mouse over effect
Mar 23, 2012 2:52 AM
Dear all
I am watched a website nicely done a mouse over link  look "Postgraduate studies, Undergraduate Studies etc.." how can this do please help me
web link
    Mar 23, 2012 4:26 AM   in reply to manojb05
    The link you show appears to just be using a mask that drops down over the content that appears when you rollover the button (movieclip)
    If you search Google using terms like "AS3 animated button tutorial" you should find some useful tutorials to get you started.
    Mar 23, 2012 5:33 AM   in reply to manojb05
    YOu can do the same using AS2, only the code would be different.  If you understand how to make rollover/rollout code, then you should be able to read/follow either an AS2 or an AS3 tutorial.  IN any case, if you search using "AS2 animated button tutorial" there are several results that should be helpful to you.
    The basics of the scheme are that when you rollover the button (actually a movieclip) you trigger an animation within the button and when you rollout of the button you play the reverse of that animation.  You can do the animations as timeline animations or as coded animations.
    Mar 23, 2012 6:04 AM   in reply to manojb05
    Here is a link to a sample file that shows the two different ways I mentioned it could be done.  There are other ways as well, but these should at least get you started.
    http://www.nedwebs.com/Flash/AS2_Animated_Btns.fla
    Mar 23, 2012 6:18 AM   in reply to manojb05
    Yes, it is working
    Mar 23, 2012 7:09 AM   in reply to manojb05
    I can't help you there.  The link works fine and the file I get opens fine.
    Mar 23, 2012 7:49 AM   in reply to manojb05
    Look up the getURL() function
    Mar 24, 2012 4:33 AM   in reply to manojb05
    In an onRelease function, similare to the rollover and rollout
    yourBtn.onRelease = function(){
        getURL(http://www...);
    Mar 24, 2012 5:22 AM   in reply to manojb05
    You can change it to suit your needs.
