I have been unsuccessfully attempting to download Flash Player on IE and Mozilla. When i get to the "install" window on both browsers it says that download will commence once browsers are closed. When i close browsers i am unable to access Adobe without a browser opened.??
Download the executable installers from http://www.adobe.com/products/flashplayer/fp_distribution3.html and save them to disk, then close all browser windows and run the downloaded installers.http://www.adobe.com/products/flashplayer/fp_distribution3.html
Hi, I would like to add to what Pat posted and that is to make sure you download and SAVE to your Desktop the Uninstaller first
from here:
http://kb2.adobe.com/cps/141/tn_14157.html
Then download and SAVE the Installer for IE and the Installer for FF(plug-in) to your Desktop.
Once you have those on your Desktop, then Close all browsers.
Be sure to use the Administrator Account for this.
Check the system tray(area near the clock) and disable any instant messengers, like yahoo, msn, aol, etc.
Also you may want to Disable any Anti-Virus that you use as some can block the Install. Re-enable when finished with this.
Run the Uninstaller and when finished, Reboot(restart) your computer.
Then Run the IE Installer and then the FF Installer, when finished, Reboot.
Test each browser here and you should be able to see the Flash logo animation and the vs of Flash Player will be displayed.
http://www.adobe.com/software/flash/about/
If you have any questions, let me know.
Also you may want to print this out to make it easier.
eidnolb
You can also find the uninstallers and full installers at http://forums.adobe.com/thread/909550
Make sure you download the correct executables (32-bit or 64-bit) for your system.
Yes, I followed instructions to the letter. I'm getting pretty quick at it...I've used Reg cleaner/defrag/CleanUp/etc so my re-boot times are minimised.![]()
And I always exit Malwarebytes, my virus software, before attempt.
Windows XP Home 2002 service pack 3. I've even established a clean restore point, since...after each failed attempt, I'm left with no flash player at all.
I'm downloading the 32 bit uninstaller from your link, a 229kb file. Saved in 'my downloads', or saved shortcut to desktop, browsers open, browsers closed, it's all the same.
"Failed to initialize"
I found this little infonugget at MozillzZine.
The Flash uninstaller may not remove all Flash plugin files from all locations so you should search for and delete the following files, if found:
I'll try this next, if I can figger out how....
No joy. I did find four NPSWF32.dll which I deleted. Had high hopes. Am reminded of the axiom that, if you keep doing the same damn thing expecting a different result...you may be a redneck. Or, was that a corrolary? Nevermind, I HATE FIREFOX now. Does this help?
C:\Windows\system32\Macromed\Flash\FlashInstall.log
=O====== M/10.1.53.64 2010-06-15+03-47-44.843 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\FlashPlayerUpdate.exe"
0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0004 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0005 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0006 [W] 00001036 Software\Opera Software/Last CommandLine 2
0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
0008 [W] 00001036 Software\Opera Software/Plugin Path 2
0009 [W] 00001036 Software\Opera Software/Plugin Path 2
0010 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
0012 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
=X====== M/10.1.53.64 2010-06-15+03-47-59.125 ========
=O====== M/10.1.53.64 2010-08-18+05-49-18.281 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.1.53.64 2010-08-18+05-50-34.859 ========
=O====== M/10.1.82.76 2010-08-18+05-50-35.015 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\4.dir\InstallFlashPlayer.exe" -iv 0
=X====== M/10.1.82.76 2010-08-18+05-50-48.734 ========
=O====== M/10.1.53.64 2010-08-25+13-19-24.937 ========
0001 [I] 00000011 0
=X====== M/10.1.53.64 2010-08-25+13-19-46.171 ========
=O====== M/10.1.82.76 2010-08-25+13-19-46.218 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 0
0001 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0002 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0003 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0004 [W] 00001036 Software\Opera Software/Last CommandLine 2
0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
0006 [W] 00001036 Software\Opera Software/Plugin Path 2
0007 [W] 00001036 Software\Opera Software/Plugin Path 2
0008 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe
0010 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
=X====== M/10.1.82.76 2010-08-25+13-19-55.937 ========
=O====== M/10.1.82.76 2010-09-22+13-13-47.765 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.1.82.76 2010-09-22+13-14-22.875 ========
=O====== M/10.1.85.3 2010-09-22+13-14-22.937 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 0
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
=X====== M/10.1.85.3 2010-09-22+13-15-54.437 ========
=O====== M/10.1.85.3 2010-11-11+05-04-38.156 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.1.85.3 2010-11-11+05-05-37.000 ========
=O====== M/10.1.102.64 2010-11-11+05-05-37.125 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
=X====== M/10.1.102.64 2010-11-11+05-05-54.359 ========
=O====== M/10.1.102.64 2011-02-12+06-09-54.218 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.1.102.64 2011-02-12+06-10-49.250 ========
=O====== M/10.2.152.26 2011-02-12+06-10-49.437 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe
=X====== M/10.2.152.26 2011-02-12+06-11-18.859 ========
=O====== M/10.2.152.26 2011-03-05+23-15-12.656 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.2.152.26 2011-03-05+23-16-16.843 ========
=O====== M/10.2.152.32 2011-03-05+23-16-16.875 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe
=X====== M/10.2.152.32 2011-03-05+23-16-32.406 ========
