Dear all
I am watched a website nicely done a mouse over link look "Postgraduate studies, Undergraduate Studies etc.." how can this do please help me
YOu can do the same using AS2, only the code would be different. If you understand how to make rollover/rollout code, then you should be able to read/follow either an AS2 or an AS3 tutorial. IN any case, if you search using "AS2 animated button tutorial" there are several results that should be helpful to you.
The basics of the scheme are that when you rollover the button (actually a movieclip) you trigger an animation within the button and when you rollout of the button you play the reverse of that animation. You can do the animations as timeline animations or as coded animations.
i am click the link some code is come like this
ÐÏ à¡± á> þÿ : þÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿRoot Entry ÿÿÿÿÿÿÿÿ pª|YªrÏ ƒ RASH°ÌECõ Í < Contents ÿÿÿÿÿÿÿÿÿÿÿÿKAIP 1 1332506058 ÿÿÿÿI S 2 1332506249 ÿÿÿÿB› ;ýÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿþÿÿÿ=>?@ABCDEFGHIJþÿÿÿLMNOPQRSTUVWXYZ[\]^_`abc defghijklmnoþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿRoot Entry ÿÿÿÿÿÿÿÿ pª|YªrÏ ƒ RASHP æïô Í Contents ÿÿÿÿÿÿÿÿÿÿÿÿ AIP 1 1332506058 ÿÿÿÿI S 2 1332506249 ÿÿÿÿB› ÿÿÿÿÿÿÿÿ ýÿÿÿþÿÿÿþÿÿÿ
þÿÿÿ !"#$%&'()*+,-./0123456789þÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿS 1 1332506097 ÿÿÿÿÿÿÿÿÿÿÿÿ l S 3 1332506736 ÿÿÿÿÿÿÿÿÿÿÿÿä ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
þÿÿÿ !"#$%&'()*+,-./0123456789:;<=>?@AþÿÿÿCDEFGHþÿÿÿJKLMNOPQRSTUVWXYZ[\]^_ `abcdefghijklmnopqrstuvwþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame €€ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ ÿÿÿ?ÿÿÿþÿ ïuÿþÿÿþÿ €€ ÿþÿ extended buttonÿÿÿÿ™3Ìÿ € € ÿÿ
CPicSprite 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ I,ÿþÿÿþÿ msk ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ WFÿþÿÿþÿ €€ ÿþÿ maskÿÿÿÿÿÿOÿ € € €€ ÿ ÿ ÿó @ ì0Àù0 0@ ÿÿÿ?ÿÿÿþÿ a<ÿþÿÿþÿ €€ ÿþÿ main button ÿÿÿÿOÿOÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame €€ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ ÿÿÿ?ÿÿÿþÿ ÌHÿþÿÿþÿ €€ ÿþÿ extended button ÿÿÿÿ™3Ìÿ € € ÿÿ
