specific url blocking
Mar 22, 2012 5:32 AM
this is specific url blocking.
But not woking this.....
 function pageDomainCheckInit(event:Event):void {
          var url:String=stage.loaderInfo.url;
          var urlBeginninng:Number=url.indexOf(://)+3;
          var urlTermination:Number=url.indexOf(/,urlBeginninng);
          var pageDomain:String=url.substring(urlBeginninng,urlTermination);
          var LastDot:Number=pageDomain.lastIndexOf(.)-1;
          var CharacterAfterDomain:Number=pageDomain.lastIndexOf(.,LastDot)+1;
          pageDomain=pageDomain.substring(CharacterAfterDomain,pageDomain.length);
          if (pageDomain!=www.somedomain.com/test/index.swf) {
                    warning_txt.text=This file is running on the wrong pageDomain. Content Access Restricted!;
                    closeBoxTop.visible = true;
          } else {
                    warning_txt.text=Yes Player Visible;
                    closeBoxTop.visible = false;
          stage.removeEventListener(Event.ENTER_FRAME, pageDomainCheckInit);
stage.addEventListener(Event.ENTER_FRAME, pageDomainCheckInit);
    Mar 22, 2012 5:36 AM   in reply to Venkom
    have u compared this
    if yes then use this
       if (pageDomain!='www.somedomain.com/test/index.swf') {
    Mar 22, 2012 6:33 AM   in reply to Venkom
    I would suggest tracing out the value of pageDomain before your if statement to make sure it's what you think it is
    I have worked this out in my head so excuse any mistakes
    as you can see from my comments I think pageDomain will be something like somedomain.com and you are comparing it to "www.somedomain.com/test/index.swf"
    // assume url = http://www.somedomain.com/test/index.swf
              var url:String = stage.loaderInfo.url;
              // url = http://www.somedomain.com/test/index.swf
              var urlBeginninng:Number = url.indexOf("://") + 3;
              var urlTermination:Number=url.indexOf("/",urlBeginninng);
              var pageDomain:String = url.substring(urlBeginninng, urlTermination);
              // pageDomain = www.somedomain.com
              var LastDot:Number=pageDomain.lastIndexOf(".")-1;
              var CharacterAfterDomain:Number = pageDomain.lastIndexOf(".", LastDot) + 1;
              pageDomain = pageDomain.substring(CharacterAfterDomain, pageDomain.length);
              // pageDomain = somedomain.com
              if (pageDomain!="www.somedomain.com/test/index.swf") {
              } else {
    Mar 22, 2012 9:48 AM   in reply to Venkom
    then you need to change this code to extract the exact domain you want
    e.g. if you want to accept only "www.somedomain.com/test/index.swf"
    then simply use something like
              if (url != "www.somedomain.com/test/index.swf") {
                        warning_txt.text="This file is running on the wrong pageDomain. Content Access Restricted!";
              } else {
                        warning_txt.text="Yes Player Visible";
    different modifications will be needed if you want
    only "www.somedomain.com/test/"
    or "www.somedomain.com/"
    Mar 23, 2012 2:02 AM   in reply to Venkom
    what do you mean validate http?
    you want to test against www.prasaar.com/dev/trials/vss/index.swf rather than http://www.prasaar.com/dev/trials/vss/index.swf?
    play around with the string manipulation and trace out the final pageDomain until it's in the format you want
    use something like this:
              var pageDomain:String = url.substring(urlBeginninng);
              if (pageDomain!="www.prasaar.com/dev/trials/vss/index.swf") {
              } else {
    Mar 25, 2012 9:50 PM   in reply to Venkom
    there is no real way to find out the html page. You might use externalinterface to talk to the page from the movie.
    Now, what actually do you want to achieve by not allowing visitors to view the swf without its surroundings?