=O====== M/10.2.152.32 2011-03-27+05-20-46.218 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe" -update plugin
=X====== M/10.2.152.32 2011-03-27+05-22-15.250 ========
=O====== M/10.2.152.32 2011-04-03+15-27-29.265 ========
0001 [I] 00000011 0
=X====== M/10.2.152.32 2011-04-03+15-35-26.265 ========
=O====== M/10.2.153.1 2011-04-03+15-35-26.359 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe
0011 [E] 00001039
=X====== M/10.2.153.1 2011-04-03+15-35-36.218 ========
=O====== M/10.2.153.1 2011-04-17+15-30-45.500 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.2.153.1 2011-04-17+15-37-34.109 ========
=O====== M/10.2.159.1 2011-04-17+15-37-34.171 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe
=X====== M/10.2.159.1 2011-04-17+15-37-49.203 ========
=O====== M/10.2.159.1 2011-05-16+23-07-34.171 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.2.159.1 2011-05-16+23-17-43.046 ========
=O====== M/10.3.181.14 2011-05-16+23-17-43.093 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe
0011 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
=X====== M/10.3.181.14 2011-05-16+23-17-52.375 ========
=O====== M/10.3.181.14 2011-06-07+23-47-56.437 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.3.181.14 2011-06-07+23-49-30.781 ========
=O====== M/10.3.181.22 2011-06-07+23-49-30.843 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe
0012 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
=X====== M/10.3.181.22 2011-06-07+23-49-41.515 ========
=O====== M/10.3.181.22 2011-06-21+23-10-47.593 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.3.181.22 2011-06-21+23-11-52.937 ========
=O====== M/10.3.181.26 2011-06-21+23-11-53.093 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\7.dir\InstallFlashPlayer.exe" -iv 0
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe
=X====== M/10.3.181.26 2011-06-21+23-12-10.609 ========
=O====== M/10.3.181.26 2011-08-12+23-34-27.203 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.3.181.26 2011-08-12+23-37-25.781 ========
=O====== M/10.3.183.5 2011-08-12+23-37-25.843 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\8.dir\InstallFlashPlayer.exe" -iv 0
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe
0012 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0013 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
=X====== M/10.3.183.5 2011-08-12+23-38-04.859 ========
=O====== M/10.3.183.5 2011-09-25+14-58-06.531 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.3.183.5 2011-09-25+15-00-42.421 ========
=O====== M/10.3.183.10 2011-09-25+15-00-42.468 ========
0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe
=X====== M/10.3.183.10 2011-09-25+15-52-24.062 ========
=O====== M/10.3.183.10 2011-10-16+15-26-31.015 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/10.3.183.10 2011-10-16+15-27-09.359 ========
=O====== M/11.0.1.152 2011-10-16+15-27-09.484 ========
0001 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0002 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0003 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0009 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0010 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
0011 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
0012 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
=X====== M/11.0.1.152 2011-10-16+15-27-25.218 ========
=O====== M/11.1.102.55 2011-11-14+01-25-24.062 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 4
0009 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe 5
0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe
0013 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0014 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
=X====== M/11.1.102.55 2011-11-14+01-25-34.109 ========
=O====== M/11.0.1.152 2011-11-14+01-19-29.296 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/11.0.1.152 2011-11-14+01-25-34.140 ========
=O====== M/11.1.102.62 2012-02-22+17-10-21.468 ========
0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 4
0009 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe 5
0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe
=X====== M/11.1.102.62 2012-02-22+17-10-32.265 ========
=O====== M/11.1.102.55 2012-02-22+17-09-09.484 ========
0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe" -update plugin
0001 [I] 00000011 0
=X====== M/11.1.102.55 2012-02-22+17-10-32.296 ========
=O====== M/11.1.102.62 2012-03-18+00-12-06.820 ========
0000 [I] 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe -maintain plugin
=X====== M/11.1.102.62 2012-03-18+00-12-20.429 ========
=O====== M/11.1.102.62 2012-03-18+00-12-23.179 ========
=X====== M/11.1.102.62 2012-03-18+00-12-31.289 ========
=O====== M/11.1.102.62 2012-03-18+00-12-50.007 ========
=X====== M/11.1.102.62 2012-03-18+00-12-57.226 ========
=O====== M/11.1.102.62 2012-03-18+02-43-26.000 ========
0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe 5
0002 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0003 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0004 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0005 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0006 [W] 00001021
0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0010 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0011 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0012 [W] 00001036 Software\Opera Software/Last CommandLine 2
0013 [W] 00001036 Software\Opera Software/Last CommandLine 2
0014 [W] 00001036 Software\Opera Software/Plugin Path 2
0015 [W] 00001036 Software\Opera Software/Plugin Path 2
0016 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe 5
0017 [I] 00000012
=X====== M/11.1.102.62 2012-03-18+02-43-34.187 ========
=O====== M/11.1.102.63 2012-03-18+04-22-42.703 ========
0000 [I] 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit.exe" -force
0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 [W] 00001018
