Using the print button to print then close a document
Mar 26, 2012 12:21 AM
I use Live Cycle Designer to create my Adobe documents.  I am working on a kiosk project and one of the menus navigates to a document page that has PDF documents and forms for users to print out.  The way the kiosk is designed, I would like for my pdf file to close after the print button is selected.  I recieved a solution in the general Adobe forum, but later found out the script does not work if the document was made using Live Cycle.  Any suggestions???  Is it possible??? Thanks.
    Mar 26, 2012 4:38 AM   in reply to ti_ger_p_a_w
    what solution did u get from Adobe forum ?
    you can write either of the following script on post-print event (print-button) to close the PDF after the print button is clicked -
    app.execMenuItem("Close"); (JavaScript)
    OR
    event.target.closeDoc(true); (FormClac)
    Regards -
    Chalukya.
    Mar 26, 2012 5:07 AM   in reply to ti_ger_p_a_w
    Open your PDF file in adobe livecycle designer, select print button on PDF.
    Go to windows(in adobe designer menu bar) and select Script Editor - In Show dropdown list select postPrint event and copy paste the code below-
    Regards-
    Chalukya.
    Mar 26, 2012 5:09 AM   in reply to chalukya
    You can also search for Scritp Editor in Adobe Designer Help, you will get the info about script editor.
    All the best -
    Chalukya.
