Clearing Adobe AppData filling up C Drive
Mar 24, 2012 12:30 AM
My Windows 7 PC is a traditional set up for video, with separate media, backup, and app/boot drives. My apps are all installed on C, a 232 GB solid state drive that currently only has 19 GB of free space, the chief reason being the enormous size of the "Adobe" subfolder of the Windows "AppData" folder (C:\Users\Admin\AppData\Roaming\Adobe), clocking in at a whopping 162 GB.
As you might know, AppData, a normally hidden folder, stores preferences and settings from all applications, many of which files are necessary for the apps to function, or at least as desired. These aren't - at least not most of them - temp files you can safely delete. I was able to locate a tutorial on how to move the save location for AppData to another drive (http://www.sevenforums.com/tutorials/87555-user-profile-change-default -location.html). My media drive is 2 TB, so this would be great, but the process is complicated, risky, and not even guaranteed to work.
Since I know that many of you follow the same drive separation protocol, have you also experienced a filling-up C drive due to having your apps on it? How have you dealt with it? Is there an easier way to manage, or at least reduce, the filling up of this AppData? 162 GB seems like an awful lot of space just for Adobe App Data, especially since I barely use most of the apps in the suite.Are there any ways to deal with this through settings in the Adobe software itself? Otherwise, it would seem like segregating the applications to the C drive isn't - not entirely - an ideal set-up.
I know this isn't strictly a Premiere question, but I wasn't sure where to categorize this; please point out if there's a better forum to which this is suited.
    Mar 24, 2012 9:06 AM   in reply to VideOh
  • joe bloe premiere
    Dec 6, 2009
    Mar 24, 2012 11:52 AM   in reply to VideOh
    Media Encoder will also save temporary files that you can safely delete to this folder:
    C:\Users\=username=\AppData\Local\Temp
    Select all, and delete.
    You will likely come across at least one active system file that can not be deleted,
    just skip the file and continue.
  • joe bloe premiere
    Dec 6, 2009
    Mar 25, 2012 4:20 PM   in reply to VideOh
    joe bloE, there are some folders in that Temp folder as well. Is everything in Temp from Media Encoder?
    Anything that is in that folder, including other folders can be safely
    deleted, with the exception of any active system files (usually one).
    Media Encoder is the only application I use that stores files in that location.
    Jul 18, 2012 9:10 PM   in reply to VideOh
    Also read about Drive C space http://forums.adobe.com/thread/1007934?tstart=0 to change a default setting
    Jul 19, 2012 1:02 PM   in reply to VideOh
    > Are these files (.cfa, .pek, .mpgindex) safe to simply delete? (I don't know of a way to delete them from any of the Adobe programs. I assume these are the files "Common" for all Adobe programs?)
    Yes, you can safely delete those media cache files. The worst thing that will happen is that they will be regenerated the next time that you use the footage with which they're associated.
    My post above in this thread about clearing your media cache links to a document telling how.
