This discussion is locked
Printing Business Cards
Jun 24, 2013 10:06 PM
I am about to print business cards? Where is the best place to get QUALITY (not VistaPrint) cards done?
[ discussion is now locked, because this topic seems to be a magnet for spammers ]
    Mar 22, 2012 8:11 AM   in reply to icaribou
    The best program to create them would seldom be Photoshop in my opinion.
    I can’t recommend any shops, but as so often the things somebody knows, but doesn’t tell, may be significant – like how many different cards and at which numbers each?
    And what paper etc.did you have in mind?
    Any special requests like imprints etc.?
    Mar 22, 2012 8:29 AM   in reply to icaribou
    Besides photoshop, get a decent color printer and glossy paper and you are set. Print only what you need initially as you may want to change something later.
    Mar 22, 2012 9:02 AM   in reply to icaribou
    While Indesign is a fine choice for the task why are you posting on a Photoshop Forum then?
    Mar 22, 2012 6:39 PM   in reply to icaribou
    Make sure you have a .125 inch bleed on all four sides.
    A normal business card in the US is 3.5 x 2 inches. With the bleed the document would be 3.75 x 2.25 inches.
    But make sure that all image/text elements is at least .125 inside the trim size of 3.5 x 2.
    So the safe area is 3.25 x 1.75 inches
    Trim size is 3.5 x 2 inches
    Bleed size is 3.75 x 2.25 inches.
    All images should be approx 240 - 300 ppi or in vector format.
    Just create 1 copy of each card with the bleed, the printer will do the imposition to best suit their printing process.
    Even if a printer accepts PDF you can't assume that they won't open it in Photoshop and end up rasterizing all the text!
    You can ask if they do this but don't expect to get a clear answer when dealing with internet printers. So be warned.
    100 is a small amount for an internet printer, they usually start at 500, but usually 1,000 may only cost 1 or 2 dollars more.
    Oh, and InDesign is the best way to go when creating business cards.
    Mar 22, 2012 6:45 PM   in reply to icaribou
    polynesiamedia wrote:
    I am more asking for suggestion on companies to look into for a supplier
    Here in the States I can recommend GotPrint, I had my own cards printed there, double-sided/glossy, they did a great job at a reasonable price!
    Mar 28, 2012 7:55 AM   in reply to pf22
    Additional observations:
    On your card you have reversed text (white text on colored background).
    Thin versions of fonts run the possibility of getting slightly filled in by ink from the background when printing.
    Also, a "rich black" background will make this problem worse.
    It is best to stick with thicker typefaces rather than thin or light typefaces to reduce this issue.
    However,solid black text on a white background won't have this problem even with thin fonts.
    Colored text will need to be thicker/larger since it would be printed with CMYK rather than black alone.
    Gray text (a tint of black) will also need to be thicker/larger.
    In the past, GotPrint has definitely rasterized some PDFs for business cards. They may not do this anymore or it may depend on the item ordered.
    Recent postcards that I ordered did not have the text issue that I saw on earlier business cards.
    However, even thought I noticed the issue, I think the average person is less likely to notice it.
    GotPrint has a much better user interface than a lot of other printers.
    I just checked and it now appears you can order just 100 cards.
    Mar 27, 2012 9:43 PM   in reply to icaribou
    I would suggest PrintPlace business cards: http://www.printplace.com/printing/business-card-printing.aspx. They always have a great quality output, two thumbs up for this company.
    Mar 27, 2012 9:51 PM   in reply to icaribou
    Try Modern postacrds
    http://www.modernpostcard.com/products
    Butr make certain what ever you do you use a rich balck for your backround color.
    they say it is $59.00 for 250 cards
    Mar 27, 2012 10:03 PM   in reply to icaribou
    I don't know where in the States you are but printing.com would be a good shout. http://us.printing.com/
    They are a European company that moved into the US market a couple of years ago. I can vouch for their print quality and the prices are very reasonable. Fast turnarounds too.
    Jan 15, 2013 12:53 PM   in reply to icaribou
    BluegrassPrint.com is great for business cards. Awesome quality and price.
    http://www.bluegrassprint.com
    Cheers!