0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0006 [W] 00001019
0007 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0008 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0009 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0010 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0011 [W] 00001021
0012 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0014 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0015 [W] 00001048
0016 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0018 [W] 00001018
0019 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0020 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0021 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0022 [W] 00001019
0023 [W] 00001020
0024 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0025 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0026 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0027 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0028 [W] 00001021
0029 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0030 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0031 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0032 [W] 00001048
0033 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0034 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0035 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0036 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0037 [W] 00001036 Software\Opera Software/Last CommandLine 2
0038 [W] 00001036 Software\Opera Software/Last CommandLine 2
0039 [W] 00001036 Software\Opera Software/Plugin Path 2
0040 [W] 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.1.102.63 2012-03-18+04-22-59.843 ========
=O====== M/11.1.102.63 2012-03-18+04-43-06.781 ========
0004 [W] 00001018
0005 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 [W] 00001019
0008 [W] 00001020
0009 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0010 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0011 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0012 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0013 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0014 [W] 00001021
0015 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0017 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0018 [W] 00001048
0019 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0021 [W] 00001018
0022 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0023 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0024 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0025 [W] 00001019
0026 [W] 00001020
0027 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0028 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0029 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0030 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0031 [W] 00001021
0032 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0034 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0035 [W] 00001048
0036 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0037 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0038 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0039 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0040 [W] 00001036 Software\Opera Software/Last CommandLine 2
0041 [W] 00001036 Software\Opera Software/Last CommandLine 2
0042 [W] 00001036 Software\Opera Software/Plugin Path 2
0043 [W] 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.1.102.63 2012-03-18+04-43-18.156 ========
=O====== M/11.1.102.63 2012-03-18+04-47-18.859 ========
0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0011 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0014 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0017 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0018 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0021 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0023 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0024 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0026 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0027 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0028 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0030 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0033 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0035 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0036 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0038 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0039 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0040 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0041 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0042 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0043 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0044 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0045 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0046 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0047 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0048 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0049 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0050 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0051 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0052 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0053 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0054 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0055 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0056 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0057 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0058 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0059 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0060 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0062 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0063 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0064 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0065 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0066 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0067 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0068 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0069 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0070 [W] 00001018