CPicSprite 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ ¿`ÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ SWÿþÿÿþÿ € € Ð ô ÿÿÿÿÿþÿ ¿ ÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.2'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ Ö<ÿþÿÿþÿ € € 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ Öjÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ /ÿþÿÿþÿ €€ ÿþÿ
animated mask ÿÿÿÿÿÿOÿ € € €€ ÿ ÿ ÿó @ ì0Àù0 0@ ÿÿÿ?ÿÿÿþÿ ~ ÿþÿÿþÿ €€ ÿþÿ main buttonÿÿÿÿOÿOÿ € € €€ ÿÿÿ?ÿÿÿþÿ -Bÿþÿ stop();ÿþÿ € €€ ÿÿÿ?ÿÿÿþÿ ÜTÿþÿ stop();ÿþÿ € €€ ÿÿÿ?ÿÿÿþÿ Ž6ÿþÿ gotoAndStop(1);ÿþÿ €€ ÿþÿ actions ÿÿÿÿÿOÿÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame ÿÿ CPicShape €€ ìÿÿÿ þÿÿ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ€€ ÿÿÿ?ÿÿÿþÿ g\ÿþÿÿþÿ €€ ÿþÿ Layer 1 ÿÿÿÿOÿOÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame ÿÿ
CPicSprite ” ” t ÿÿÿÿÿþÿ É#ÿþÿÿþÿ btn_timeline ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1'>
</component>
€€ Ø h Ø h éêÿÿø éêÿÿø ÿÿÿ?ÿÿÿþÿ ê3ÿþÿÿþÿ €€ ÿþÿ Layer 1ÿÿÿÿOÿOÿ € € € • Ž ÿÿÿÿÿþÿ ƒyÿþÿÿþÿ btn_tween ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ f
ÿþÿÿþÿ €€ ÿþÿ Layer 3ÿÿÿÿÿÿOÿ € € €€ ÿÿÿ?ÿÿÿþÿ ÿ/ÿþÿÿ´ // here is the code for the button that has the animation built into it
btn_timeline.onRollOver = function(){
btn_timeline.gotoAndPlay(2);
btn_timeline.onRollOut = function(){
btn_timeline.gotoAndPlay(16);
// HEre is the code for the version where actionscript is used to animate the mask
import mx.transitions.Tween;
import mx.transitions.easing.Regular;
btn_tween.onRollOver = function(){
tweenTo(25); // _ending _y value is 25
btn_tween.onRollOut = function(){
tweenTo(-111); // _ending _y value is -111
var tw:Tween;
function tweenTo(yValue){
tw = new Tween(btn_tween.msk, "_y", Regular.easeIn, btn_tween.msk._y, yValue, 0.5, true);
ÿþÿ €€ ÿþÿ Layer 2 ÿÿÿÿ™3Ìÿ €€ ? ÿÿ
CDocumentPage P 1 1332506058ÿþÿ Scene 1ÿþÿ ÊmlO
ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ³slOÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿ€€€€ € S 2 1332506249ÿþÿ Symbol 2 ÿþÿ ‰nlO ÿþÿÿþÿÿþÿ ÿþÿÿþÿ Symbol 2 ÿÿÿÿÿþÿ‰nlOÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ ÿþÿÿþÿÿþÿÿþÿ€€€€ € S 1 1332506097ÿþÿ Symbol 1 ÿþÿ ñmlO ÿþÿÿþÿÿþÿ ÿþÿÿþÿ Symbol 1 ÿÿÿÿÿþÿ‡olOÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿ€€€€ € S 3 1332506736ÿþÿ Symbol 3 ÿþÿ pplO
ÿþÿÿþÿÿþÿ ÿþÿÿþÿ
Symbol 1 copy ÿÿÿÿÿþÿ–qlOÿþÿÿþÿ ÿþÿÿþÿÿþÿ ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿ ÿþÿÿþÿ ÿþÿÿþÿÿþÿÿþÿ€€€€ ø*@ h h h h h ÿÿÿÿÀÀÀÿ ´ ÿþÿ legacyLineSpacingÿþÿ 0 ¢ÿþÿ%PublishFormatProperties::htmlFileNameÿþÿ Untitled-1.htmlÿþÿ"PublishHtmlProperties::StartPausedÿþÿ 0ÿþÿ Vector::AS3 Package Pathsÿþÿÿþÿ PublishRNWKProperties::speed256Kÿþÿ 0ÿþÿ!PublishGifProperties::PaletteNameÿþÿÿþÿ PublishFormatProperties::jpegÿþÿ 0ÿþÿ PublishHtmlProperties::Loopÿþÿ 1ÿþÿ PublishProfileProperties::nameÿþÿ Defaultÿþÿ Vector::Debugging Permittedÿþÿ 0ÿþÿ Vector::UseNetworkÿþÿ 0ÿþÿ"PublishQTProperties::MatchMovieDimÿþÿ 1ÿþÿ PublishQTProperties::AlphaOptionÿþÿÿþÿ PublishQTProperties::LayerOptionÿþÿÿþÿ4PublishHtmlProperties::UsingDe faultAlternateFilenameÿþÿ 1ÿþÿ PublishHtmlProperties::Unitsÿþÿ 0ÿþÿ%PublishHtmlProperties::showTagWarnMsgÿþÿ 1ÿþÿ Vector::External Playerÿþÿÿþÿ Vector::DocumentClassÿþÿÿþÿ&PublishRNWKProperties::singleRateAudioÿþÿ 0ÿþÿ&PublishRNWKProperties::speedSingleISDNÿþÿ 0ÿþÿ$PublishPNGProperties::OptimizeColorsÿþÿ 1ÿþÿ PublishQTProperties::Widthÿþÿ 550ÿþÿ%PublishFormatProperties::projectorMacÿþÿ 0ÿþÿ'PublishFormatProperties::gifDefaultNameÿþÿ 1ÿþÿ&PublishFormatProperties::flashFileNameÿþÿ Untitled-1.swfÿþÿ Vector::Package Pathsÿþÿÿþÿ Vector::Compress Movieÿþÿ 1ÿþÿ Vector::ScriptStuckDelayÿþÿ 15ÿþÿ#PublishRNWKProperties::flashBitRateÿþÿ 1200ÿþÿ%PublishRNWKProperties::mediaCopyrightÿþÿ (c) 2000ÿþÿ PublishGifProperties::Smoothÿþÿ 1ÿþÿ PublishFormatProperties::htmlÿþÿ 1ÿþÿ$PublishFormatProperties::pngFileNameÿþÿ Untitled-1.pngÿþÿ(PublishHtmlProperties::VerticalAlignmentÿþÿ 1ÿþÿ PublishHtmlProperties::Qualityÿþÿ 4ÿþÿ Vector::FireFoxÿþÿ 0ÿþÿ Vector::Invisible Layerÿþÿ 1ÿþÿ Vector::AS3ExportFrameÿþÿ 1ÿþÿ"PublishRNWKProperties::exportAudioÿþÿ 1ÿþÿ PublishRNWKProperties::speed384Kÿþÿ 0ÿþÿ!PublishRNWKProperties::exportSMILÿþÿ 1ÿþÿ"PublishGifProperties::DitherOptionÿþÿÿþÿ-PublishFormatProperties ::generatorDefaultNameÿþÿ 1ÿþÿ!PublishHtmlProperties::DeviceFontÿþÿ 0ÿþÿ Vector::Override Soundsÿþÿ 0ÿþÿ'PublishRNWKProperties::mediaDescriptionÿþÿÿþÿ"PublishPNGProperti es::FilterOptionÿþÿÿþÿ PublishFormatProperties::gifÿþÿ 0ÿþÿ(PublishFormatProperties::jpegDefaultNameÿþÿ 1ÿþÿ(PublishFormatProperties::rnwkDefaultNameÿþÿ 1ÿþÿ*PublishFormatProperties::generatorFileNameÿþÿ Untitled-1.swtÿþÿ Vector::Templateÿþÿ 0ÿþÿ2PublishHtmlProperties::VersionDetectionIfAvailableÿþÿ 0ÿþÿ*PublishHtmlProperties::HorizontalAlignmentÿþÿ 1ÿþÿ"PublishHtmlProperties::DisplayMenuÿþÿ 1ÿþÿ Vector::Protectÿþÿ 0ÿþÿ Vector::Qualityÿþÿ 80ÿþÿ PublishJpegProperties::DPIÿþÿ 4718592ÿþÿ PublishGifProperties::Interlaceÿþÿ 0ÿþÿ"PublishGifProperties::DitherSolidsÿþÿ 0ÿþÿ PublishPNGProperties::Smoothÿþÿ 1ÿþÿ PublishPNGProperties::BitDepthÿþÿ 24-bit with Alphaÿþÿ PublishQTProperties::Flattenÿþÿ 1ÿþÿ#PublishFormatProperties::qtFileNameÿþÿ Untitled-1.movÿþÿ Vector::AS3Optimizeÿþÿ 1ÿþÿ PublishRNWKProperties::speed28Kÿþÿ 1ÿþÿ!PublishRNWKProperties::mediaTitleÿþÿÿþÿ$PublishRNWKProperties::m ediaKeywordsÿþÿÿþÿ PublishGifProperties::Widthÿþÿ 550ÿþÿ PublishGifProperties::Loopÿþÿ 1ÿþÿ PublishFormatProperties::flashÿþÿ 1ÿþÿ PublishJpegProperties::Qualityÿþÿ 80ÿþÿ$PublishRNWKProperties::realVideoRateÿþÿ 100000ÿþÿ$PublishRNWKProperties::speedDualISDNÿþÿ 0ÿþÿ#PublishGifProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishGifProperties::PaletteOptionÿþÿÿþÿ"PublishPNGProperties:: DitherOptionÿþÿÿþÿ0PublishFormatProperties::projectorMacDefaultNameÿþÿ 1ÿþÿ'PublishFormatProperties::pngDefaultNameÿþÿ 1ÿþÿ-PublishFormatProperties::projectorWinFileNameÿþÿ Untitled-1.exeÿþÿ PublishHtmlProperties::Alignÿþÿ 0ÿþÿ!PublishProfileProperties::versionÿþÿ 