an ORDER to the SQL statement, then when the hard coded one was recreated using a script that creates a script I made sure it was sorted, so the ORDERED SQL would always match, that way I was indeed able to utilize a straight forward EQUALS command.
I am surprised that CF does not have a tag that allows for list comparison in the same way a string can be compared.
Thanks for the input
Mark
Well you can use any string function you like on a list: lists are just strings with a notion of an element delimiter after all. So to test two lists for equality, one can use the compare() or compareNoCase() functions. Or in most situations just the EQ operator will suffice.
However CF lists are ordered, so if you want to implement the concept of an "unordered list" (which is a completely legitimate notion), then it's also up to you to implement the functionality to deal with them.
Adam
In my case the list is not ordered, or certainly was no initially ordered, it was originally manually created and hard coded, but it was being overwritten when required by CF and recreated, so I just had to use ORDER in the SQL so that when I came back to do the compare it was the same as the next ORDER SQL.
The only way that COMPARE would give the desired result on a list is if both lists were in the same order, as robots12 above pointed out, you need to sort them both
