Sunrider69
Exporting FLA to AVI/MOV
Mar 21, 2012 4:53 AM
I'm creating a short promotional video which has been created in Flash. I've broken it down into modules for easy editing and then want to export them individually into a video file so I can stitch them all together in a suitable video editing software to create one video.
I've done this however the output quality is pretty low. It needs to be displayed on a 42" monitor at a trade show so quality is an issue. Can anyone advise me on the best settings in Flash for optimum video export quality or indeed offer any other advice that'll provide me with the output I require.
    Mar 22, 2012 1:50 PM   in reply to Sunrider69
    Other than get a proper video CGI app like After Effects? Probably the only thing you can do is hope you used a lot of vector graphics which will upscale fairly gracefully. If you used a lot of bitmaps you're pretty much up the creek, especially if you didn't even do it at least 1280x720. You'd have to go back and retool any tiny bitmaps or they will simply get blurry as heck.
    During exporting you can choose any resolution you want. You can choose 1920x1080 if you wish. Just export your movie at 1920x1080 and take a look at it. If it's acceptable then you need not do anything else.
    In the future, definitely start with the highest possible resolution you may need. It's standard in video to produce in at or above the resolution of your target (typically larger) and then reduce size. It has a nice smoothing effect and you'll never be in this situation again.
    Mar 23, 2012 6:55 AM   in reply to Sunrider69
    Glad you got it to work!
    Mar 25, 2012 10:53 PM   in reply to Sunrider69
    Actually, you can use a third-party tool like moyea or sothink to convert swf to HD video.