1ÿþÿ Vector::Package Export Frameÿþÿ 1ÿþÿ$PublishJpegProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishPNGProperties::MatchMovieDimÿþÿ 1ÿþÿ#PublishPNGProperties::PaletteOptionÿþÿÿþÿ)PublishFormatPropertie s::flashDefaultNameÿþÿ 1ÿþÿ%PublishFormatProperties::jpegFileNameÿþÿ Untitled-1.jpgÿþÿ PublishHtmlProperties::Widthÿþÿ 550ÿþÿ PublishHtmlProperties::Heightÿþÿ 400ÿþÿ Vector::Omit Trace Actionsÿþÿ 0ÿþÿ Vector::Debugging Passwordÿþÿÿþÿ Vector::Export Swcÿþÿ 0ÿþÿ"PublishJpegProperties::Progressiveÿþÿ 0ÿþÿ"PublishPNGProperties::DitherSolidsÿþÿ 0ÿþÿ#PublishQTProperties::PlayEveryFrameÿþÿ 0ÿþÿ PublishFormatProperties::pngÿþÿ 0ÿþÿ PublishFormatProperties::rnwkÿþÿ 0ÿþÿ(PublishFormatProperties::htmlDefaultNameÿþÿ 1ÿþÿ-PublishFormatProperties::projectorMacFileNameÿþÿ Untitled-1.hqxÿþÿ2PublishHtmlProperties::UsingDefaultContentFilenameÿ þÿ 1ÿþÿ!PublishHtmlProperties::WindowModeÿþÿ 0ÿþÿ'PublishHtmlProperties::TemplateFileNameÿþÿ Default.htmlÿþÿ Vector::TopDownÿþÿ 0ÿþÿ Vector::DeviceSoundÿþÿ 0ÿþÿ Vector::AS3Coachÿþÿ 1ÿþÿ Vector::AS3AutoDeclareÿþÿ 1ÿþÿ Vector::UseAS3Namespaceÿþÿ 1ÿþÿ PublishJpegProperties::Sizeÿþÿ 0ÿþÿ PublishGifProperties::Heightÿþÿ 400ÿþÿ PublishPNGProperties::Interlaceÿþÿ 0ÿþÿ"PublishFormatProperties::generatorÿþÿ 0ÿþÿ&PublishHtmlProperties::ContentFilenameÿþÿÿþÿ(PublishHtmlProperti es::AlternateFilenameÿþÿÿþÿ+PublishHtmlProperties::OwnAlternateFilenam eÿþÿÿþÿ Vector::Reportÿþÿ 0ÿþÿ PublishRNWKProperties::speed56Kÿþÿ 1ÿþÿ PublishGifProperties::LoopCountÿþÿÿþÿ'PublishGifProperties::Transpare ntOptionÿþÿÿþÿ PublishGifProperties::MaxColorsÿþÿ 255ÿþÿ%PublishPNGProperties::RemoveGradientsÿþÿ 0ÿþÿ PublishQTProperties::Heightÿþÿ 400ÿþÿ PublishFormatProperties::qtÿþÿ 0ÿþÿ Vector::Stream Compressÿþÿ 7ÿþÿ Vector::Event Formatÿþÿ 0ÿþÿ Vector::Versionÿþÿ 8ÿþÿ Vector::AS3Strictÿþÿ 1ÿþÿ"PublishRNWKProperties::audioFormatÿþÿ 0ÿþÿ$PublishGifProperties::OptimizeColorsÿþÿ 1ÿþÿ0PublishFormatProperties::projectorWinDefaultNameÿþÿ 1ÿþÿ PublishHtmlProperties::Scaleÿþÿ 0ÿþÿ Vector::Event Compressÿþÿ 7ÿþÿ Vector::ActionScriptVersionÿþÿ 2ÿþÿ Vector::StreamUse8kSampleRateÿþÿ 0ÿþÿ Vector::EventUse8kSampleRateÿþÿ 0ÿþÿ PublishJpegProperties::Heightÿþÿ 400ÿþÿ PublishRNWKProperties::speed512Kÿþÿ 0ÿþÿ%PublishGifProperties::RemoveGradientsÿþÿ 0ÿþÿ PublishPNGProperties::Widthÿþÿ 550ÿþÿ PublishPNGProperties::Heightÿþÿ 400ÿþÿ&PublishFormatProperties::qtDefaultNameÿþÿ 1ÿþÿ$PublishFormatProperties::gifFileNameÿþÿ Untitled-1.gifÿþÿ"PublishHtmlProperties::VersionInfoÿþÿP9,0,115,0;8,0 ,24,0;7,0,14,0;6,0,79,0;5,0,58,0;4,0,32,0;3,0,8,0;2,0,1,12;1,0,0,1;ÿþÿ Vector::Stream Formatÿþÿ 0ÿþÿ PublishJpegProperties::Widthÿþÿ 550ÿþÿ"PublishRNWKProperties::exportFlashÿþÿ 1ÿþÿ&PublishRNWKProperties::showBitrateDlogÿþÿ 1ÿþÿ(PublishRNWKProperties::speedCorporateLANÿþÿ 0ÿþÿ"PublishRNWKProperties::mediaAuthorÿþÿÿþÿ PublishGifProperties::Animatedÿþÿ 0ÿþÿ&PublishGifProperties::TransparentAlphaÿþÿ 128ÿþÿ!PublishPNGProperties::Transparentÿþÿ 0ÿþÿ!PublishPNGProperties::PaletteNameÿþÿÿþÿ*PublishQTProperties::Use QTSoundCompressionÿþÿ 0ÿþÿ PublishQTProperties::Loopingÿþÿ 0ÿþÿ%PublishFormatProperties::defaultNamesÿþÿ 1ÿþÿ%PublishFormatProperties::projectorWinÿþÿ 0ÿþÿ%PublishFormatProperties::rnwkFileNameÿþÿ Untitled-1.smilÿþÿ,PublishHtmlProperties::UsingOwnAlternateFileÿþÿ 0ÿþÿ PublishPNGProperties::MaxColorsÿþÿ 255ÿþÿ%PublishQTProperties::ControllerOptionÿþÿ 0ÿþÿ"PublishQTProperties::PausedAtStartÿþÿ 0ÿÿÿÿÿþÿÿþÿ üÿÿ CColorDef ÿ € ÿ € ÿ € ÿ € 3ÿPï € fÿPï0 € ™ÿPïH € ÌÿPï` € ÿÿPïx € 3ÿï € 33ÿ(ï € 3fÿ<ï0 € 3™ÿCïH € 3ÌÿFï` € 3ÿÿHïx € fÿï0 € f3ÿ ï0 € ffÿ(ï0 € f™ÿ5ïH € fÌÿ<ï` € fÿÿ@ïx € ÿ € 333ÿ0 € ÿ € 3ÿ ï € 33ÿxï € f3ÿdï0 € ™3ÿ]ïH € Ì3ÿZï` € ÿ3ÿXïx € 33ÿÈï € 333ÿ0 € 3f3ÿPPH € 3™3ÿPx` € 3Ì3ÿPx € 3ÿ3ÿPï € f3ÿÜï0 € f33ÿPH € ff3ÿ(PH € f™3ÿ<x` € fÌ3ÿCx € fÿ3ÿFï € ÿ € fffÿ` € ÿ € fÿ ï0 € 3fÿŒï0 € ffÿxï0 € ™fÿkïH € Ìfÿdï` € ÿfÿ`ïx € 3fÿ´ï0 € 33fÿ PH € 3ffÿxPH € 3™fÿdx` € 3Ìfÿ]x € 3ÿfÿZï € ffÿÈï0 € f3fÿÈPH € fffÿ` € f™fÿP0x € fÌfÿPx € fÿfÿPï¨ € ÿ € ™™™ÿ € ÿ € ™ÿ ïH € 3™ÿ“ïH € f™ÿ…ïH € ™™ÿxïH € Ì™ÿnï` € ÿ™ÿhïx € 3™ÿïH € 33™ÿ x` € 3f™ÿŒx` € 3™™ÿxx` € 3Ì™ÿkx € 