FMLE 3.2 doesn't show audio devices
Dec 23, 2011 3:07 PM
Tags: #adobe #audio #fmle
At first when I had installed FMLE it would only see my G35 microphone, not much use and so I installed the Realtek drivers with stereo mix. As it seems FMLE only saw my microphone input, because it wouldnt pick up on the stereo mix and also didnt show Virtual Audio Cable.
By now I had gone crazy, I can NOT stream without audio. So I had removed all audio devices, reinstalling and configuring each one of them. Now FMLE shows me no inputs at all!
So please fix this problem, FMLE is obviously not finding audio devices where it's supposed to be looking and that it was able to "find" my G35 in the first place was just coincidence at best.
Im on Windows 7 x64 SP1, FMLE3.2 and latest drivers for audio devices installed.
Screenshot of VAC streaming music, stereo mix shows final output level of the chain: http://i.imgur.com/Z57RF.jpg
edit: after some inspection I found out that FMLE is looking here:
HKEY_CURRENT_USER\Software\Microsoft\ActiveMovie\devenum
    Jan 9, 2012 8:03 AM   in reply to _sfjuocekr_
    thank you for give me this idea
    i believe it's because fmle only get device info in
    "HKEY_CURRENT_USER\Software\Microsoft\ActiveMovie\devenum\{33D9A762-90 C8-11D0-BD43-00A0C911CE86}"
    but win7 x64 got another 64-bit next to it
    "HKEY_CURRENT_USER\Software\Microsoft\ActiveMovie\devenum 64-bit\{33D9A762-90C8-11D0-BD43-00A0C911CE86}"
    if you install x64 driver for your device fmle won't recognize it,
    so i copy everything under
    to replace the
    then my fmle 3.2 found my device and work fine
    in my case i found 3 places need to change
    "HKEY_USERS\S-1-5-21-1935447303-2600364710-218316825-1000\Software\Mic rosoft\ActiveMovie\devenum\{33D9A762-90C8-11D0-BD43-00A0C911CE86}"
    "HKEY_USERS\S-1-5-21-1935447303-2600364710-218316825-1004\Software\Mic rosoft\ActiveMovie\devenum\{33D9A762-90C8-11D0-BD43-00A0C911CE86}"
    maybe you can try to fix it with my method
    hope this will help ,and sorry for my poor english
    Jan 22, 2012 11:55 PM   in reply to -cdplayer-
    I've been having this same problem and -cdplayer-'s solution worked for me.  I just added the key for the preferred audio input device from devenum 64-bit to devenum in the 2nd key he posted above
    Thanks -cdplayer- !
    Mar 24, 2012 4:55 PM   in reply to _sfjuocekr_
    Ive got the same Problem.
    Somehow fmle never uses the proper devices.
    i tried to use VAC but i dont get it to be used in fmle
    can anyone help how to fix?
    my system is windows 7 professional 64bit
    Apr 5, 2012 12:50 PM   in reply to _sfjuocekr_
    Have the same thing going on.
    Specs - Windows 7 x64 SP1
    Realteck HD Audio - Codec ALC892
    Got this keys in registy:
    http://imageshack.us/g/11/38729889.jpg/
    http://img205.imageshack.us/img205/2408/59353332.jpg
    Any help ???
    UPDATE:
    Tryed with my old X-fi Fatal1ty Pro Xtreme Gamer - same thing.
    May 29, 2012 3:31 AM   in reply to Achmonek
    That is the wrong key to look at, thats no the key to change. is this one:
    HKEY_USERS\S-1-5-21-1312392363-2256890078-3854120228-1000\Software\Mic rosoft\ActiveMovie\devenum\{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Line In (Realtek High Definitio
    Jul 24, 2012 11:51 PM   in reply to -cdplayer-
    I see the keys, how do I actually move the keys? There is no way for me to copy and paste or just move. If I copy keys, only name will be copied over but none of the other stuff inside like data and values get transfered over....
Bookmarked By (2)
