Hi All,
I have one doubt.Can anyone clear this doubt?
Steps:
1)I have created One movieClip & named as MyComp
2)I export this movieclip to actionscript.Class name for this movieclip is MyComp.
3)After that,Dynamically I have created 5 instance for this class & added to stage.
4)Now i need to change width of MyComp. it should reflect on previous 5 instance too.
I tried like,
I have created MyComp.as file in same location. There I tried to inherite DisplayObject properties Width.
Example :
In authoring time,I have one movieclip in my library which contains one rectangle shape..Im adding 5 instance of that movieclip in stage.
After that i get into one movieclip,and im increasing width of that movieclip by increasing Shape width. it ll get reflect in all instance..
i need this thing in actionscript.... is it possible?
Thanks...
you can't do what you are trying to do the way you are trying to do it.
I have included some code here (pure AS3, no timeline or library) which you might be able to adapt to your needs
Basically I have created a static property (_rectWidth which controls the rectangles width) on the MovieClip class that contains the rectangle and a render() function that redraws the rectangle tot he correct width. Note you will have to call render() after setting a new width to see the rectangle drawn at the new
...Copy link to clipboard
Basically I have created a static property (_rectWidth which controls the rectangles width) on the MovieClip class that contains the rectangle and a render() function that redraws the rectangle tot he correct width. Note you will have to call render() after setting a new width to see the rectangle drawn at the new width.
Then in the main class I create 5 rectangles with random colours and positions.
The main class also listens for the "arrow up" and "arrow down" keys to change the rectangle's size. Note: I change the size of the rectangle and then run through all of the Main classes children (which are all RectMC's) and call render();
package
import flash.display.Sprite;
import flash.events.Event;
import flash.events.KeyboardEvent;
public class Main extends Sprite
public function Main():void
if (stage) init();
else addEventListener(Event.ADDED_TO_STAGE, init);
private function init(e:Event = null):void
removeEventListener(Event.ADDED_TO_STAGE, init);
// entry point
for (var i:int = 0; i < 5; i++)
var col:uint = Math.floor(Math.random() * 0xffffff);
var rectX:int = Math.floor(Math.random() * stage.stageWidth);
var rectY:int = Math.floor(Math.random() * stage.stageHeight);
var rectMC:RectMC = new RectMC(col);
rectMC.x = rectX;
rectMC.y = rectY;
addChild(rectMC);
stage.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown);
private function onKeyDown(e:KeyboardEvent):void
switch (e.keyCode)
case 38:
RectMC.rectWidth += 20;
break;
case 40:
RectMC.rectWidth -= 20;
break;
for (var i:int = 0; i < numChildren; i++)
var rectMC:RectMC = getChildAt(i) as RectMC;
rectMC.render();
package
import flash.display.MovieClip;
* @author steven O'Boyle
public class RectMC extends MovieClip
protected static var _rectWidth:int = 100;
protected static var _rectHeight:int = 50;
protected var _rectColour:uint;
public function RectMC(col:uint)
_rectColour = col;
render();
public function render():void
graphics.clear();
graphics.beginFill(_rectColour);
graphics.drawRect(0, 0, _rectWidth, _rectHeight);
graphics.endFill();
public static function set rectWidth(value:int):void
_rectWidth = value;
public static function get rectWidth():int
return _rectWidth;
Thanks for ur valuable reply...