3ÿ™ÿdï € f™ÿ»ïH € f3™ÿ´x` € ff™ÿ 0x € f™™ÿx0x € fÌ™ÿdx € fÿ™ÿ]ï¨ € ÿ € ÌÌÌÿÀ € ÿ € Ìÿ ï` € 3Ìÿ–ï` € fÌÿŒï` € ™Ìÿ‚ï` € ÌÌÿxï` € ÿÌÿpïx € 3Ìÿªï` € 33Ìÿ x € 3fÌÿ“x € 3™Ìÿ…x € 3ÌÌÿxx € 3ÿÌÿnï € fÌÿ´ï` € f3Ìÿx € ffÌÿ x € f™ÌÿŒx € fÌÌÿxx € fÿÌÿkï¨ € ÿ € ÿÿÿÿð € ÿ € ÿÿ ïx € 3ÿÿ˜ïx € fÿÿïx € ™ÿÿˆïx € Ìÿÿ€ïx € ÿÿÿxïx € 3ÿÿ¨ïx € 33ÿÿ ï € 3fÿÿ–ï € 3™ÿÿŒï € 3Ìÿÿ‚ï € 3ÿÿÿxï € fÿÿ°ïx € f3ÿÿªï € ffÿÿ ï¨ € f™ÿÿ“ï¨ € fÌÿÿ…ï¨ € fÿÿÿxï¨ € ÿ € ÿÿïx € ÿ € ™ÿïH € ™3ÿ
ïH € ™fÿ ïH € ™™ÿ(ïH € ™Ìÿ2ï` € ™ÿÿ8ïx € Ìÿï` € Ì3ÿ
ï` € Ìfÿ ï` € Ì™ÿ ï` € ÌÌÿ(ï` € Ìÿÿ0ïx € ÿÿïx € ÿ3ÿ ïx € ÿfÿ ïx € ÿ™ÿ ïx € ÿÌÿ ïx € ÿÿÿ(ïx € ÿ € ÿÿPïx € ÿ € ™3ÿãïH € ™33ÿx` € ™f3ÿ x` € ™™3ÿ(x` € ™Ì3ÿ5x € ™ÿ3ÿ<ï € Ì3ÿæï` € Ì33ÿx € Ìf3ÿ
x € Ì™3ÿ x € ÌÌ3ÿ(x € Ìÿ3ÿ2ï € ÿ3ÿèïx € ÿ33ÿï € ÿf3ÿ
ï € ÿ™3ÿ ï € ÿÌ3ÿ ï € ÿÿ3ÿ(ï € ÿ € ÿÿ ïx € ÿ € ™fÿÕïH € ™3fÿÜx` € ™ffÿ0x € ™™fÿ(0x € ™Ìfÿ<x € ™ÿfÿCï¨ € ÌfÿÜï` € Ì3fÿãx € Ìffÿx € Ì™fÿ x € ÌÌfÿ(x € Ìÿfÿ5ï¨ € ÿfÿàïx € ÿ3fÿæï € ÿffÿï¨ € ÿ™fÿ
ï¨ € ÿÌfÿ ï¨ € ÿÿfÿ(ï¨ € ÿ € ÿÿÿ(ïx € ÿ € ™™ÿÈïH € ™3™ÿÈx` € ™f™ÿÈ0x € ™™™ÿ € ™Ì™ÿPP¨ € ™ÿ™ÿPïÀ € Ì™ÿÒï` € Ì3™ÿÕx € Ìf™ÿÜx € Ì™™ÿP¨ € ÌÌ™ÿ(P¨ € Ìÿ™ÿ<ïÀ € ÿ™ÿØïx € ÿ3™ÿÜï € ÿf™ÿãï¨ € ÿ™™ÿïÀ € ÿÌ™ÿ ïÀ € ÿÿ™ÿ(ïÀ € ÿ € ÿÿÿxïx € ÿ € ™Ìÿ¾ï` € ™3Ìÿ»x € ™fÌÿ´x € ™™Ìÿ P¨ € ™ÌÌÿxP¨ € ™ÿÌÿdïÀ € ÌÌÿÈï` € Ì3ÌÿÈx € ÌfÌÿÈx € Ì™ÌÿÈP¨ € ÌÌÌÿÀ € ÌÿÌÿPïØ € ÿÌÿÐïx € ÿ3ÌÿÒï € ÿfÌÿÕï¨ € ÿ™ÌÿÜïÀ € ÿÌÌÿïØ € ÿÿÌÿ(ïØ € ÿ € ÿÿÿÈïx € ÿ € ™ÿÿ¸ïx € ™3ÿÿ´ï € ™fÿÿï¨ € ™™ÿÿ ïÀ € ™ÌÿÿŒïÀ € ™ÿÿÿxïÀ € ÌÿÿÀïx € Ì3ÿÿ¾ï € Ìfÿÿ»ï¨ € Ì™ÿÿ´ïÀ € ÌÌÿÿ ïØ € ÌÿÿÿxïØ € ÿÿÿÈïx € ÿ3ÿÿÈï € ÿfÿÿÈï¨ € ÿ™ÿÿÈïÀ € ÿÌÿÿÈïØ € ÿÿÿÿð € ÿ ÿÿÿÿÿÿ € ÿ ÿÿÿÿÿÿ € ÿ ÿÿÿÿ € ÿ ÿÿÿÿ € ÿ ÿÿÿÿ € ÿ fýÿ`ÿÿÿÿzÿÿÿÿ€™fÿªÿÌÿÿÿÿÿÿ € ÿ ÿÿ*ÿÿÿ]ÿÿÿÿÿªÿÿÔÿÿÿÿÿÿ ý ˆ ¤ z ÿþÿ"PublishQTProperties::QTSndSettingsÿÿ CQTAudioSettings ÿÿ ÿþÿ h ÿþÿÿþÿ ÿÿÿÿÿþÿ ÿþÿÿþÿÿþÿÿÿÿÿÿÿÿÿ î BSaved by Adobe Flash Windows 9.0 build 494 timecount = 1332507635
þÿÿÿ !"#$%&'()*+,-./0123456789:;<=>?@AþÿÿÿCDEFGHþÿÿÿJKLMNOPQRSTUVWXYZ[\]^_ `abcdefghijklmnopqrstuvwþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿS 1 1332506097 ÿÿÿÿÿÿÿÿÿÿÿÿ l S 3 1332506736 ÿÿÿÿÿÿÿÿÿÿÿÿä ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame €€ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ ÿÿÿ?ÿÿÿþÿ < ÿþÿÿþÿ €€ ÿþÿ extended buttonÿÿÿÿ™3Ìÿ € € ÿÿ
