as the title says, i have to constantly reinstall flash player every time i open my conputer.
can any one help me because this issue is driving me crazy.
What OS are you using? If it's windows, could you try the following steps to see if it helps?
Chris
Before you go Chris Campbell's route because messing around with the registry can get you into a whole load of trouble if you're not careful (no offence Chris), could you please try running this Microsoft fix which was written to address the problem of not being able to maintain an installation: http://support.microsoft.com/mats/Program_Install_and_Uninstall
If it doesn't work, post again and I'll provide you with some screenshots to help you delete the key Chris described.
I'm having the same issue (Flash Reader 11.2 r202).
I'm running Windows 7 64-bit, and regardless if I install Adobe Flash Player for IE 9 or Firefox 11, the installation works only until I restart my computer. After restarting, sites like youtube don't prompt me to reinstall flash but just show a blank location where the video would play. The plugins are still installed on the machine and both Firefox and IE still recognize that the plugins are there. They just don't work.
I have repeatedly tried uninstalling and reinstalling the flash player and have also tried the recommended step of deleting "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash" with no success.
Visiting the website
http://helpx.adobe.com/flash-player.html
shows my flash player version after I reinstall flash, but after restarting my machine and visiting the site, neither the version of flash nor an error message is shown. Only an empty space where the message would go.
Any help would be greatly appreciated.
How do I do a clean install of Flash Player?
After the clean install, do a clean boot.
Click Start, type System Configuration, click System Configuration, click Selective startup, uncheck Load startup items, click Apply, click Services tab, check Hide all Microsoft Services, click Disable all, click Apply, click OK, click Restart.
Check to see if Flash Player is still functioning.
Thank you for the reply.
Unfortunately the suggestions did not help.
After running through the complete cleaning process flash was completely disabled (as it should be) so visiting sites like Youtube prompted for me to install flash. Flash didn't work again until I reinstalled, however I got the same issues as before. Restarting my computer causes flash to stop sorking.
But again, thank you for the rely.
Do you by any chance have an app called "Playon" installed? it's mentioned here by a user having a similar problem to your own: http://www.dslreports.com/forum/r26636257-
Can you do the following please.
JllyGrnGiant wrote:
The line reads:
Local Group Memberships *Administrators *HomeUsers
Could you do the following please.
I am experiencing the same problem. Except I have tried everything from an administrative account with administrative privileges.
I have also followed the clean install procedures http://forums.adobe.com/thread/928315 as well as the above.
I note, however, that the "Shockwave Flash Object" does not appear as published by "Adobe Systems Incorporated" but rather as "Not Available" even though it is enabled. The "Shockwave Active X Control" is listed as published by "Adobe Systems Incorporated."
Thanks for your feedback.
I followed the procedure but noticed that next to Shockwave Flash Object the publisher is listed as "Not Available" yet is enabled, just like jimsup33. I visited the Adobe Flash Player test site to verify if the player was working and it still is not.
Thank you for your help however. I greatly appreciate it.
We'd like to investigate this further. Could do the following steps for me?
1. Download and extract AccessChk to a folder on your computer
2. Download and extract the attached "flashreport.bat" file to the same location as AccessChk (flash_report.bat and accesschk.exe should be in the same location). Please note that unless you have file extensions visible you might not see the .exe and .bat parts of the file name.
3. Install Flash Player again so that it is in the working state
4. Right click "flashreport.bat" and select "Run as administrator"
5. A window will appear briefly, then close. A new file named "flashreport.txt" will be created.
6. Rename this file to "flashreport_good.txt"
7. Reboot your system, or do whatever is needed so that Flash is no longer working properly and repeat 4.
8. Save the new flashreport.txt as flashreport_bad.txt.
Please email both of these reports along with a link to your forum thread to ccampbel@adobe.com
In addition, please let us know if the Flash Player installer name you ran ends with "aih". And finally, if it did not end with "aih", did you start the installer using the download dialog's "run" button or did you double click on the .exe after saving the file?
Chris
I have the same problem as the others-I went ahead and performed your instructions and just emailed them to that address. So far the solutions given in this thread haven't fixed my problem.
Oh! I did notice in a brief comparison of the two text files that the "Bad" report is about 300 million bytes smaller at the "Directory Listing: system32\macromed\flash\" part, down where it says Total Files Listed, the 'Dir(s)' is smaller in the bad report, if that's any significance.
Hi Chris
I am having exactly the same problem.
I am on Windows 7 and running Firefox browser. Flash installs and works fine. However, when my PC reboots Flash is no longer installed. This has only started happening quite recently.
I will try and run the test you mentioned above and email you the results (Update: I have emailed you the files Chris).
Thanks for your help
James
I finally resolved this issue. See discussion at http://forums.adobe.com/message/4317467#4317467 including final post.
Follow the clean install procedures http://forums.adobe.com/thread/928315, BUT also make sure that your MACROMEDIA folders have full permissions for administrators and rwx for users. I don't know what program would have changed/corrupted my permissions, it is possible that they were legacy permissions from an earlier installation of Flash Player.
