jose_torres_2
Ps CS6 slower than Ps CS5
Mar 22, 2012 2:18 PM
Tags: #and #cs5 #ps #choppy #layers #multiple #move #cs6 #than #slower
I work with multiple layers on a .psd document quite frequently and I occasionally have to select and move multiple layers as well. As I do that on Ps CS6, I notice that movement is very choppy and much slower than on CS5. Is there a way to optimize this? I'm using Ps CS6 beta on a Windows 7 Enterprise PC with 8gb ram, Intel Core2 Quad Core 2.5GHz processor and a ATI Radeon HD 4650 graphics card if that helps.
Branched to a new discussion.
    Mar 22, 2012 2:57 PM   in reply to jose_torres_2
    Try disabling OpenGL drawing in preferences, then restarting Photoshop.
    CS6 shouldn't be any slower, but we did add more GPU support and could be hitting bugs in video drivers.
    Also, it would be a good idea to update your video card driver from the ATI web site.
    Mar 22, 2012 3:46 PM   in reply to jose_torres_2
    Same spot, but now labelled "Use Graphics Processor".
    Mar 22, 2012 3:53 PM   in reply to Chris Cox
    I am on Winodws 7 (64 Bit) and  so far I can't see that Photoshop CS6 is slower than PS5. Even more,  CS6 is sugnificantly  faster.
  • Noel Carboni
    Dec 23, 2006
    Mar 22, 2012 4:31 PM   in reply to jose_torres_2
    Have you fully configured CS6 for RAM use, and to use your proper scratch drive?
    -Noel
    Mar 22, 2012 6:25 PM   in reply to jose_torres_2
    Well, we don't know why your machine is showing choppy redraws or taking so much time -- that isn't happening for most people.
    Someone from QE will need to follow up with you and figure out what is going wrong with your system.
    Mar 23, 2012 11:55 AM   in reply to jose_torres_2
    Just a quick post to confirm that PhotoShop CS6 UI elements are also slower than PhotoShop CS5 on my system:
    Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
    Operating System: Mac OS 10.7.3
    System architecture: Intel CPU Family:6, Model:37, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
    Physical processor count: 2
    Logical processor count: 4
    Processor speed: 2400 MHz
    Built-in memory: 8192 MB
    Free memory: 4579 MB
    Memory available to Photoshop: 6847 MB
    Memory used by Photoshop: 70 %
    Image tile size: 128K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    OpenGL Version: 2.1 NVIDIA-7.18.11
    OpenCL Unavailable
    Video Card Vendor: NVIDIA Corporation
    Video Card Renderer: NVIDIA GeForce GT 330M OpenGL Engine
    Display: 2
    Display Depth:= 32
    Display Bounds:=  top: 390, left: -1680, bottom: 1440, right: 0
    Video Renderer ID: 16918034
    Video Card Memory: 205 MB
    Video Rect Texture Size: 8192
    OpenCL Unavailable
    Display: 1
    Main Display
    Display Depth:= 32
    Display Bounds:=  top: 0, left: 0, bottom: 1440, right: 2560
    Serial number: Tryout Version
    Application folder: SledgeHammer:Applications:Adobe Photoshop CS6:
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      SledgeHammer (this is an OWC SSD drive), 446.8G, 217.8G free
    Required Plug-ins folder: SledgeHammer:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
    Primary Plug-ins folder: SledgeHammer:Applications:Adobe Photoshop CS6:Plug-ins:
    Additional Plug-ins folder: not set
    Installed components:
       adbeape.framework   adbeape   3.3.8.19346   66.1025012
       AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
       adobe_caps.framework   adobe_caps   5.0.11.0   1.256674
       AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
       AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
       AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
       AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
       AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
       AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
       AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
       AdobeLinguistic.framework      17206
       AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
       AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
       AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
       AdobePDFSettings.framework   AdobePDFSettings   1.4
       AdobePIP.framework   AdobePIP   6.0.0.1642
       AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
       AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
       AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
       AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
       ahclient.framework   ahclient   1.7.0.56
       aif_core.framework   AdobeAIF   3.0.00   62.490293
       aif_ocl.framework   AdobeAIF   3.0.00   62.490293
       aif_ogl.framework   AdobeAIF   3.0.00   62.490293
       AlignmentLib.framework   xcode   1.0.0.1
       amtlib.framework   amtlib   6.0.0.75
       boost_date_time.framework   boost_date_time   6.0.0.0
       boost_signals.framework   boost_signals   6.0.0.0
       boost_system.framework   boost_system   6.0.0.0
       boost_threads.framework   boost_threads   6.0.0.0
       Cg.framework   NVIDIA Cg
       CIT.framework   CIT   2.0.5.19287   145486
       data_flow.framework   AdobeAIF   3.0.00   62.490293
       dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
       dvacore.framework   dvacore   6.0.0.0
       dvamarshal.framework   dvamarshal   6.0.0.0
       dvamediatypes.framework   dvamediatypes   6.0.0.0
       dvaplayer.framework   dvaplayer   6.0.0.0
