Drag/Drop "Numbered Stills" from Explorer into Project?
Mar 24, 2012 9:03 AM
I only get individual stills when I drag a folder from Explorer into a project.  Is there a way to tell Premiere to import as numbered stills (ie a sequence) when using drag/drop?
Thanks.
  • joe bloe premiere
    Dec 6, 2009
    Mar 24, 2012 11:38 AM   in reply to voxL
    Mar 24, 2012 3:38 PM   in reply to voxL
    Yes, there is an Adobe way that is MUCH better, but it is not exactly a Premiere Pro way
    1) Using Adobe Bridge, put all of your stills in the order that you want them to show in Premiere
    2) Select all photos and do a right-click "batch rename" (set to make a copy of all photos with 001 002 003 numbers in front of each file name in an empty sub-directory)
    3) Import the whole "folder" (that you just "batch rename" copied the photos into) using the "import folder" option
    Hope this works for your "workflow" as well as it does for mine.
    Jim
    Mar 24, 2012 7:06 PM   in reply to voxL
    Import the folder into PP. You can do this by draging and droping, from Bridge or Explorer or thru the explorer in PP. After the import you can then highlight the PP bin the on the task bar click sequence then automate to sequence. You are done.
    Mar 24, 2012 7:10 PM   in reply to srukweza
    Sorry, you find that selection in Project/ taskbar,
    Mar 25, 2012 7:32 AM   in reply to voxL
    This avoids needing to navigate to the files from within Pr.
    I believe you will need to do that in order to get the "Numbered Stills" checkbox.
