Hello Everybody.
Whenever I do a preview of my website, for example, if I do a preview of an "about us" page, it works fine, but when I click on "about us" from its own like on the "home" page it shows up all...gone.
I Will post pictures below
The picture on the right is from when I access from link.
The picture on the left is when I preview that exact page.
Looks like broken paths to CSS and images. But we can't be sure without seeing your code.
Did you define your local site folder in DW before you started this project?
Setting Up Local & Remote site folders (CS5 & CS5.5)
http://help.adobe.com/en_US/dreamweaver/cs/using/WS753df6af718a350a600 97e0f131686fa2b4-7ffe.html
Also, don't use spaces in folder or filenames. This can create problems. If you want to separate words, use a - hyphen or _underscore.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
It is not easy to tell what a problem is without seeing the code and the best way of doing that is to give a link to a live page.
However, a guess would be that the way your paths are formed in any of your links is wrong. Links to your images, CSS and maybe other files.
Did you define your site before starting out? It is a good idea to do so. Are your paths correctly formed within the context of your site structure? Maybe things are pointing to your hard drive - it sometimes happens.
If none of that helps, post your code please.
Martin
Links are...
http://dewittlondrepm.com/test/DWPM-Home.html
http://dewittlondrepm.com/test/Contact%20Us.html
http://dewittlondrepm.com/test/DWPM-Template%20About%20Us.html
Also, i really apologize if I am not the best at this, I literally bought this program this morning, not even kidding. I am also 13. Although, I understand most things about this, and know HTML and CSS just a tiny bit, enough to be able to find things and edit things inside the HTML and CSS.
Best Regards...