       dvatransport.framework   dvatransport   6.0.0.0
       dvaunittesting.framework   dvaunittesting   6.0.0.0
       dynamiclink.framework   dynamiclink   6.0.0.0
       FileInfo.framework   FileInfo   66.145433   66.145433
       filter_graph.framework   AdobeAIF   3.0.00   62.490293
       hydra_filters.framework   AdobeAIF   3.0.00   62.490293
       ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
       ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
       image_compiler.framework   AdobeAIF   3.0.00   62.490293
       image_flow.framework   AdobeAIF   3.0.00   62.490293
       image_runtime.framework   AdobeAIF   3.0.00   62.490293
       LogSession.framework   LogSession   2.1.2.1640
       mediacoreif.framework   mediacoreif   6.0.0.0
       PlugPlug.framework   PlugPlug   3.0.0.383
       UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
       wrservices.framework
    Required plug-ins:
       3D Studio 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
       ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
       Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Average 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
       Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Cineon 13.0 20120305.m.415 2012/03/05:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
       Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Collada DAE 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crop and Straighten Photos 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
       Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
       Difference Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Eazel Acquire 13.0 20120305.m.415 2012/03/05:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
       Embed Watermark NO VERSION - from the file “DigiSign.plugin”
       Enable Async I/O 13.0 20120305.m.415 2012/03/05:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
       Entropy 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       FastCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
       Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Flash 3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Google Earth 4 KMZ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
       IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       JPEG 2000 13.0 20120305.m.415 2012/03/05:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
       Kurtosis 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
       Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
       Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
       Matlab Operation 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Maximum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mean 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Measurement Core 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
       Median 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Minimum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       MMXCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
       Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Multiprocessor Support 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
       Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       NTSC Colors 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
       Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
       OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       PCX 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
       Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Photoshop 3D Engine 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
       Picture Package Filter 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pixar 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
       Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Portable Bit Map 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
       Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Radiance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
       Range 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Read Watermark NO VERSION - from the file “DigiRead.plugin”
       Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
       ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
       Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Skewness 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Solarize 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
       Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Standard Deviation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Summation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       U3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
       Variance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wavefront|OBJ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wireless Bitmap 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
       ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash: NONE
    Installed TWAIN devices: NONE
    Mar 23, 2012 12:35 PM   in reply to aaronrdeutsch
    Aaron,
    I see that you are running dual monitors (or one external + your laptop), is the performance bad on both monitors or just one?  Also do you have Rulers showing for your documents?
    Adam
    Mar 23, 2012 12:57 PM   in reply to Adam Jerugim
    Hi Adam,
    I was using the dual monitors prior to the upgrade from PhotoShop CS5 to PhotoShop CS 6 Beta which was the basis for my comparison.