CPicSprite 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ 9ÿþÿÿþÿ msk ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ ‡~ÿþÿÿþÿ €€ ÿþÿ maskÿÿÿÿÿÿOÿ € € €€ ÿ ÿ ÿó @ ì0Àù0 0@ ÿÿÿ?ÿÿÿþÿ > ÿþÿÿþÿ €€ ÿþÿ main button ÿÿÿÿOÿOÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame €€ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ ÿÿÿ?ÿÿÿþÿ l=ÿþÿÿþÿ €€ ÿþÿ extended button ÿÿÿÿ™3Ìÿ € € ÿÿ
CPicSprite 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ ®rÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ Ö,ÿþÿÿþÿ € € Ð ô ÿÿÿÿÿþÿ I ÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.2'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ _ÿþÿÿþÿ € € 0ýÿÿ T÷ÿÿ ÿÿÿÿÿþÿ ñZÿþÿÿþÿ ÿþÿ†<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1.1'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ ñmÿþÿÿþÿ €€ ÿþÿ
animated mask ÿÿÿÿÿÿOÿ € € €€ ÿ ÿ ÿó @ ì0Àù0 0@ ÿÿÿ?ÿÿÿþÿ »Aÿþÿÿþÿ €€ ÿþÿ main buttonÿÿÿÿOÿOÿ € € €€ ÿÿÿ?ÿÿÿþÿ é&ÿþÿ stop();ÿþÿ € €€ ÿÿÿ?ÿÿÿþÿ ë ÿþÿ stop();ÿþÿ € €€ ÿÿÿ?ÿÿÿþÿ ³ ÿþÿ gotoAndStop(1);ÿþÿ €€ ÿþÿ actions ÿÿÿÿÿOÿÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame ÿÿ CPicShape €€ ìÿÿÿ þÿÿ ™fÿó ˜ è ï<pþpþ 0P < 0à < pþ0°ë<pþpþpþ€€ ÿÿÿ?ÿÿÿþÿ Riÿþÿÿþÿ €€ ÿþÿ Layer 1 ÿÿÿÿOÿOÿ €€ ÿÿ CPicPage ÿÿ CPicLayer ÿÿ CPicFrame ÿÿ
CPicSprite ” ” t ÿÿÿÿÿþÿ áJÿþÿÿþÿ btn_timeline ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='1'>
</component>
€€ Ø h Ø h éêÿÿø éêÿÿø ÿÿÿ?ÿÿÿþÿ „gÿþÿÿþÿ €€ ÿþÿ Layer 1ÿÿÿÿOÿOÿ € € € • Ž ÿÿÿÿÿþÿ Û ÿþÿÿþÿ btn_tween ÿþÿ„<component metaDataFetched='true' schemaUrl='' schemaOperation='' sceneRootLabel='Scene 1' oldCopiedComponentPath='3'>
</component>
€€ ÿÿÿ?ÿÿÿþÿ ¦.ÿþÿÿþÿ €€ ÿþÿ Layer 3ÿÿÿÿÿÿOÿ € € €€ ÿÿÿ?ÿÿÿþÿ ™ÿþÿÿ´ // here is the code for the button that has the animation built into it
var tw:Tween;
In an onRelease function, similare to the rollover and rollout
yourBtn.onRelease = function(){
getURL(http://www...);