0071 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
0072 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0073 [W] 00001019
0074 [W] 00001020
0075 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0076 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0077 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0078 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0079 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0080 [W] 00001021
0081 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0082 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0083 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0084 [W] 00001048
0085 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0086 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0087 [W] 00001018
0088 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0089 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0090 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0091 [W] 00001019
0092 [W] 00001020
0093 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0094 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0095 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0096 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0097 [W] 00001021
0098 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0099 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0100 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
0101 [W] 00001048
0102 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0103 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0104 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0105 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0106 [W] 00001036 Software\Opera Software/Last CommandLine 2
0107 [W] 00001036 Software\Opera Software/Last CommandLine 2
0108 [W] 00001036 Software\Opera Software/Plugin Path 2
0109 [W] 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.1.102.63 2012-03-18+04-47-42.000 ========
=O====== M/11.1.102.63 2012-03-18+05-33-52.578 ========
0000 [I] 00000010 "C:\Documents and Settings\Monty Johnson\Desktop\uninstall_flash_player_32bit(1).exe" -force
0040 [E] 00001039
=X====== M/11.1.102.63 2012-03-18+05-34-06.484 ========
=O====== M/11.1.102.63 2012-03-18+05-39-13.796 ========
0004 [W] 00001018
0007 [W] 00001019
0008 [W] 00001020
0014 [W] 00001021
0018 [W] 00001048
0021 [W] 00001018
0025 [W] 00001019
0026 [W] 00001020
0031 [W] 00001021
0035 [W] 00001048
=X====== M/11.1.102.63 2012-03-18+05-39-20.890 ========
=O====== M/11.1.102.63 2012-03-18+05-43-29.375 ========
=X====== M/11.1.102.63 2012-03-18+05-43-33.468 ========
=O====== M/11.1.102.63 2012-03-18+06-20-13.187 ========
0004 [W] 00001018
0007 [W] 00001019
0008 [W] 00001020
0014 [W] 00001021
0018 [W] 00001048
0021 [W] 00001018
0025 [W] 00001019
0026 [W] 00001020
0031 [W] 00001021
0035 [W] 00001048
=X====== M/11.1.102.63 2012-03-18+06-20-19.796 ========
=O====== M/11.1.102.63 2012-03-18+23-34-13.234 ========
0000 [I] 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(1).exe" -force
0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001018
0004 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0005 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0006 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0007 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0008 [W] 00001021
0010 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0011 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0012 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0013 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0014 [W] 00001021
0017 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0018 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
0019 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0020 [W] 00001036 Software\Opera Software/Last CommandLine 2
0021 [W] 00001036 Software\Opera Software/Last CommandLine 2
0022 [W] 00001036 Software\Opera Software/Plugin Path 2
0023 [W] 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.1.102.63 2012-03-18+23-34-22.078 ========
=O====== M/11.1.102.63 2012-03-19+07-26-14.140 ========
0000 [I] 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(2).exe" -force
0003 [W] 00001018
0008 [W] 00001021
0014 [W] 00001021
=X====== M/11.1.102.63 2012-03-19+07-26-22.187 ========
Thank you for the FlashInstall.log file; I can see that there are many errors or warnings during the uninstall process. However, I cannot see any attempts to run the installers - could it be that the error occurs before it starts logging?
Two things to try:
Pat-
I tried the two things you suggested, no joy.![]()
But, undaunted...I learned from your Fixit tool that I was missing two killbits activex updates, so I fixed.
Then...when checking my Java performance, (suggested elsewhere on da web), I learned I had SEVEN old Java versions that needed uninstalling. I didn't know this about Java!
So I deleted almost 900meg of old Java program.
Rebooted and loaded both new Flash (.exe and .msi) and...............................................................etc ...................
YA-HOO IT'S A GO!
ps thank you thank you for all your help......![]()
Me either, and I still don't with any certainty. I did 2 different fixes at once. Uploading 2 "killbits actvex" updates in Windows, then uninstalling my 7 outdated Java files.
Which operation was the fix....
But thanks again! Your suggestions gave me the inspiration to keep up the fight; not take hammer to cpu.
You can download the executable installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#Install_in_a_firewall_proxy_server_environment
ediejessesmom wrote:
11.0
OK, do the following please.
Should work.