    That said:
    • I normally *do* display rulers, though turning them off does not seem to make a big difference
    • The jerkiness of scrolling and changing tools might be *slightly* less when only using my laptop monitor, but not much
    • The files I'm working on these days are about 90MB and contain almost 400 layers. Combine that with a 2560x1440 display and a 1680x1050 display with a 256MB mobile graphics card and I presume I'm starting to push it a little
    • In PhotoShop -> Preferences -> Performance -> Graphics Processor Settings -> Advanced Settings I've tried a few diff settings and didn't notice a difference so I left it on "Normal". "Use Graphice Processor to Accelerate Computation" and "Use OpenCL" are grayed out on my machine.
    Cheers.
    Mar 23, 2012 1:08 PM   in reply to jose_torres_2
    Wanted to chime in to say that I'm also experiencing noticeable sluggishness compared to CS5.5
    Software  Mac OS X Lion 10.7.3 (11D50)
    Hardware:
    Processor  2 x 2.8 GHz Quad-Core Intel Xeon
    Memory  10 GB 800 MHz DDR2 FB-DIMM
    Graphics  NVIDIA GeForce 8800 GT 512 MB
    I work with 2 monitors (1920x1200 & 1600x1200) and almost always have rulers displayed.
    As the original poster mentioned, where I'm seeing the biggest hiccups is when I have multiple layers selected and I'm either trying to nudge with keyboard, or move with the mouse the selected layers.
    Mar 26, 2012 2:27 AM   in reply to jose_torres_2
    I also have these problems, nudging multiple layers using the arrow keys takes around 5-7 seconds for 1 (px) nudge. Moving the same layer group using the mouse is almost impossible, the lag is enourmous.
    The file is actually quite small (~15MB), but there are some layers in it.
    Rulers are visible.
    EDIT: Interestingly, this only happens when using the arrow keys with the move tool. When hitting CMT+T and then changing x and y values directly or even with the arrow keys (up and down) speed is almost on par with CS5.
    Message was edited by: Florian Grau
    Mar 26, 2012 7:17 AM   in reply to jose_torres_2
    Also - turning on and off visibility has about a half second lag.
    This is the case on a file i'm bringing in from cs5.5 that's 1200x1600, weighs in at 207.5 MB and has roughly 200 or so layers with all kinds of smart objects, shape layers, raster layers, adjustment layers, etc.
    Mar 26, 2012 1:44 PM   in reply to majmanCS6
    Can someone do me a favor and take a file that performs well in CS5 (or CS5.5) and re-save the file in CS6?  Re-open the newer file created in CS6 and see if the performance problems persist.
    Adam
    Mar 26, 2012 1:46 PM   in reply to Adam Jerugim
    As one who decided to dive right in and use PhotoShop CS6 Beta for production work I can say that I've done this and the problems persist and can be pronounced.
    Does the new x/y indicator next to the cursor require lots of maths if you are moving multiple items? Many of my moves are groups that contain multiple layers and it puts some serious hurt on my machine--and I have 8GB of RAM and an SSD drive.
    Mar 26, 2012 1:50 PM   in reply to aaronrdeutsch
    One more thing to try - hide the layers palette (just switch to the channels palette) and see if performance is better.  We've got a few performance threads we're trying to follow here on the forums and I need to know if the two issues are related.
    Thanks again,
    Adam
    Mar 26, 2012 1:53 PM   in reply to Adam Jerugim
    Well that is interesting!
    Turning off the layers palette greatly improves the performance. I can actually see my layers move while I'm dragging them!
    Bummer that you have to have the palette on to select the layers to move, but I'm sure you guys/gals will get that worked out.
    Thx.
    Mar 26, 2012 2:59 PM   in reply to aaronrdeutsch
    And yet another thing to try:  go to the layers palette and choose Panel options... from the flyout menu.  Change thumbnail size to "None" and try this again with the Layers palette showing.  Still seeing a performance hit?
