How to localize Photoshop layer names
Mar 22, 2012 11:26 AM
I'm trying to get the default layer names for background, group, etc used by Photoshop depending on users local language.
As I haven't found a direct way I decided to use javascript instead:
I have a jsx code like
function GetBackground()
var message = localize( "$$$/LayerName/Background=Background");
return message;
and in the extension I use
var result:SyncRequestResult = CSXSInterface.instance.evalScript("GetBackground");
trace(result);
but result value is undefined.
Any help would be appreciated.
    Mar 26, 2012 2:33 AM   in reply to MSSDedalus
    Hello MSSDedalus,
    the returned result from the called extend is in form of a object; so you should add this code to the extendscript (just a example):
    var xml = '<object>';
    var xml = xml += '<property id="strMessage"><string>'+message+'</string></property>';
    var xml = xml += '</object>';
    and then return the xml variable instead of the message one.
    Then, you should have to modify the actionscript code as well:
    var oResult:Object;
        if((SyncRequestResult.COMPLETE == result.status) && result.data)
         oResult = result.data as Object;
         //Make sure oResult has the property you are expecting
           if(oResult.hasOwnProperty("strMessage"))
            var localizedString:String = oResult.strMessage;
    This can be found on the official documentation too.
    Best,
    Luca
    Mar 26, 2012 4:03 AM   in reply to MSSDedalus
    Have you tried this? (no separate jsx required)
    var message:String = HostObject.getRoot(HostObject.extensions[0]).localize( "$$$/LayerName/Background=Background");
