I only get individual stills when I drag a folder from Explorer into a project. Is there a way to tell Premiere to import as numbered stills (ie a sequence) when using drag/drop?
Thanks.
Yes, there is an Adobe way that is MUCH better, but it is not exactly a Premiere Pro way ![]()
1) Using Adobe Bridge, put all of your stills in the order that you want them to show in Premiere
2) Select all photos and do a right-click "batch rename" (set to make a copy of all photos with 001 002 003 numbers in front of each file name in an empty sub-directory)
3) Import the whole "folder" (that you just "batch rename" copied the photos into) using the "import folder" option
Hope this works for your "workflow" as well as it does for mine.
Jim
I already have the stills named and numbered. What I'd like is to drag the folder into Pr from Win Explorer and have Pr recognize the files as a series of numbered stills rather than having to import them. This avoids needing to navigate to the files from within Pr. Useful when there are several sequences to import. After Effects has this feature...
Thanks.