    Thanks again,
    Adam
    Mar 26, 2012 3:02 PM   in reply to Adam Jerugim
    Turning off thumbnails provides a similarly massive improvement in performace to turning off the visibility of the layers palette.
    Thx.
    Mar 26, 2012 3:58 PM   in reply to jose_torres_2
    Hi Adam -
    Closing the layer palette and/or selecting "none" for thumbnail size in the panel options made a huge difference.
    I had already opened a previously well-performing file in cs5.5 - saved it in a cs6, restarted cs6 and opened the file again. Performance was the same.
    Pressing tab to hide all panels and then moving stuff around also seems to perform well.
    let us know if we should try anything else.
    Mar 27, 2012 12:13 AM   in reply to jose_torres_2
    Seems to be the Thumbnails - disabling them/hiding the layer palette significantly increases the performance for me.
    Mar 27, 2012 6:09 AM   in reply to jose_torres_2
    yeah having the same issue aswell, seems like most people are. Used cs6 at work, moving multiple pictures on different layers around and it is reeeeally slow compared to cs5. Like a near deal breaker.   I hope adobe fixes this before the full release, hiding layers panel/thumbnail is only solution for now i suppose.
    Mar 29, 2012 7:52 AM   in reply to jose_torres_2
    I'm also seeing the huge performance issues with moving multiple layers. And I also saw a huge performance increase (not quite on par with cs5, but close) when I disabled thumbnails in the layer palette.
    Mac OS X 10.6.8
    Hope this can be fixed soon! Thanks!
    Mar 29, 2012 9:06 AM   in reply to jose_torres_2
    One more wrench to throw into the mix. I'm seeing the same lag issue as discussed here on my Mac (quad core i7 2.8Ghz, 12GB Ram, Radeon HD 4850, OSX 10.6.8). Using a large file 55mb with lots of layers (web interface) the system lags so much that I see no change for several minutes when dragging a layer group and sometimes even get a beachball at the system level.
    As a quick note: hiding the thumbnails in the layers pallet did help with performance but its by no means ideal even with that tweak.
    The funny thing is that the exact same file sees much less of a performance impact on my Windows box (Windows 7 Ultimate 64bit, AMD Phenom 2 x6 3.0Ghz, 16GB Ram, Radeon HD 4890). Typically my experience is opposite of that with the Mac performing slightly better. I usually assume that the AMD chip isn't quite as good at single threaded applications as the i7 but performs very well for heavily multi-threaded apps. Is there a chance we're seeing PS's multi threading come into play? I would think GPU and Ram differences between my two setups would be neglibable espcially with the slightly less efficiant Windows OS taking more resources.
    Let me know if there are other things you'd like tested. I'd love to get this issue figured out since its currently a deal breaker for me to be a viable upgrade.
    Apr 9, 2012 10:31 PM   in reply to jose_torres_2
    I think I figured out something else with respect to this issue. I am having the same performance problems with moving layers and panning around my document. When space panning around a large comp I realized that performance is VASTLY improved if I close any panel that is floating on top of the actual canvas itself. Doesn't matter if it's the layers panel, the character panel, etc - if there is a panel that is floating on top of my document - I get a huge performance / display redraw hit. If all pannels are docked or hidden, everything performs better.
    Apr 13, 2012 2:27 AM   in reply to fmotion
    Having the same problem and it's extremely frustating when working in a +500 layers file. As fmotion said, when i disable the Layers panel the performance gets much better - Please do something about this huge issue (Chris Cox).
    Apr 19, 2012 3:16 AM   in reply to jose_torres_2
    Hi, same story here on an iMac 27" with and without GPU acceleration moving multiple layers is a pain.
    PS has 10 Go of RAM and I do webdesign, it is the first time I have to wait for moving layers.
    Right now moving a group of 60 layers (text and vector) from 1 pixels to one direction takes up to 10 seconds.
